Originally posted by: DEMO24
Originally posted by: z1ggy
Don't work your self up over a type-o. Jeez somebody is an angry elf today.
And honestly, I am not all that certain what I want to do. I have a non turbo 07 impreza. I highly considered just selling what I have now and trying to get a 04 or 05 wrx and then modding it. I guess I would have to do a cost analysis to figure out what would be the best thing to do. But if I was to keep what I had now for a long time, then I would want to upgrade everything....add a turbo,intercooler, intake, suspension..everything.
No point in trying to pull too much power out of that engine as it's simply going to cost too much to be worth it. If you can find some exhausts that have been used and are cheap for your model then it might grant you a few hp's.
Otherwise what I would focus on is making it handle better. That's pretty easy to do with some new springs, and some stiffer sway bars. But to do those projects will require someone with mechanical knowledge. Also cost you a few hundred bucks.
Of course the best thing you could do is make sure you aren't on the stock crappy rubber.
