Voyager is at the edge :
Sunny129
4,823
yes, i didn't want to mention accretion as this thread is generally about the sun. but it is quite amazing...it is the most efficient process in which matter is converted into energy that we know of, is it not?
...and it is confounding how much hotter the corona is than the sun's actual surface when intuition tells us that things get cooler the farther one gets form the sun...
May 11, 2008
20,138
1,149
And yet, still a couple orders of magnitude less than accretion onto a compact object. Fusion is .07% efficient? Accretion can convert up to 10% the rest mass energy into radiation.
Also, the sun only really does hydrogen -> helium fusion, it's not massive enough for anything else interesting happening.
What is interesting though, is that the surface of the sun is around 6000K, while the corona is more like 1000000K....the magnetic reconnection problem is far from a solved problem.
I cannot wait until that mystery will be solved. That knowledge will be a giant leap forward for humanity. I wonder if it will be the winning answer for space travel (propulsion and power generation/distribution). It should give massive new insights into plasma science.
May 11, 2008
20,138
1,149
I knew i had read it somewhere :
http://arstechnica.com/science/news...ns-corona-so-much-hotter-than-the-surface.ars
Here is the theory :
Plasma jets make Sun's corona so much hotter than the surface
The Sun's core is millions of degrees, while the solar surface is a balmy 5800 kelvin. But travel to the Sun's outer atmosphere, the corona, and it heats up to millions of degrees again. The corona is a wispy plasma envelope extending millions of miles above the Sun's surface. Why the tenuous atmosphere above the sun is hotter than the actual surface has remained a mystery. One generic explanation has been that magnetic fields must be involved, but getting beyond this superficial understanding has required more detailed observations.
New solar missions, designed to take the surprises out of living next to a star, are reaching the point where they have the spatial and temporal resolution to observe previously hidden solar phenomena. These observations are revealing a compelling link between the coronal plasma that is heated to millions of degrees and ubiquitous, ephemeral jets that reach into corona. A paper published in Science reports on observations obtained with the Atmospheric Imaging Assembly on NASA’s Solar Dynamics Observatory (SDO) and NASA’s Focal Plane Package for the Solar Optical Telescope (SOT) on the Japanese Hinode satellite. Beyond good science, the recently launched SDO satellite has been taking some fabulous pictures of our Sun.
A solar phenomena we observed a long time ago turns out to be the cause of hot plasma in the solar corona. In 1877, tendrils were seen on the Sun's surface that wavered from side to side like a field of wheat in a gentle breeze. These whiskers on the sun are known as spicules, and they're understood to be fountains of relatively cool, 10,000° plasma that shoots up from the Sun's interior and reach its outer atmosphere. Spicules are extremely common on the Sun and, although they have been considered as prime candidates as a coronal heating mechanism since the 1960s, their low temperature seemed to rule them out.
The lead author of this Science paper is Dr. Bart De Pontieu at the Lockheed Martin Solar and Astrophysics Laboratory; he has published a series of papers with collaborators about solar chromospheric spicules. They have found that the spicules we've observed in the past don't provide adequate heating of the chromosphere, but that a second class of spicules known as type II do have that potential. "These classical spicules form when sound waves (from oscillations and convective motions in the photosphere) propagate upwards into an ever more rarefied atmosphere, which leads to strong shock waves that drive plasma upwards," Pontieu told Ars. "Type II spicules cannot be explained by this mechanism since they reach much larger speeds and develop coronal temperatures. They are likely caused by some mechanism that is driven by the Sun's magnetic field."
Type II spicules are accelerated into the corona at speeds up to 100 km/s and have plasma heated to temperatures up to 1 million Kelvin. The new observations show hot plasma associated with spicules for the first time, indicating that the energy flux density into the corona is on the order of that required to sustain its temperatures in the face of the energy the corona radiates away.
In rough physics terms, this means that energy in now appears to equal the energy out, making spicules a dead-obvious source of coronal heating. However, there is still an uncertainty regarding the mechanics of the heating and eruption of the type II spicules themselves. It could be heating by magnetic waves or heating from reconnection of magnetic field lines that are twisted by convective motion at the solar surface.
Pontieu sums up the situation by stating that, "Our observations, for the first time, show hot plasma that is associated with spicules. Enough hot plasma to play a significant role in filling the corona." Even as we have one answer, we have another question: "Our challenge now is to understand what drives and heats the material in the spicules," Pontieu said. More advanced simulations of the Sun's magnetic field and more detailed observations are needed.
Science, 2010. DOI: 10.1126/science.1197738 (About DOIs).
May 11, 2008
20,138
1,149
I will add here some info about spicules.
http://en.wikipedia.org/wiki/Spicule_(solar_physics)
At any one time there are around 60,000 to 70,000 active spicules on the Sun; an individual spicule typically reaches 3,000-10,000 km altitude above the photosphere.
Bart De Pontieu (Lockheed Martin Solar and Astrophysics Laboratory, Palo Alto, California ), Robert Erdélyi and Stewart James (both from the University of Sheffield, Sheffield, UK) hypothesised in 2004 that spicules formed as a result of P-mode oscillations in the Sun's surface, sound waves with a period of about five minutes that causes the Sun's surface to rise and fall at several hundred meters per second (see helioseismology). Magnetic flux tubes that tilted away from the vertical can focus and guide the rising material up into the solar atmosphere to form a spicule. There is still however some controversy about the issue in the solar physics community.
http://en.wikipedia.org/wiki/P-wave
P-waves are a type of elastic wave, also called seismic waves, that can travel through gases (as sound waves), solids and liquids, including the Earth.
I wonder if these p waves have something to do with the pressure waves that where turned into sound by researchers in post 31 from this thread.
20,138
1,149
News from voyager 2:
http://www.nasa.gov/mission_pages/voyager/voyager20111114.html
Voyager 2 Completes Switch to Backup Thruster Set
11.14.11
Voyager mission status report
PASADENA, Calif. -- NASA's Voyager 2 has successfully switched to the backup set of thrusters that controls the roll of the spacecraft. Deep Space Network personnel sent commands to the spacecraft to make the change on Nov. 4 and received confirmation today that the switch has been made.
The change allows engineers to reduce the amount of power that the 34-year-old spacecraft needs to operate by turning off the heater that keeps the fuel to the primary thrusters warm. Although the rate of energy generated by Voyager 2's nuclear power source continues to decline, by reducing its power requirements, engineers expect the spacecraft can continue to operate for another decade.
The switch also allows the spacecraft to use previously unused thrusters as it continues its journey toward interstellar space, beyond our solar system.
