Originally posted by: Slickone
This will convert a PAL DVD to NTSC (like Apex), correct? Anyone tried this? How's the quality?
anyone know how to determine in which version of divx a movie is encoded in? Is there a way the liteon player can display which version the movie is?
what is macrovision and why should i turn it off?
Originally posted by: drti
most of the people was right, xbox probably a much better deal. if you don't have a game console yet, then xbox is a better choice. eventhough ps2 has more games than xbox now, but xbox hardware is far more superior than ps2.
anyway, you can go to sam's or costco, buy the xbox, mod, if something wrong, they take it back no problem.
for non-technical people who's doesn't want to mess w/ moding and stuff, then this dvd player is a way to go. plus, lot of people complained about xbox cdr compability problem.
thanks,
tk
Originally posted by: LordAccord
I've had more problems with TV-Out quality from my PC than the DivX quality itself. That's more in the hands of the encoder. All you people complaining that you can't stand to watch a DivX movie on the television.... I have to ask... what did you ever do before DVD, because my VHS tapes certainly have never stood up to a DivX encode? I mean, at least that's a worthy question, because it doesn't seem to me that the DivX codec was designed to knock DVD MPEG2 out of the circle or anything, let alone with a 700mb file vs a 4gb set.
I think its a matter of what you are used to watching. DVD's look great on my 32" TV but once I got a front projector I'm beginning to see flaws even on DVD's. This is on a 100" screen. Now I can't wait till DVD's go high def.
Originally posted by: phenderson
Originally posted by: shuan24
Is it really worth $140? I mean, you could easily build a custom "DVD player" for the same price or cheaper, but with all the mods you want. IMHO, I really don't see the advantage in this player, other than the fact that its already built for you. With the custom player you could install all codecs (like FFDshow) and not just watch Divx/Xvid only.
I am going to call you onto the carpet on this one...
Lets see....
$ 40.00 for a cheap or used ATX case. (hopefully with PSU)
$ 50.00 for at least a cheap TV Out, good quality Directx 9 Video card (possibly and Ati-All-in-Wonder)
$ 40.00 for a used or new DVD-R that will play all of the formats
$ 35.00 for at least 256 megs of ram (maybe 25.00 used) to run the OS
$ 20.00 for cheapo used 20.0 gig harddrive
$ 60.00 for used CPU\motherboard combo, presumably and Athlon XP solution (hopefully it comes with HSF)
$ 50.00 for perhaps (just to be legal) Windows 2000 license....
Now lets add labor,
-If you are blessed, it will take 20 minutes to 2 hours to put the system together, another hour to
install OS (harddrive format then OS files copied, then reboot then OS installed then reboot)
-It should take another hour to update the OS and install all of the DiVX and Mpeg 4 codecs
-It should then take another 20 minutes to move the big lug (cheapo cases are big... not SFF or HSF) case then connect the unit.
That sounds like about 5 hours of work to me... and if I go by what most techs could charge, lets say a minimun of $50.00 an hour... welllllllll $250.00 for labor...
Now some other luxuries that will be needed...
$40.00 ATI remote wonder (or pay $75.00 above and substitue video out card with ATI AIW 7500)
$50.00 for wireless keyboard mouse combo...
we have a grand total of
$635.00
WOW.... sounds like some custome made system to me... and it looks ugly sitting next to my entertainment center in "el-cheap" vanilla case... Plus it takes me 10 minutes to boot the sucker, then login to Windows, then place the DVD in the drive and play them....
WOW... $140.00 Liteon looks good right now... in fact it looks awesome!!!
Guess what, I have the exact same system that I mentioned, above... except my parts are higher quality...
And it cost me a ton of money... to put it together, but for what its worth... I can at least play BF1942 on it...
Of course we could subtract the $250.00 for labor and still would have a nice $385.00 DVD player... which still is a little extreme considering most of us probably have $500.00 receivers or less...
One more thing... most everybody knows that 90% of the illegally distributed movies and TV episodes out on the net encode in some form of Mpeg 1(VCD) Mpeg 2(SVCD) or DiVX or Mpeg4. SO there really is not a need for RM...or even QT...
Originally posted by: lungster
- Regarding the use of xBox - from what I've read on the net, it seems I don't have the Samsung DVD drive (I think mine is the Philips). The results is that I can't read CD-R audio and DVD+R use is so-so. Even as a DVD player, the drive sometimes hicups. In short, I wouldn't recommend using an xBox for serious media playing unless you know for sure what you're getting in the hardware. And that says nothing about the extra work of having to convert its BIOS
Lets see....
Now lets add labor,
$635.00
I bought a used p2-333 box (256mb ram, 8gb hdd, video with tv-out) on here for $45 shipped, added a $10 dvdrom I got on here and a $17 logitech cordless kb + mouse.. only thing missing is the remote which I don't care about since I have wireless kb+mouse... total for my dvd box (also use it to rip tv shows) was ~$72 all thanks to the FS/FT forum..
