Originally posted by: wisdomtooth
22 amps on the 12V rail is more than plenty if you don't plan to SLI two video cards.
HTH.
This is not necessarily true. Check out flexy's comment on page ONE of this Anandtech TREAD on P/S
HTH.
...If you look at the majority of generic PSUs out there that claims to be "500W", you will see that they don't put out more than 18 amps PEAK (nevermind sustained) on the 12V rail...
The PSU/mobo/CPU combo I listed is one of the tried-and-true preferred configs for HTPC builders, and they usually add something like an NVidia 6600 vid card plus multiple tuner and capture cards, as well as large HDs for storing all the PVR-recorded TV programs. 22 amps is definitely plenty.
Originally posted by: Fisher999
I REALLY like what I see. I noticed that you, liike my in my system thread over here have opted for a PCI-E based Motherboard. Have you given any thought about this EXCELLENT Asus Radeon X700 sold at NEWEGG for only $112.50 DELIVERED. I based my decision based on CURRENT pricing and benchmarks from this EXCELLENT Anandtech article over here. Pay partiular attention, if you go to the article, on the section titled "the contenders" and of course the benchmark figures. The Radeon x700 (standard) "blows away" the similarly-priced GeFORCE 6600 (standard) by a significant margin in every benchmark EXCEPT DOOM 3 ! :thumbsup:
Originally posted by: Triple B
i would also suggest the x700 by ati. i love my x800x....
I know you weren't responding to me but THANKS for agreeing about the Radeion x700 card. Today, for my new system build, I went ahead and ordered this Gigabyte Radeon X700 PCI-E videocard for $112.50 DELIVERED. I think that's hard to beat don't you??? The only card I could find at about the SAME price was a GeForce 6600 STANDARD.
For my memory I ordered this PATRIOT ! GB PACK of DDR 400 and for a Power Supply this 500 Watt Fortron Source !
I Will be installing Windows XP Media Center Edition and this ATI "XP Media Center Compatible" TV Tuner card !!!
I agree with you TOTALLY on your comment about CHAINTECH motherboards. As I will be ordering this AMD Athlon64 3000+ "Winchester" as my system's brain I of course need a socket 939 motherboard. I want to go with an nFORCE 4 mobo. I am having a problem making up my mind.
Would you be willing to read the post dated 04/25/2005 06:50 AM at this Anandtech thread and tell my what you think ???
It would be much appreciated !!!
BTW, WELCOME to the FORUM !!!
ENJOY !!!
Greg
Originally posted by: shoRunner
...your memory choice isn't bad but i'd still recommend the G.skill memory as it is cheaper and still has the tight timings.
i'd still say that the ati motherboard would be a good choice for you...
if not i'd go with the gigabyte board with the x700 card. its definately a better card than the 6600 in everything but doom.
The board is awfully small (micro ATX) and cramped - the IDE, floppy and P/S connectors are AWFULLY close together and there are only 3 other slots (Standard PCI) besides the PCI-E graphics slot.
sry i guess i should be checking to see if things are instock...
...the Fortron Blue Storm is not the best choice, not at that price. That PSU does not have active PFC and is not particularly quiet...A Seasonic S12-430 will cost you $85 at PC Alchemy, has dual rail with comparable amperages, active PFC, and is 80% efficient throughout its operating range, a MUCH better PSU than the Blue Storm for a few bucks less even....
Originally posted by: The Pentium Guy
Before I throw in my hat, I got a few questions: What's with the bold/caps/"kiddy" talk? Sorry, I had to let that out...
Here's what I'd recommend:
http://www2.newegg.com/Product/Product.asp?Item=N82E16817103935 Antec SmartPower 2.0 SP-400 ATX12V 400W $59.00
http://www2.newegg.com/Product/Product.asp?Item=N82E16813128283 Gigabyte K8N-Ultra 9 $143.00
Since your hard drive isn't NCQ (I don't think it is - sorry it's on the previous page), you could also get the ABit nforce4 motherboard
http://www2.newegg.com/Product/Product.asp?Item=N82E16813127197
I heard that was pretty stable as well.
-The Pentium Guy
I have very poor vision; that's why I use the CAPS and the BOLD. I can find no way to increase font size in the options available in these thread reply boxes. If you know of a way for me to increase my font size PLEASE let me know.
Very sorry about that, I'm sorry if I offended you.
Heh, to increase font size? Easy.
a) Increase (or decrease actually) your resolution 😉
b) In internet explorer just go to View | Text Size | Largest 🙂.
You're right about that powersupply, I guess I picked it in a hurry.
I'd go with the Seasonic that others have suggested.
Yeah, abit is known for their stability, that so called "OTES Cooling" is for their Mosfets.
The higher end board has an "OTES RAM FLOW" which is a little floater thing that blows air right into the ram.
There are several advantages to the Ultra-9 as opposed to the K8NF-9, somewhat minor anyways.
1) The pretty box 😛
2) More cables included
3) Dual BIOS
That's pretty much the only big difference between them.
The K8NF-9, like the Abit, is nforce4 as opposed to nforce4 ultra. It's missing features like ActiveArmor (Firewall) and SATA II / NCQ. Pretty much it.
Hope that helps a bit.
-The Pentium Guy
sata II will give you nothing since 7200rpm drives are no where near maxing out sata 150 or even ide...