Voyager 1 and Voyager 2 are each equipped with six sets, or pairs, of thrusters to control the pitch, yaw and roll motions of the spacecraft. These include three pairs of primary thrusters and three backup, or redundant, pairs. Both spacecraft are now using all three sets of their backup thrusters.
Voyager 2 is currently located about 9 billion miles (14 billion kilometers) from Earth in the heliosheath -- the outermost layer of the heliosphere where the solar wind, which streams out from the sun, is slowed by the pressure of interstellar gas.
The Voyagers were built by NASA's Jet Propulsion Laboratory in Pasadena, Calif., which continues to operate both spacecraft. JPL is a division of the California Institute of Technology in Pasadena. The Voyager missions are a part of the NASA Heliophysics System Observatory, sponsored by the Heliophysics Division of the Science Mission Directorate. For more information about the Voyager spacecraft, visit: http://www.nasa.gov/voyager .
General news about the voyagers :
http://www.nasa.gov/mission_pages/voyager/index.html
http://en.wikipedia.org/wiki/Voyager_program
May 11, 2008
20,138
1,149
The huge filament from post 46 has partially respawned and is now bigger then ever.
800.000km long and it has shifted more towards the equator of the sun according to space weather.com. But i do not really have the impression that the filament or one of the ends has shifted more towards the equator.
GREAT FILAMENT: It's one of the biggest things in the entire solar system. A dark filament of magnetism measuring more than 800,000 km from end to end is sprawled diagonally across the face of the sun. NASA's Solar Dynamics Observatory took an ultraviolet picture of the structure during the late hours of Nov. 17th:
If the filament becomes unstable, as solar filaments are prone to do, it could collapse and hit the stellar surface below, triggering a Hyder flare. Indeed, part of the filament already erupted on Nov. 16th, but Earth was not in the line of fire when the twisted lines of magnetism snapped. A similar event today would likely be geoeffective because of the filament's central location on the solar disk.
I am not sure but i think this is a picture taken by a camera with UV filters or just sensitive to UV but i am not sure. It might also be digitally colored with the computer.
http://www.nasa.gov/mission_pages/sdo/news/avalanche.html
The Solar Dynamics Observatory has three main instruments. The Atmospheric Imaging Assembly (AIA) is a battery of four telescopes designed to photograph the sun's surface and atmosphere. AIA filters cover 10 different wavelength bands, or colors, selected to reveal key aspects of solar activity. The bulk of SDO's data stream will come from these telescopes.
The Helioseismic and Magnetic Imager (HMI) will map solar magnetic fields and peer beneath the sun's opaque surface using a technique called helioseismology. A key goal of this experiment is to decipher the physics of the sun's magnetic dynamo.
The Extreme Ultraviolet Variability Experiment (EVE) will measure fluctuations in the sun's ultraviolet output. EUV radiation sun has a direct and powerful effect on Earth's upper atmosphere, heating it, puffing it up, and breaking apart atoms and molecules. "We really don't know how fast the sun varies at these wavelengths," notes Pesnell. "We're guaranteed to learn something new."
To gather data from all three instruments, NASA has set up a pair of dedicated radio antennas near Las Cruces, New Mexico. SDO's geosynchronous orbit will keep the observatory in constant view of the two 18-meter dishes around the clock for the duration of the observatory's five-year mission. Not a single bit should be lost.
Sunny129
4,823
no doubt that the exposure - or at the very least one of its components - was taken through a UV filter. but that picture has an interesting and complex mix of colors, so i wonder if there isn't IR, visible, and perhaps even Hydrogen alpha-filtered light in that image. either way, the digitally assigned false colors (for UV, IR, and any other forms of light outside the visible spectrum obviously) in that image seem to suggest to me more than just UV light...
...of course it could just be entirely composed of UV light, with different false colors assigned to different wavelengths/narrow bands in the UV region of the spectrum...
Biftheunderstudy
375
A quick google search turns up that it observes the sun in 10 bands ranging from white light (?) to EUV bands at 13.1 nm.
Seems reasonable that that image could be reproduced with 10 "colors".
May 11, 2008
20,138
1,149
I see.
With such a camera, is the camera sensitive to the entire range or is the range divided into 10 small bands with sharp edges ?
Another picture :
Sunny129
4,823
I see.
well without having specifically researched the SDO myself, i would bet that it has a multitude of instruments on board, each of which detects a narrow band of wavelengths in the UV portion of the EM spectrum. on other words, it probably uses a number of cameras, not just one. then the exposures from each individual camera are assigned false colors depending on their range of wavelengths. and then they are probably laid over each other (using CCD Stack, Maxim DL, and perhaps an assortment of other photo editing software suites), giving us the complex colors we see in the photo in your previous post.
May 11, 2008
20,138
1,149
Yahooo ! Perhaps there is progress again ?
On the website there is a video as well :
http://www.physorg.com/news/2012-02-plasmas-torn-physicists-discovery-hints.html
False color close up of magnetic field lines on the surface of the sun :
An argon plasma jet forms a rapidly growing corkscrew, known as a kink instability. This instability causes an even faster-developing behavior called a Rayleigh-Taylor instability, in which ripples grow and tear the jet apart. This phenomenon, the Caltech researchers say, has never been seen before and could be important in understanding solar flares and in developing nuclear fusion as a future energy source. Credit: A. L. Moser and P. M. Bellan, Caltech
January saw the biggest solar storm since 2005, generating some of the most dazzling northern lights in recent memory.
The source of that storm—and others like it—was the sun's magnetic field, described by invisible field lines that protrude from and loop back into the burning ball of gas. Sometimes these field lines break—snapping like a rubber band pulled too tight—and join with other nearby lines, releasing energy that can then launch bursts of plasma known as sol ar flares. Huge chunks of plasma from the sun's surface can zip toward Earth and damage orbiting satellites or bump them off their paths.
These chunks of plasma, called coronal mass ejections, can also snap Earth's magnetic field lines, causing charged particles to speed toward Earth's magnetic poles; this, in turn, sets off the shimmering light shows we know as the northern and southern lights.
Even though the process of field lines breaking and merging with other lines—called magnetic reconnection—has such significant effects, a detailed picture of what precisely is going on has long eluded scientists, says Paul Bellan, professor of applied physics in the Division of Engineering and Applied Science at the California Institute of Technology (Caltech).
Now, using high-speed cameras to look at jets of plasma in the lab, Bellan and graduate student Auna Moser have discovered a surprising phenomenon that provides clues to just how magnetic reconnection occurs. They describe their results in a paper published in the February 16 issue of the journal Nature.
"Trying to understand nature by using engineering techniques is indeed a hallmark of the Division of Engineering and Applied Science at Caltech," says Ares Rosakis, the Theodore von Kármán Professor of Aeronautics and professor of mechanical engineering and the chair of engineering and applied science.
