Hey this summer I am planning on adding water cooling to my computer. I know there are like 50 posts about this, but I couldnt find one that answered a few specific questions. So here it goes. First, am I correct in assuming that the entire circuit has no air in it, including the resevoir, or does it matter if you have air in the resevoir? Also whats the best way to go if I am going to cool both my video card and my processor. Should I have two completely separate circuits or should I have a 't' junction that goes to each and then comes back together for the radiator. Or should I have them in series with the path going from the processor to a radiator to the gpu to another radiator and then back into the resevoir? I was also thinking, what if I had a single resevoir and had a loop going to each, and then a third loop going through the radiator? Anyway what about measuring pressure and flow rate. Do I need to check to make sure flop rate stays even two both loops? Alright thanks
