- Nov 28, 2000
- 2,224
- 0
- 0
Originally posted by: iamaelephant
I wouldn't put too much stock into the fuel pump idea, despite the almost unanimous vote for it so far. I would check for vacuum leaks and if nothing shows up have you injectors cleaned. First try a bottle of injector cleaner, but most likely they will need to be removed and sonic cleaned (sometimes it's cheaper to just replace them).
A faulty fuel pump would affect fuel pressure (duh) and what you're describing doesn't sound like a pressure problem. However, we need more details. If you switch the key to the "on" position and wait 20 - 30 seconds, then try to start, does it fire up quickly or is it still slow? If it's still slow, it's not your fuel pump. If this test returns a positive result (quick startup) then it could be the pump, but more likely is a leak somewhere in your fuel system. Mosy commonly this is the injectors, leaking into the manifold. This explains why you need to crank the engine a lot when cold, but not when warm. Do you get a small puff of black smoke out of the exhaust when the car does fire up?
People please, when asking car questions give all relevant details. I can't stress this enough - a problem can not be diagnosed properly without a complete picture.
As in my first post I try to leave the key on (I actually thought you had to put it on, wait 5 seconds, shut it off, put it back on for 5 seconds, cause it only injects fuel for the first few seconds...I seem to be wrong?) but it doesnt change anything. Only the first start is longer...
Ill try giving it a good 20 seconds tomorrow before work..
No black smoke at all... (at least I dont think so, I never see any through the rearview mirror)
Another question: will a deep cycle battery work for my set up? If so can I get any type? Im running out of ideas... I dont wanna buy another alternator I just changed mine and its only single output, i was thinking dual output but couldnt find any locally.... can a single output alternator power 2 batteries in a tank set up? will I kill my alternator?
Thanks again.