In the experiments, Moser fired jets of hydrogen, nitrogen, and argon plasmas at speeds of about 10 to 50 kilometers per second across a distance of more than 20 centimeters in a vacuum. Plasma is a gas so hot that atoms are stripped of their electrons. As a throughway for speeding electrons, the jets act like electrical wires. The experiment requires 200 million watts of power to produce jets that are a scorching 20,000 degrees Kelvin and carry a current of 100,000 amps. To study the jets, Moser used cameras that can take a snapshot in less than a microsecond, or one millionth of a second.
As in all electrical currents, the flowing electrons in the plasma jet generate a magnetic field, which then exerts a force on the plasma. These electromagnetic interactions between the magnetic field and the plasma can cause the jet to writhe and form a rapidly expanding corkscrew. This behavior, called a kink instability, has been studied for nearly 60 years, Bellan says.
But when Moser looked closely at this behavior in her experimental plasma jets, she saw something entirely unexpected.
She found that—more often than not—the corkscrew shape that developed in her jets grew exponentially and extremely fast. The jets in the experiment formed 20-centimeter-long coils in just 20 to 25 microseconds. She also noticed tiny ripples that began appearing on the inner edge of the coil just before the jet broke—the moment when there was a magnetic reconnection.
In the beginning, Moser and Bellan say, they did not know what they were seeing—they just knew it was strange. "I thought it was a measurement error," Bellan says. "But it was way too reproducible. We were seeing it day in and day out. At first, I thought we would never figure it out."
But after months of additional experiments, they determined that the kink instability actually spawns a completely different kind of phenomenon, called a Rayleigh-Taylor instability. A Rayleigh-Taylor instability happens when a heavy fluid that sits on top of a light fluid tries to trade places with the light fluid. Ripples form and grow at the interface between the two, allowing the fluids to swap places.
What Moser and Bellan realized is that the kink instability creates conditions that give rise to a Rayleigh-Taylor instability. As the coiled plasma expands—due to the kink instability—it accelerates outward. Just like a passenger being pushed back into the seat of an accelerating car, the accelerated plasma is pushed down on the vacuum behind it. The plasma tries to swap places with the trailing vacuum by forming ripples that then expand—just like when gravity forces a heavy fluid to try to change places with a light fluid underneath. The Rayleigh-Taylor instability—as revealed by the ripples on the trailing side of the accelerating plasma—grows in about a microsecond.
"People have not observed anything like this before," Bellan says.
Although the Rayleigh-Taylor instability has been studied for more than 100 years, no one had considered the possibility that it could be caused by a kink instability, Bellan says. The two types of instabilities are so different that to see them so closely coupled was a shock. "Nobody ever thought there was a connection," he says.
What is notable is that the two instabilities occur at very different scales, the researchers say. While the coil created by the kink instability spans about 20 centimeters, the Rayleigh-Taylor instability is much smaller, making ripples just two centimeters long. Still, those smaller ripples rapidly erode the jet, forcing the electrons to flow faster and faster through a narrowing channel. "You're basically choking it off," Bellan explains. Soon, the jet breaks, causing a magnetic reconnection.
Magnetic reconnection on the sun often involves phenomena that span scales from a million meters to just a few meters. At the larger scales, the physics is relatively simple and straightforward. But at the smaller scales, the physics becomes more subtle and complex—and it is in this regime that magnetic reconnection takes place. Magnetic reconnection is also a key issue in developing thermonuclear fusion as a future energy source using plasmas in the laboratory. One of the key advances in this study, the researchers say, is being able to relate phenomena at large scales, such as the kink instability, to those at small scales, such as the Rayleigh-Taylor instability.
The researchers note that, although kink and Rayleigh-Taylor instabilities may not drive magnetic reconnection in all cases, this mechanism is a plausible explanation for at least some scenarios in nature and the lab.
More information: "Magnetic reconnection from a multiscale instability cascade." Nature, 2012.
Provided by California Institute of Technology (news : web)
Hinode Alfen waves :
http://www.nasa.gov/centers/goddard/news/topstory/2007/hinode_alfven_waves.html
An Alfven wave is a vibration of a magnetic field line that carries the charged particles in plasma along with it. "In other words, it is similar to a vibrating string with beads," says Ofman. "This type of wave was first proposed to exist in 1942 by Hannes Alfven, a Swedish scientist who won the Nobel Prize in Physics in 1970. Alfven waves were later found to exist in laboratory experiments with magnetized plasma, and in space," said Ofman.
Alfven waves can be caused by an impact to a magnetic field. In the case of the new Hinode observations, they were caused by an explosion of magnetic energy, called a solar flare, which immediately preceded the observations, according to Ofman.
"Hinode detected the Alfven waves with its Solar Optical Telescope instrument. This is a high-resolution telescope in space that is sensitive to the emission of relatively cool material that can fill coronal loops due to eruptions caused by a flare. A movie made from a sequence of images showed a clear pattern of periodic motion of coronal loops. The loops vibrated side-to-side, which is typical for an Alfven wave. The relation between the period of the vibrations and the parameters of the loop (its length, density, and temperature) further reinforced the conclusion that what we see is really an Alfven wave," said Ofman.
According to Ofman, Alfven waves could heat the solar corona by their vibrations: "As the magnetic field lines vibrate, they experience friction with the surrounding magnetized material. The friction results in heating of the corona and damping of the wave motions."
The next step to understand the sun's mysteriously hot atmosphere is to discover how much Alfven waves contribute to coronal heating, to see whether it’s the dominant force or if the other possible heating mechanisms play major roles.
May 11, 2008
20,138
1,149
It is old but interesting nevertheless :
http://sci.esa.int/science-e/www/object/index.cfm?fobjectid=40852
Magnetic reconnection is a universal process in space, playing a key role in various astrophysical phenomena such as star formation, solar explosions or the entry of solar material within the Earth's environment. Reconnection has been observed at large-scale boundaries between different plasma environments such as the boundary between Earth and the interplanetary space. Irregular behaviour of particle flows and magnetic fields, known as plasma turbulence, also occur throughout the Universe. In a turbulent plasma many small-scale boundaries can form, where models predict reconnection to occur. However, magnetic reconnection in turbulent plasma has never been directly observed before. Using measurements of the four ESA Cluster satellites, a study published this week in Nature Physics shows, for the first time, experimental evidence of magnetic reconnection in turbulent plasma. This discovery opens new perspectives to better understand the behaviour of turbulent plasmas in the Universe.
The Earth's magnetic field is our first line of defence against the permanent flow of particles coming from the Sun: the solar wind. Thanks to the Earth's magnetic field, most of this solar material gets deflected around the Earth's magnetosphere, delimited by a boundary layer called magnetopause.
