wanna upgrade cpu
Markfw
May 16, 2002
27,261
16,119
ATI- XFX
Nvidia - EVGA
But unfortunately you don't find these brands in India, atleast I didn't until now. I know ASUS is an OEM for both and is available there too. I am not sure about powercolor's QC but MSI and Sapphire are good brands you can look into.
EDIT: I just did some quick browsing and a 5770 is around Rs. 10,500 /- and GTX 460 768 MB is for around Rs. 11,500 /-
If you can get a I5 760, and one of those video cards, you are set. Otherwise, you might as well, just sit still with what you have, you really need both.
samrat
12
hello freinds good afternoon
so finally i check the price and asus 5770 is for 210 dollars and xfx 5770 is available for 220 dollors and sparkle gtx 460-768 mb is available for 245 dollars .
so what should i go for now...
Thanks.
richierich1212
2,741
360
Well if you can spring for the 460 go for that. But I'd like for you to upgrade your monitor to one that has a better resolution as well ;).
samrat
12
Hiiii...freinds,
how much will there be any PERFORMANCE difference in gtx 460 1 gb and 768 mb.can i go for ZOTAC.
and distributor told to my dealer that gtx 460 is problematic card...is it true ?He was insisting me for ASUS 5770.
(in my opinion no problem with the 460card).what's your opinion...please guide.
Thanks a lot.
toyota
12,957
Hiiii...freinds,
Thanks a lot.
at 1366x768 the 5770 is fine but if the gtx460 768mb is not much more there then go for it. if you don't plan on getting a larger monitor any time soon then there is no need for a gtx460 1gb.
RavenSEAL
8,661
I would go with the 5770 personally, ATI has more of a kick as far as performance vs cost ratio. If the 5770 is 1GB, there is no reason to grab a 460.
samrat
12
hi friends,
now going a bit offtrack. today i tried to oc my i3-530 with asus vcore help and successfully oc it to 3.2 ghz with following settings
bclk freq 150
cpu volt 1.18750
dram us volt 1.560
imc volt 1.10000
cpu pll 1.80
pch 1.05000
igpu freq 1033
igpu volt 1.4750
but when i increase the blck to 160 it restarted. can you pls give me the setting to increase cpu to higher ghz. my cpu has stock cooling with it.
thanks
Apr 20, 2008
10,067
990
At those prices, ATI does NOT have better price/perf. The 460 takes the edge here. It costs more because its better, obviously.
OP, If have cash to spare, the 460 is a much better choice. If youre limited, a 5770 is in your future ;-)
Rifter
751
are you even reading this thread? how can you say a 5770 is a better deal that a 460 with the prices he listed, $210 5770 vs $245 460? thats only a 12% price differnce and the 460 offers at least a 12% performance differnce in most games. That would definatly NOT give ATI better performance vs cost ratio.
http://www.anandtech.com/bench/Product/172?vs=156
samrat
12
Hi friends,
Good evening from my side..
so GTX 460 is not easily available in India. If available in India its highly priced..
ASUS GTX 460-768 MB is for 290 dollors and the palit GTX 460-1gb is for 315 dollors.
only Sparkle gtx 460-768mb is available for 240 dollors and 1 gb is for 270 dollors.
and sparkle dealer told me that the price will go down after 10th of september. what should i have to do now.
these are latest tax paid price.
please advise.
Thanks
Rifter
751
yeah if the price is going down in 10 days then if at all possible i would wait and then get a sparkle 1GB. Unless you are for sure going to stay under 1080P resolution in which case the 768MB model will do fine.
RavenSEAL
8,661
Does this also mea cuts on the GT2xx series? I saw newegg had the rebates but they expired today before i could buy my friend the card he needed...any idea if there are any more rebates coming out soon?
samrat
12
Hi everyone.
my current configuration is :-
intel core i3-530
corsair vx 450 watt power supply
asus p7h55-m motherboard.
2 gb ddr3 1333 mhz ADATA ram
aoc 18.5 inch Led moniter
1 tb WD caviar black 32 MB cache.
soon i'll upgrade the processor to intel core i5-760 and graphic card to sparkle gtx 460 1 GB.
so can you please help me about cabinet.
i am using a old cabinet.this cabinet has only 1 exhaust fan at rear.and no other fan expansion available .only cpu and psu fans are there .so should i have to go for a new proper ventilated cabinet. is cooler master ELITE 430 BLACK will be a good option.?
please help me out.
THANKS.
toyota
12,957
you need more ram. 2gb does not cut it anymore and some games will hitch. also with an i5 760 and gtx460 you will be pushing that psu a bit if you overclock. it only has 33amps on the 12v so its not really suited for a higher end system.
bryanW1995
11,144
32
OP is in India.
Core i5 750/760 should be a good step up, or a Core i7 860 if you need 8 threads for video encoding especially. If you can sell the 530 back at market price, then the upgrade is not a bad idea if you really do a lot of video work.
yes, and also i7 950 requires a new mobo whereas with a 7 or 8 series cpu he can just drop it into his existing one.
RavenSEAL
8,661
Hi everyone.
intel core i3-530
please help me out.
THANKS.
Like mentioned above...you might wanna add 2 more gigs of ram MINIMUM if you're going to game. As far as cases...see if you can find the Rosewill CHALLENGER in india. Comes with 3 fans and plenty of room for technically anything.
Here is the newegg link if you want more info on it.
http://www.newegg.com/Product/Produc...82E16811147153
Pretty good budget case, you need those other 50 dollars you would spend on some fancy ass case to upgrade your ram. At least thats what i would so. Also, for your i5, try to get an after market cooler.
