Demon-Xanth
- Feb 15, 2000
- 20,551
- 2
- 81
Laust: check out DC's 4.7 that's in the trucks and Jeeps. Fuel injectors are pointed straight up, spark plugs are on the top, under the coils which point straight up and attach with a 10mm nut, a quick disconnect cable attaches to the coil. You can swap cams w/o taking any major parts off. The valve train is even more simple than a pushrod, it still has rockers. It's quite possibly the easiest access engine that I've ever had the potential to work on (haven't needed to yet). Would I trade the SOHC for pushrods+displacement? Oh hell yeah I would. Pushrod engines are so much more narrow that you can cram some massive displacements in the same size box. The 4.7 can only be enlarged to about 330CID, the Hemi's the same phyiscal size, but has been pictured in upto 6.1L. (rumored 425HP, 425LB/ft)
...I wonder how much an engine swap would run...