Like for any other magnetized planet (Jupiter, Saturn, ...), the solar wind is in fact first decelerated from supersonic to subsonic speed by a shock wave (called the bow shock), located in front of the magnetopause. The region between the bow shock and the magnetopause is called the magnetosheath (Image 1). This region is one of the most turbulent environments in the near-Earth space, making it an open-air laboratory to study turbulence. Other environments such as the solar atmosphere or accretion disks are likely to exhibit similar behaviour, but the terrestrial magnetosheath is by far one of the few accessible places to perform in situ measurements. Characterising the properties of the magnetic turbulence in this region is of prime importance to understand its role in fundamental processes such as energy dissipation and particle acceleration.
Magnetic reconnection is a process where the energy stored in magnetic fields is converted into kinetic and thermal energy of a plasma. While magnetic reconnection has been directly observed at large-scale boundaries such as the Earth's magnetopause or in the solar wind, no observations of reconnection at small-scale boundaries (which form in a turbulent plasma) have been reported so far. In space, this requires simultaneous measurements by at least four spacecraft flying in close formation. However, models and numerical simulations have predicted this possibility.
For the first time ever, direct evidence of magnetic reconnection in turbulent plasma is reported, in this week's edition of Nature Physics. This study is based on data collected by the four satellites composing the European Space Agency (ESA) Cluster mission. On 27 March 2002, the Cluster satellites were crossing the magnetosheath with an inter-spacecraft distance of only 100 km. Reconnection was found within a very thin current sheet embedded in the turbulent plasma with a typical size of about 100 km (Image 1), a real challenge for the instruments onboard Cluster. The observations show that the turbulent plasma is accelerated and heated during the reconnection process. Moreover, this new type of small-scale reconnection seems to be associated with the acceleration of particles to energies much higher than their average energy, something which could explain, in part, the creation of high energy particles by the Sun.
"Reconnection in such an environment of irregular magnetic fields could be thought to be sporadic, but this is not the case. For this particular magnetosheath crossing, a very large number of other thin current sheets was found where reconnection is very likely to occur, a subject currently under investigation by our team," says Alessandro Retinò lead author of this study, PhD student at the Swedish Institute of Space Physics, Uppsala, Sweden.
The discovery of reconnection in turbulent plasma has significant implications for the study of laboratory and astrophysical plasmas, where both turbulence and reconnection naturally develop and thus where turbulent reconnection is very likely to occur. Possible applications range from the dissipation of magnetic energy in fusion devices on Earth to the acceleration of high energy particles in solar explosions called solar flares (Animation 1 and Image 2).
Model of magnetic fields at the Sun's surface using SOHO data from several instruments taken on 19 October 1996.
May 11, 2008
20,138
1,149
Fascinating discoveries has been done the last few years.
The plasma ejected from the sun and plasma generated by magnetic reconnection seems to be able to heat up the earth's atmosphere. The ionosphere can grow and shrink depending on how much energetic particles from the sun affect the ionosphere. I remember that i read somewhere that the satellites orbiting Earth experienced more drag and had to compensate when the CME from the sun hit the earth end of 2011.
http://www.wired.com/wiredscience/2008/12/earthbreathing/
Sun Induces Strange ‘Breathing’ of Earth’s Atmosphere
SAN FRANCISCO — New satellite observations have revealed a previously unknown rhythmic expansion and contraction of Earth’s atmosphere on a nine-day cycle.
This "breathing" corresponds to changes in the sun’s magnetic fields as it completes rotations once every 27 days, NASA and University of Colorado, Boulder, scientists said Monday at the American Geophysical Union annual meeting.
The sun’s coronal holes, seen as dark regions in the image above, direct plasma away from the sun and out into the solar system. When these particles get to the Earth, they heat the upper atmosphere, causing the outer atmosphere to expand and contract.
"What’s going on in the solar side is indeed mysterious and challenges the solar physics understanding," said Stan Solomon, a scientist at the National Center for Atmospheric Research who was not involved in the research.
The finding emphasizes the many ways that solar activity impacts the Earth — and its increasingly space-utilizing humans.
"From the Earth’s perspective, we’re in the sun’s outer atmosphere," said Jeffrey Thayer, an aerospace engineer at UC-Boulder.
The new discovery could help scientists and engineers design better satellites that account for the changing conditions in the ionosphere. Eventually, it might be possible to predict the severity of ionospheric storms and protect the world’s communication infrastructure.
The scientists used changes in the density of the Earth’s atmosphere to pinpoint this previously unknown pattern. As the atmosphere contracts or expands, it also gets more or less dense, respectively. In response to the "hills and valleys of density," satellites subtly speed up or slow down, recording those motions with on-board accelerometers. And that’s the data that allowed the scientists to back into the discovery of this new atmospheric cycle.
Solomon said that while the cycle on Earth is interesting, the really strange aspect of this work is what it says about our local star.
"What’s going on in the sun that’s causing all this?" Solomon said. "It’s not entirely clear. That part of it is quite mysterious."
May 11, 2008
20,138
1,149
A lot of fun information for those interested or just a quick easy refresh course.
Lot of pictures accompanied with explanations.
http://missionscience.nasa.gov/ems/index.html
Tour of the Electromagnetic Spectrum
Welcome to the Tour of the Electromagnetic Spectrum. This unique NASA resource on the web, in print, and with companion videos introduces electromagnetic waves, their behaviors, and how scientists visualize these data. Each region of the spectrum is described and illustrated with engaging examples of NASA science. Come and explore the amazing world beyond the visible!
There is even a handy pdf booklet. You can store this on your android phone or I phone. To read when there is no connection. Or just as a refresher...
http://missionscience.nasa.gov/ems/TourOfEMS_Booklet_Web.pdf
20,138
1,149
Voyager is getting close to flying in interstellar space...
http://phys.org/news/2012-08-fast-voyager-solar-edge.html
(Phys.org) -- Two of three key signs of changes expected to occur at the boundary of interstellar space have changed faster than at any other time in the last seven years, according to new data from NASA's Voyager 1 spacecraft.
For the last seven years, Voyager 1 has been exploring the outer layer of the bubble of charged particles the sun blows around itself. In one day, on July 28, data from Voyager 1's cosmic ray instrument showed the level of high-energy cosmic rays originating from outside our solar system jumped by five percent. During the last half of that same day, the level of lower-energy particles originating from inside our solar system dropped by half. However, in three days, the levels had recovered to near their previous levels.
A third key sign is the direction of the magnetic field, and scientists are eagerly analyzing the data to see whether that has, indeed, changed direction. Scientists expect that all three of these signs will have changed when Voyager 1 has crossed into interstellar space. A preliminary analysis of the latest magnetic field data is expected to be available in the next month.
