[VR-Zone] NVidia GTX-590 *FINAL* Specs Revealed!
SlowSpyder
17,305
1,002
I bet Nvidia will market this as a card capable of massive overclocks. I don't think at that clock speed it'll beat a 6990. But we'll see what happens. I am looking forward to the power consumption numbers when overclocked just for a laugh, though. :)
n0x1ous
2,574
252
612 mhz?! That is fail. Its not going to beat 6990 at that speed. I can't believe they are even going to release this thing if it doesn't beat the 6990 across the board by at least 5-10%
The point of these cards are halo/mindshare not sales, so if they don't get that, why bother.
I can only hope VRzone is wrong. I was thinking/hoping for 700mhz....
Ghiedo27
403
Just watch, there's going to be warranty tape over a 3rd 8 pin power plug! :biggrin:
TerabyteX
Banned
Mar 14, 2011
92
For some reason, lots of XFX HD 6970 were reporting noise issues but that's a story for another thread. I was pretty sure that the GPU would be clocked to 600MHz or around that, so no surprise here. But I certainly doubt that it will outperform a stock HD 6990 at such stock speeds. HD 6990 at stock speeds can keep up easily with the GTX 570 SLI which has much higher clocks, let alone two heavily underclocked ones, Seems that ATI's (I mean AMD) approach of small die pays itself in the dual GPU arena.
RussianSensation
19,458
765
Even if GTX590 doesn't outperform the 6990, the 6990 is more or less unusable in reference design form. It really doesn't matter if the 6990 is 10-20% faster. Who would subject themselves to 70 DB+ of noise levels? At the end of the day if the 590 comes in at 10% slower but is FAR quieter, it's the winner imo. When comparing such videocards, +/-10% performance isn't much at all. If I had a $700+ graphics card, I may also want to try 3D, where NV wins again. Also, the card would be fast enough to run AA+PhysX. So I don't necessarily agree that this card has to be faster to be better.
Idontcare
21,110
64
Seriously. Why not just tape over all them, put a label on the box itself that states your warranty is void if you expose the video card to your computer in any way. :D
TerabyteX
Banned
Mar 14, 2011
92
I don't see how nVidia wins in this case, the card haven't been released yet, so nobody knows how loud or quiet it will be. It is clear that they lost the performance crown except in Tri-SLI exotic scenarios. The HD 6990 might be loud, but with a well ventilated case, that issue will diminish somewhat. Remember that most noise tests are done placing the sensor close to the cooler, are you gonna play games sticking your ear on the cooler shroud?
Enthusiast doesn't care much about noise as everything is about efficient performance without reaching astronomical levels of power consumption. If you care about noise, I think that you would like better the GTX 560 Ti or the HD 6870.
badb0y
4,015
30
That's impossible since both cards are using the same type of cooler and Fermi is more power hungry than Cayman.
Since we are on the topic of features, will this card be Surround capable? Or would we need 2 cards to run 3 monitors?
WelshBloke
33,551
11,698
Its not about sensible, if it was you could just SLI two gtx 580's and call it a day. These cards are for the people who otherwise would set their fans to 100% and overvolt to he limit.
As long as Nvidia/AMD continue to put out their more mainstream cards with (somewhat) sensible power use/noise levels I'm more than happy for them to go balls to the wall with their extreme offerings.
WelshBloke
33,551
11,698
Nvidia does have a history of building better coolers than AMD though.
badb0y
4,015
30
Unless it's a triple-slot cooler I think the coolers are going to be on par in terms of cooling. The shroud on the GTX 590 is removable so I assume you can remove the shroud and have a fan blowing air right on the heatsinks that would give the GTX 590 an edge but that's about it.
WelshBloke
33,551
11,698
They should make a clip on kit to replace the stock shroud that has two blower fans over the heatsinks.
Maybe thats the idea behind the removable shroud.:eek:
Jionix
238
The same type of cooler != the same quality and capabilities.
