I have a similar setup. I'm running a hitachi sata2 165gb and an old ata 66 IDE HD. Check your BIOS settings under IDE devices and the boot order is probably wrong - make sure your SATA drive is in front of your IDE drive. It seems to want to stick the IDE drive in front if you're not careful! I'm having standby issues now and might just pull the ide drive for now to see if it fixes the problem.
Originally posted by: Cohort
I need some help since you guys are using the same board I have. I installed with a 3000+ venice core amd and a hitachi 80g sata had. I am trying to use an old ata 133 drive on the system aswell for my downloads and music storage. I got xp to load fine, but when ever I reboot the system it gives me this error
disk boot failure, insert system disk and press enter.
I download software fro Hitachi to test the drive and make sure it is working, and it is according to the software.
This is all new merchandise and since I hadnt ever set up a sata drive I was wondering if any of you could guide me to fix this problem. Its been a huge pain in the neck.