"These are thrilling times for the Voyager team as we try to understand the quickening pace of changes as Voyager 1 approaches the edge of interstellar space," said Edward Stone, the Voyager project scientist based at the California Institute of Technology, Pasadena, Calif. "We are certainly in a new region at the edge of the solar system where things are changing rapidly. But we are not yet able to say that Voyager 1 has entered interstellar space."
The levels of high-energy cosmic ray particles have been increasing for years, but more slowly than they are now. The last jump -- of five percent -- took one week in May. The levels of lower-energy particles from inside our solar system have been slowly decreasing for the last two years. Scientists expect that the lower-energy particles will drop close to zero when Voyager 1 finally crosses into interstellar space.
"The increase and the decrease are sharper than we've seen before, but that's also what we said about the May data," Stone said. "The data are changing in ways that we didn't expect, but Voyager has always surprised us with new discoveries."
Voyager 1, which launched on Sept. 5, 1977, is 11 billion miles (18 billion kilometers) from the sun. Voyager 2, which launched on Aug. 20, 1977, is close behind, at 9.3 billion miles (15 billion kilometers) from the sun.
"Our two veteran Voyager spacecraft are hale and healthy as they near the 35th anniversary of their launch," said Suzanne Dodd, Voyager project manager based at NASA's Jet Propulsion Laboratory, Pasadena. "We know they will cross into interstellar space. It's just a question of when."
Sunny129
4,823
simply amazing...it seems pretty typical of NASA probes/satellites/observatories to continue to function well past their estimated service lives, but Voyager I & II take this concept to a whole new level. there's no way NASA expected a pair of 1977 probes to remain functional for this long! :thumbsup:
May 11, 2008
20,138
1,149
That is one of thew many reasons why i think that NASA should have a bigger budget. And also that NASA should create extra divisions to implement new technologies in existing infrastructure or replacing infrastructure nationwide and possibly globally. From third world development to state of the art space exploration. ESA in Europe should do the same. On contractual basis of course to give startups a chance. More cooperation globally. Government programs have created a lot of the technology that exist today. For example the VHDL language has been created by a US government program. The basis of the Internet. Giving startups a chance to create something by making use of their patents...
20,138
1,149
Since this is a bit of a sun / solar system / voyager thread, i might as well add this :
There has another Hyder flare appeared above the surface of the sun :
http://www.spaceweather.com/
SUN SERPENT: Amateur astronomers arpund the world are monitoring a gigantic filament of magnetism on the sun. If one end of the filament were on Earth, the other end would reach all the way to the Moon. The dimensions of the structure make it an easy target for amateur solar telescopes. Richard Fleet sends this picture from his backyard observatory in Wiltshire, England:
This filament is filled with billions of tons of plasma, yet it has remained suspended above the surface of the sun for days. Such a massive structure, buffeted as it is by winds and currents in the sun's atmosphere, is unlikely to remain stable much longer. If the filament collapses, it could crash into the surface of the sun and spark a powerful type of explosion called a Hyder flare. Amateur astronomers are encouraged to monitor developments.
When thinking of huge filaments on the sun, it is not uncommon that in ancient days (Ancient astrology and astronomy), people have assumed these magnetic filaments for dragons and evil serpents.
20,138
1,149
Some explanation about beautiful but possible worrisome effects in the sky.
Noctilucent clouds are beautiful to watch.
http://science.nasa.gov/science-news/science-at-nasa/2012/07aug_meteorsmoke/
A theory is that meteor dust is a common "seed" material where water molecules can accumulate on to form small ice crystals but also volcanic dust is a good seed material. The exhaust residu of airplanes and rockets might also very well function as a "seed" material for cloud formation. But i think this also highly depends on the altitude. Clouds also form by use of "seed" material. The process is called nucleation.
http://en.wikipedia.org/wiki/Nucleation
Astronauts on board the ISS took this picture of noctilucent clouds near the top of Earth's atmosphere on July 13, 2012 :
Random picture from a noctulent cloud, possible rocket exhaust ?
August 7, 2012: Anyone who's ever seen a noctilucent cloud or “NLC” would agree: They look alien. The electric-blue ripples and pale tendrils of NLCs reaching across the night sky resemble something from another world.
Researchers say that's not far off. A key ingredient for the mysterious clouds comes from outer space.
"We've detected bits of 'meteor smoke' imbedded in noctilucent clouds," reports James Russell of Hampton University, principal investigator of NASA's AIM mission to study the phenomenon. "This discovery supports the theory that meteor dust is the nucleating agent around which NLCs form."
A new ScienceCast video explains how "meteor smoke" seeds noctilucent clouds. Play it
Noctilucent clouds are a mystery dating back to the late 19th century. Northern sky watchers first noticed them in 1885 about two years after the eruption of Krakatoa. Ash from the Indonesian volcano caused such splendid sunsets that evening sky watching became a worldwide past time. One observer in particular, a German named T.W. Backhouse who is often credited with the discovery of NLCs, noticed something odd. He stayed outside longer than most people, long enough for the twilight to fully darken, and on some nights he saw wispy filaments glowing electric blue against the black sky. Scientists of the day figured they were some manifestation of volcanic dust.
Eventually Krakatoa’s ash settled and the sunsets faded, but strangely the noctilucent clouds didn’t go away. They’re still present today, stronger than ever. Researchers aren’t sure what role Krakatoa’s ash played in those early sightings. One thing is clear, however: The dust behind the clouds we see now is space dust.
Mark Hervig of the company GATS, Inc, led the team that found the extraterrestrial connection.
"Using AIM's Solar Occultation for Ice Experiment (SOFIE), we found that about 3% of each ice crystal in a noctilucent cloud is meteoritic," says Hervig.
The inner solar system is littered with meteoroids of all shapes and sizes--from asteroid-sized chunks of rock to microscopic specks of dust. Every day Earth scoops up tons of the material, mostly the small stuff. When meteoroids hit our atmosphere and burn up, they leave behind a haze of tiny particles suspended 70 km to 100 km above Earth's surface.
It's no coincidence that NLCs form 83 km high, squarely inside the meteor smoke zone.
Specks of meteor smoke act as gathering points where water molecules can assemble themselves into ice crystals. The process is called "nucleation."
Nucleation happens all the time in the lower atmosphere. In ordinary clouds, airborne specks of dust and even living microbes can serve as nucleation sites. Tiny ice crystals, drops of water, and snowflakes grow around these particles, falling to Earth if and when they become heavy enough.
