Update: Suggestions for the best daily commuter/Mom-mobile
Try a Versa hatch
Huge backseat that we put our rugs into with easy in/out doors, and safer than a Fit
I would take the Fit out of those options. Bear in mind that there will be a new Fit this fall. If you can wait a bit, Honda promises that the new one will be slightly more spacious, and have a better ride.
Completely different cars. The Fit is smaller and probably more fun, the Matrix is much, much larger and more practical.
If you need the Matrix's space, maybe you should look at the scion xB and if you wanted the Fit's size, maybe you should look at the Versa and xD.
