Ok, Im back and am thinking of water again. For now just a simple loop for my Q9550 on a Gigabyte EP45-UD3P. Have a 4850 that I might try to add in later, but thats another day for now.
I havent really researched too much and think I might try to find deals in the for sale section to help on costs; we'll see. Can anyone/Aigo recommend a system for me please? I was reading through BTRY's thread and was wondering if I would need something similar or if the recommendations would be the same?
On another note; What exactly would be the differences between a MCP-355 pump and the D5 MCP-655? Also whats the difference between using a XSPC or EK pump top as appossed to a res top; would it be for saving space?
I think thats it for the moment till I get some suggestions. I currently do not have a case, but more than likely will be using something like a TJ-07 or the lian-li equivilent ( I think its the A70B or something like that).
Thanks
Thanks