Nucleating agents are especially important in the ethereal realm of NLCs. The clouds form at the edge of space where the air pressure is little more than vacuum. The odds of two water molecules meeting is slim, and of sticking together slimmer still.
Meteor smoke helps beat the odds. According AIM data, ice crystals can grow around meteoritic dust to sizes ranging from 20 to 70 nanometers. For comparison, cirrus clouds in the lower atmosphere where water is abundant contain crystals 10 to 100 times larger.
The small size of the ice crystals explains the clouds' blue color. Small particles tend to scatter short wavelengths of light (blue) more strongly than long wavelengths (red). So when a beam of sunlight hits an NLC, blue is the color that gets scattered down to Earth.
Meteor smoke explains much about NLCs, but a key mystery remains: Why are the clouds brightening and spreading?
In the 19th century, NLCs were confined to high latitudes—places like Canada and Scandinavia. In recent times, however, they have been spotted as far south as Colorado, Utah and Nebraska. The reason, Russell believes, is climate change. One of the greenhouse gases that has become more abundant in Earth's atmosphere since the 19th century is methane. It comes from landfills, natural gas and petroleum systems, agricultural activities, and coal mining.
It turns out that methane boosts NLCs.
Russell explains: "When methane makes its way into the upper atmosphere, it is oxidized by a complex series of reactions to form water vapor. This extra water vapor is then available to grow ice crystals for NLCs."
If this idea is correct, noctilucent clouds are a sort of "canary in a coal mine" for one of the most important greenhouse gases.
And that, says Russell, is a great reason to study them. "Noctilucent clouds might look alien, but they're telling us something very important about our own planet."
image_full
20,138
1,149
As always, spaceweather.com has some nice graphical representations of data from soho about the surface of the sun.
Very nice soho recording of a coronal mass ejection at the sun.
MAGNIFICENT ERUPTION: A filament of magnetism curling around the sun's southeastern limb erupted on August 31st, producing a coronal mass ejection (CME), a C8-class solar flare, and one of the most beautiful movies ever recorded by NASA's Solar Dynamics Observatory:
The explosion hurled a CME away from the sun traveling faster than 500 km/s (1.1 million mph). The cloud, shown here, is not heading directly toward Earth, but it could deliver a glancing blow to our planet's magnetic field on or about September 3rd. This date is preliminary and may be changed in response to more data from coronagraphs on the Solar and Heliophysics Observatory (SOHO).
Actual link to video :
http://www.spaceweather.com/images2...cent.m4v?PHPSESSID=ojidb6eg3e59f2765r2cdinrf0
And a nice perspective about blue moons.
Tonight's full Moon is the second full Moon this month. According to modern folklore, that makes it a "Blue Moon." Strange but true: Most blue moons look red, pink or gray. On rare occasions, however, the Moon can actually turn blue. A video from NASA explains how.
Usually, when very fine particles from volcanic eruptions end up in the high atmosphere, these particles may act as a color filter. Giving the light from the moon (Which is reflected sunlight) its color and in some rare occasions, this light is blue. Not much different as why the sun also seems to change color form sunset to high noon to sundown.
The atmosphere and what the atmosphere is made up of, determines the color of what color we see from space.
Explanation from the researchers of NASA :
http://www.youtube.com/watch?v=4HRKl0fa2dg
20,138
1,149
An interesting explanation about how magnetic portals are formed between the magnetic field from the sun and the magnetic field of the Earth.
Field lines become tangled and once in a while, the knot disappears and several magnetic field lines emerges between the sun and the earth.
I am wondering about it and it made me think of this :
Thus the earth and the sun are at that point the two different magnetic poles of those lines. What is of course the question is that these magnetic poles are opposite. They should be, because that is intuition ? Or could it be that in all this complex and seemingly magnetic chaos between the Earth and the Sun something could emerge that is long sought for ?
In another post in this thread it is explained that these portals occur every 8 minutes somewhere... That is also the time photons need to travel from the Sun to the Earth. That makes me wonder if magnetic field lines also propagate in the direction of the field line with the speed of light.
Well, for all interested, watch it yourself and ask the questions :
ScienceCasts: Hidden Magnetic Portals Around Earth
http://www.youtube.com/watch?v=y3_vW5yrNek
May 11, 2008
20,138
1,149
For those interested, one of "our" many means of travel will pass through the solar system next year. :p
Comet C/2012_S1 will travel through the solar system in 2013. It is expected to be bright enough to be seen with the naked eye during daytime.
http://en.wikipedia.org/wiki/C/2012_S1
http://www.tecca.com/news/2012/09/26/2013-comet-brighter-than-full-moon
the full moon. This temporary attraction, called C/2012 S1, is a comet that has likely never passed through our inner solar system before, so it's larger and more reflective than those our sun has already blasted.
C/2012 S1 won't just be bright; it'll be large enough to see without the need for binoculars or a telescope. Its brightness magnitude is expected to be -16, with the Sun by comparison being -26. Comet Hale-Bopp, seen above, was magnitude -1 when it passed through our solar system in 1997. Astronomers are predicting that C/2012 S1 will appear in the sky near the sun and horizon, so it should be fairly easy to pinpoint without a sky map. Should it contain a large amount of gas beneath its icy exterior, the comet could sprout a massive glowing tail as it nears the sun and the ice is melted away, making it even easier to see — not to mention much cooler looking.
Scientists tracking C/2012 S1 have pointed out that the comet's brightness isn't entirely guaranteed, but even if their estimates are off it should still be visible to the naked eye. That wasn't the case with Kohoutek, a comet that entered our solar system in 1973 and was expected to be brilliant in the night sky, only to disappoint because it turned out to be mostly rock and not highly reflective ice.
May 11, 2008
20,138
1,149
More and more information arises how the solar cycle variations influence our planet and the climate. As always, when multiple disciplines of science start to work together, the elaborated "grand scheme of things" becomes more clear and understandable.
