Info Upscayl CPU benchmark (much improved with recompiled DLL)
Thanks, Det0x!
Seems this is one of those "hard" benchmarks where squeezing more performance won't be easy without tinkering with the source code itself.
Did not expect this CPU to finish so quickly at only 3.56 GHz max boost and 41% overall CPU utilization.
Possibly more RAM bandwidth or AVX-512 optimization by the VS compiler could be the reason.
My 9755 uses only 4800 but 12 channels
Yeah, it's worth a try. Make sure that the NPS setting is at zero in the BIOS. Epyc performs twice as slow with NPS4.
The benchmark behaves weirdly on different systems.
On my Epyc Rome, it showed around 15 threads pegged at 100%. On Ryzen 9950X3D, it was spread over all the cores with lower CPU utilization. On the Xeon 6248R, it was again spread out over the cores, not maxing any cores at 100% as far as I could see but still managed a decent score.
What about your 128 core (2 x 64) Milan ?
I will get to building it, eventually. I want it to be fancy with AIO cooling and I found something cheap (Coolermaster TR4 cooler that is supposedly compatible with SP3 socket) but not cheap enough to get two of them at once in a single month 🙂
If TR4 looks like SP3 I am pretty sure I have used the same cooler on both. My threadrippers (ols, were 1950x I think they were) are in fact the same cooler as my early EPYC's.
Here is a pic of that system. I still have it ! @igor_kavinski