I'm fairly confident that, in terms of reference cards, Nvidia won't be using anything more extravagant, quality wise, then AMD.
You have to realize; At the same power envelope, Nvidia will be cooling the same amount of heat/power as AMD, and if it wasn't for the massive underclocking, Nvidia would have been needing to cool a great deal MORE heat/power.
There is only so much you can do with the design both are using (at default) --- cooling 375w, dual vapor chamber heat-sinks, a centrally located blower.
Kenmitch
8,505
2,250
Doesn't matter which card is faster....They both need full water blocks!
Full water blocks would tame both of these beasts! Would make a nice review with both of them going toe to toe in single and cross-fire/sli. Would be nice to see how much overclocking headroom these cards would have under water!
RussianSensation
19,458
765
Well if it runs well below the specs of a full-bledged 580, the fan may not need to spin as hard.
It's one thing to have a louder card, but 6990 is the loudest card ever made outside of the FX5800U. I still think enthusiasts care about noise to some extent. This is why cards with superior coolers like the Asus DirectCU II series of cards are popular among enthusiasts for example. Also, hardcore overclockers who benchmark will likely put this card under water anyway and run 2 of them. What about everyone else? Use earplugs?
NV wouldn't have listened to their customers' complaints about how loud the GTX480 was when they redesigned the heatsinks on the 570/580 series if enthusiasts didn't care about noise. Specifically, lower noise was one of the features in their GTX580 slides.
n0x1ous
2,574
252
Maybe Hilbert can give this a go for us. :thumbsup:
badb0y
4,015
30
You would think that wouldn't you but according to these guys who ran 2 GTX 580s at 600 core, the GTX 590 would still be producing more heat than a HD 6990.
http://plaza.fi/muropaketti/artikkelit/naytonohjaimet/ennakkokatsaus-nvidia-geforce-gtx-590
notty22
3,375
I agree. The 580' reviews show they had the better cooler Vs the 6970, on top of the fact it uses more power. Each company still can out-engineer each other and its not a given that 'they (HS~fan,are equal)' so irrelevant.
Fan noise of the Radeon HD 6970 is ok. When compared with NVIDIA's latest GTX 580 that was optimized for low noise, we see about the same numbers. But GTX 580 is over 10% faster!
RussianSensation
19,458
765
Except it needs to cool 2 580s with one fan.
How exactly is a 512SP chip clocked at ~ 612mhz = a full fledged 580 @ 772mhz? If the chip is clocked at 20% slower, you don't need to supply the same high voltage to maintain these lower frequencies.
But what if NV runs at 600 core at lower voltages? Either way, if it's a dustbuster like the 6990, the excitement about it will die down within 1 day.
AtenRa
14,003
3,362
Well at the same TDP (375W) both coolers will have to dissipate the same amount of heat so i dont see why one cooler cant be better than the other.
3DVagabond
11,951
204
All of your points are valid. One consideration though. because there is no standard means of measurement for either power consumption or noise, we need to be careful just listing either spec from one review as the spec for the card. For example 70db+. It's not hard at all to find reviews from respected sources, TechPowerUp, for example http://208.43.3.154/reviews/ASUS/Radeon_HD_6990/21.html that give noise levels far, far, lower.
Arkadrel
3,681
Thats because TechPowerUP measures around 100cm from the pc (normal sitting range from a pc). Some measure it like 3cm from it, but who in their right mind sit with their ears 3cm from a gpu? no one, does it matter how much noise it makes at 3cm then? no.
TechPowerUP: (GPUs under heavy load):100cm from GPU:
580 = 41 dB
280= 51 dB
480= 50 dB
6990 = 53 dB
TechPowerUP: (GPUs under idle load):100cm from GPU:
580 = 31 dB
6990 = 34 dB
also the 590 isnt released yet, if it turns out to be ~50 dB or 54 dB, will the people the crusified the 6990 for being noisy say the same about the about the 590?