You can download the pdf article after regristration here :
http://www.nap.edu/catalog.php?record_id=13519
These six images from SDO, chosen to show a representative image about every six months, track the rising level of solar activity since the mission first began to produce consistent images in May, 2010. The period of solar maximum is expected in 2013. The images were taken in the 171 Angstrom wavelength of extreme ultraviolet light.
http://phys.org/news/2013-01-solar-variability-terrestrial-climate.html
(Phys.org)—In the galactic scheme of things, the Sun is a remarkably constant star. While some stars exhibit dramatic pulsations, wildly yo-yoing in size and brightness, and sometimes even exploding, the luminosity of our own sun varies a measly 0.1% over the course of the 11-year solar cycle. There is, however, a dawning realization among researchers that even these apparently tiny variations can have a significant effect on terrestrial climate. A new report issued by the National Research Council (NRC), "The Effects of Solar Variability on Earth's Climate," lays out some of the surprisingly complex ways that solar activity can make itself felt on our planet. Understanding the sun-climate connection requires a breadth of expertise in fields such as plasma physics, solar activity, atmospheric chemistry and fluid dynamics, energetic particle physics, and even terrestrial history. No single researcher has the full range of knowledge required to solve the problem. To make progress, the NRC had to assemble dozens of experts from many fields at a single workshop. The report summarizes their combined efforts to frame the problem in a truly multi-disciplinary context. One of the participants, Greg Kopp of the Laboratory for Atmospheric and Space Physics at the University of Colorado, pointed out that while the variations in luminosity over the 11-year solar cycle amount to only a tenth of a percent of the sun's total output, such a small fraction is still important. "Even typical short term variations of 0.1% in incident irradiance exceed all other energy sources (such as natural radioactivity in Earth's core) combined," he says. Of particular importance is the sun's extreme ultraviolet (EUV) radiation, which peaks during the years around solar maximum. Within the relatively narrow band of EUV wavelengths, the sun's output varies not by a minuscule 0.1%, but by whopping factors of 10 or more. This can strongly affect the chemistry and thermal structure of the upper atmosphere. Several researchers discussed how changes in the upper atmosphere can trickle down to Earth's surface. There are many "top-down" pathways for the sun's influence. For instance, Charles Jackman of the Goddard Space Flight Center described how nitrogen oxides (NOx) created by solar energetic particles and cosmic rays in the stratosphere could reduce ozone levels by a few percent. Because ozone absorbs UV radiation, less ozone means that more UV rays from the sun would reach Earth's surface. Isaac Held of NOAA took this one step further. He described how loss of ozone in the stratosphere could alter the dynamics of the atmosphere below it. "The cooling of the polar stratosphere associated with loss of ozone increases the horizontal temperature gradient near the tropopause," he explains. "This alters the flux of angular momentum by mid-latitude eddies. [Angular momentum is important because] the angular momentum budget of the troposphere controls the surface westerlies." In other words, solar activity felt in the upper atmosphere can, through a complicated series of influences, push surface storm tracks off course. Many of the mechanisms proposed at the workshop had a Rube Goldberg-like quality. They relied on multi-step interactions between multiple layers of atmosphere and ocean, some relying on chemistry to get their work done, others leaning on thermodynamics or fluid physics. But just because something is complicated doesn't mean it's not real. Indeed, Gerald Meehl of the National Center for Atmospheric Research (NCAR) presented persuasive evidence that solar variability is leaving an imprint on climate, especially in the Pacific. According to the report, when researchers look at sea surface temperature data during sunspot peak years, the tropical Pacific shows a pronounced La Nina-like pattern, with a cooling of almost 1o C in the equatorial eastern Pacific. In addition, "there are signs of enhanced precipitation in the Pacific ITCZ (Inter-Tropical Convergence Zone ) and SPCZ (South Pacific Convergence Zone) as well as above-normal sea-level pressure in the mid-latitude North and South Pacific," correlated with peaks in the sunspot cycle.
Space-borne measurements of the total solar irradiance (TSI) show ~0.1 percent variations with solar activity on 11-year and shorter timescales.
These data have been corrected for calibration offsets between the various instruments used to measure TSI. Credit: Greg Kopp, University of Colorado
The solar cycle signals are so strong in the Pacific, that Meehl and colleagues have begun to wonder if something in the Pacific climate system is acting to amplify them. "One of the mysteries regarding Earth's climate system ... is how the relatively small fluctuations of the 11-year solar cycle can produce the magnitude of the observed climate signals in the tropical Pacific." Using supercomputer models of climate, they show that not only "top-down" but also "bottom-up" mechanisms involving atmosphere-ocean interactions are required to amplify solar forcing at the surface of the Pacific. In recent years, researchers have considered the possibility that the sun plays a role in global warming. After all, the sun is the main source of heat for our planet. The NRC report suggests, however, that the influence of solar variability is more regional than global. The Pacific region is only one example.
How incoming galactic cosmic rays and solar protons penetrate the atmosphere. SOURCE: C. Jackman, NASA Goddard Space Flight Center, “The Impact of Energetic Particle Precipitation on the Atmosphere,” presentation to the Workshop on the Effects of Solar Variability on Earth’s Climate, September 9, 2011.
Caspar Amman of NCAR noted in the report that "When Earth's radiative balance is altered, as in the case of a change in solar cycle forcing, not all locations are affected equally. The equatorial central Pacific is generally cooler, the runoff from rivers in Peru is reduced, and drier conditions affect the western USA." Raymond Bradley of UMass, who has studied historical records of solar activity imprinted by radioisotopes in tree rings and ice cores, says that regional rainfall seems to be more affected than temperature. "If there is indeed a solar effect on climate, it is manifested by changes in general circulation rather than in a direct temperature signal." This fits in with the conclusion of the IPCC and previous NRC reports that solar variability is NOT the cause of global warming over the last 50 years.
Composite averages for December-January-February for peak solar years. SOURCE: G.A. Meehl, J.M. Arblaster, K. Matthes, F. Sassi, and H. van Loon, Amplifying the Pacific climate system response to a small 11 year solar cycle forcing, Science 325:1114-1118, 200.; Credit: AAAS.
Much has been made of the probable connection between the Maunder Minimum, a 70-year deficit of sunspots in the late 17th-early 18th century, and the coldest part of the Little Ice Age, during which Europe and North America were subjected to bitterly cold winters. The mechanism for that regional cooling could have been a drop in the sun's EUV output; this is, however, speculative. Dan Lubin of the Scripps Institution of Oceanography pointed out the value of looking at sun-like stars elsewhere in the Milky Way to determine the frequency of similar grand minima. "Early estimates of grand minimum frequency in solar-type stars ranged from 10% to 30%, implying the sun's influence could be overpowering. More recent studies using data from Hipparcos (a European Space Agency astrometry satellite) and properly accounting for the metallicity of the stars, place the estimate in the range of less than 3%." This is not a large number, but it is significant.
The yearly averaged sunspot number for a period of 400 years (1610-2010). Credit: NASA Marshall Space Flight Center
Indeed, the sun could be on the threshold of a mini-Maunder event right now. Ongoing Solar Cycle 24 is the weakest in more than 50 years. Moreover, there is (controversial) evidence of a long-term weakening trend in the magnetic field strength of sunspots. Matt Penn and William Livingston of the National Solar Observatory predict that by the time Solar Cycle 25 arrives, magnetic fields on the sun will be so weak that few if any sunspots will be formed. Independent lines of research involving helioseismology and surface polar fields tend to support their conclusion. (Note: Penn and Livingston were not participants at the NRC workshop.) "If the sun really is entering an unfamiliar phase of the solar cycle, then we must redouble our efforts to understand the sun-climate link," notes Lika Guhathakurta of NASA's Living with a Star Program, which helped fund the NRC study. "The report offers some good ideas for how to get started."
