water cooling noob
shamgar03
289
A guy named 2fresh sells custom made radiators o the hardocp forums , heres the link : Cool Rad. How do you think his stuff compares to other - comercial radiators?
Mrvile
14,066
A heatercore is bigger and a little harder to work with (it doesn't come with screwholes or tube fittings). They're generally much cheaper though.
S Random
236
question: once you turn off your comp, does all the liquid in the water cooling system drain into the reservoir?
NINaudio
526
4
What he's selling looks like any heater core you could get from a junkyrad. They usually work quite well at cooling, but don't look as nice as a black ice radiator (if you care about that at all), and may require stronger fans.
S Random: Once you shut your pc off the water should pretty much just stay where it is unless you have it draining into the top of your reservoir, but I don't think I've ever seen anyone do that before.....
Tyrant222
802
the heatercore will cool very well, better than the ones by HWLabs. but like mentioned they will need strong >100 cfm fans and custom mounting.