This image of the Sun's upper photosphere shows bright and dark magnetic structures responsible for variations in TSI. Credit: P. Foukal, Heliophysics, Inc.
In a concluding panel discussion, the researchers identified a number of possible next steps. Foremost among them was the deployment of a radiometric imager. Devices currently used to measure total solar irradiance (TSI) reduce the entire sun to a single number: the total luminosity summed over all latitudes, longitudes, and wavelengths. This integrated value becomes a solitary point in a time series tracking the sun's output. In fact, as Peter Foukal of Heliophysics, Inc., pointed out, the situation is more complex. The sun is not a featureless ball of uniform luminosity. Instead, the solar disk is dotted by the dark cores of sunspots and splashed with bright magnetic froth known as faculae. Radiometric imaging would, essentially, map the surface of the sun and reveal the contributions of each to the sun's luminosity. Of particular interest are the faculae. While dark sunspots tend to vanish during solar minima, the bright faculae do not. This may be why paleoclimate records of sun-sensitive isotopes C-14 and Be-10 show a faint 11-year cycle at work even during the Maunder Minimum. A radiometric imager, deployed on some future space observatory, would allow researchers to develop the understanding they need to project the sun-climate link into a future of prolonged spotlessness. Some attendees stressed the need to put sun-climate data in standard formats and make them widely available for multidisciplinary study. Because the mechanisms for the sun's influence on climate are complicated, researchers from many fields will have to work together to successfully model them and compare competing results. Continued and improved collaboration between NASA, NOAA and the NSF are keys to this process. Hal Maring, a climate scientist at NASA headquarters who has studied the report, notes that "lots of interesting possibilities were suggested by the panelists. However, few, if any, have been quantified to the point that we can definitively assess their impact on climate." Hardening the possibilities into concrete, physically-complete models is a key challenge for the researchers. Finally, many participants noted the difficulty in deciphering the sun-climate link from paleoclimate records such as tree rings and ice cores. Variations in Earth's magnetic field and atmospheric circulation can affect the deposition of radioisotopes far more than actual solar activity. A better long-term record of the sun's irradiance might be encoded in the rocks and sediments of the Moon or Mars. Studying other worlds might hold the key to our own. The full report, "The Effects of Solar Variability on Earth's Climate," is available from the National Academies Press at http://www.nap.edu/catalog.php?record_id=13519
20,138
1,149
Aeronautics and astronautics Assistant Professor Sigrid Close has done interesting research.:wub:
This research is all about plasma where particles interact and produce EM radiation powerful enough to damage electronic equipment.
In the comment section, someone mentions that the Chelyabinsk meteor also caused a widespread EMP pulse causing cell phone communication to fail.
I can imagine that When the air and part of the meteor is heated up enough to form a plasma, wideband EM radiation will be generated during the explosion.
But how strong will this radiation burst be ?
Does anybody know ?
Read it all at :
http://phys.org/news/2013-02-scientist-mystery-impedes-space-exploration.html
A few excerpts :
These natural micro-meteoroids are not directly causing satellites harm. When they hit an object in space, however, they are traveling so fast that they turn into a quasi-neutral gas of ions and electrons known as plasma. That plasma, Close theorizes, has the potential to create a radio signal that can damage, and even completely shut down, the satellites they hit. The signal is an electromagnetic pulse, or EMP – similar in concept but not in size to what is generated by nuclear detonations. (Tellingly, a massive EMP knocked out cell phones when the Chelyabinsk meteoroid hit.) "Spacecraft transmit a radio signal, so they can receive one that might potentially disable them," Close said. "So our question was: Do these plasmas emit radio signals, and if so, at what frequencies and with what power?" Now, through experiments she's led at the Max Planck Institute for Nuclear Physics in Germany, Close has proof that particles that mimic space dust can indeed cause trouble. The researchers fired tiny dust particles at targets resembling satellites at speeds of 60 kilometers per second. "We found that when these particles hit, they create a plasma or quasi-neutral gas of ions and electrons, and that plasma can then emit in the radio frequency range," Close said.
These plasma-induced bursts of energy could explain mysteries like the European Space Agency's loss of its Olympus communication satellite in 1993, Close believes. "Olympus failed during the peak of a meteor shower, but they never detected a momentum transfer, which means whatever hit it wasn't big enough to be detected mechanically," she said. "And yet this multimillion-dollar spacecraft was effectively taken out." Many other satellites have also failed electronically rather than mechanically. If Close is right, her experiments point to design modifications that might lessen the damage that space dust inflicts. How the satellite is oriented in space, whether it is being heated or cooled at the time and whether it is positively or negatively charged, all appear to make a difference to whether a plasma-induced radio signal actually causes damage. "Spacecraft are being hit all the time by these particles," said Close. "So we feel like we found a smoking gun here in the sense of explaining why this doesn't always happen. And once we know what's going on, there are solutions we could implement to save billions and billions of dollars." Her next step will be to show that these effects occur in space as well as in the laboratory. To that end, Close is working with James Smith and Henry Garrett of NASA's Jet Propulsion Laboratory to design an experiment that could be anchored to the International Space Station. "The idea is to try and get hit as much as possible!" Close joked.
A second research project of Close's, for which she's received a National Science Foundation (NSF) CAREER Award for outstanding young teacher-scholars, uses ground-based radar to spot meteoroid-created atmospheric plasmas. By mapping the location, size and density of these plasmas, she's able to deduce the size and locations of the particles causing them – and thus better understand the scope of what's hitting Earth, how fast it's coming at us and where in the universe it actually originates. In a related investigation, Close and three colleagues in her department are working on an international research effort to model how space debris of all kinds gets produced and then changes over time. The project is funded by the Center of Excellence for Commercial Space Transportation at the U.S. Federal Aviation Administration, which, as space flight becomes more commercialized, could take on a responsibility for safety similar to the one it holds for regular commercial flight today. Close has also received NSF and U.S. Navy funding to research the connection between meteoroids, plasma and lightning to understand how meteoroids and other phenomena that create atmospheric plasmas might cause interruptions to satellite communications, and then to help ameliorate these interruptions. Another, newer project tackles the problem of the communications blackouts that bedevil spacecraft when they re-enter the Earth's atmosphere at hypersonic speeds.
Background information :
http://en.wikipedia.org/wiki/Sigrid_Close
http://en.wikipedia.org/wiki/2013_Russian_meteor_event
