Originally posted by: Tabb
What flavors of linux will work on Macs?
Why would you use Linux when Mac come with a perfectly good OS?Originally posted by: n0cmonkey
Yellow dog.
Mandrake had a PPC version, don't know if they still do.
Debian.
Don't know of any others off hand.
EDIT:
According to Linuxiso:
Debian, LinuxPPC, yellow dog, gentoo, mandrake
They also list Darwin, GNU-Darwin, and NetBSD (although OpenBSD and I think FreeBSD 5 also support it).
Unless you meant m68k, then I don't know (other than NetBSD/OpenBSD).
m88k is neater anyways. 😛
Debian:
Debian is one of the most advanced Linux distros available today. Debian focuses on stability and (GNU) free software. Debian has a strict Social Contract that is applied to the system. Their commitment to (GNU/not-GNU) free software is amazing, and almost unmatched in the Free/Open Source Software world. It is one of the reasons the Debian contributers deserve praise and support.
The current installer is menu driven, and often considered tough for users that are new to Linux. To make up for it, the online documentation is amazing, and should cover all issues during the install. They do admit to there being issues with the install documentation, but it has proven itself atleast adequate in the past. The installer supports atleast FTP, CDROM, hard drive, and netboot installs, but Debian relies on the user to setup most of the hardware. Initializing the driver module for the network adapter is common after installation.
There is work being done on a new installer for Debian, but this won't mention it much because it is not ready yet.
Debian focuses on stability, and not necessarily features. On the stable and testing branches of Debian, software is often an older version. Security patches are backported, so that is not necessarily a concern with using the older versions of software. These software packages have been thoroughly tested by developers and users, and are considered some of the best packages around.
Software installation is a breeze with Debian. The large package respository covers a great deal of software, and not finding a piece of software you need is the exception, not the rule. Binary software packages are in a .deb format, and can be installed through dpkg, apt, or one of the great front ends (like dselect). The package management system takes care of dependancies and restarting any services that are installed or modified. Often configuration information is gathered through the front end in use, so that can simplify things for many users. Generally the only time a reboot is necessary is when the kernel is changed, which can happen though dpkg (not done by default) or through a local compile.
Just about every Window Manager and Desktop Environment can be installed through the package management system, so there is no default GUI for Debian.
That seems to be a pretty good description of Debian. Of course, as BBWF said, it should say that it uses whatever GUI you choose. I like GNOME, myself.Originally posted by: n0cmonkey
Maybe we can use the newer version of the Slackware comment I made, since the "behind the curve" comment is easy to misinterpret. 😉
Here's something for debian. Comments please. No offence meant anywhere. I do like Debian.
And just so I don't get crap for it, the (GNU) free comment is there because there are different definitions of free depending on what part of the FOSS world you ask. I figured that, with the link, was an easy way to exlplain which free they meant. 🙂
Debian:
<snip>
Originally posted by: KF
What I meant was that the same reasoning applies for Mac users as Windows users. Mac OS is not free and open for use in source and binary, AFAIK. Sure, they used some open source, but you don't get to use theirs. (Or am I assuming?) And if you like the command line utilities, there have always been Windows/DOS translations from the unix, etc., if you want to find them.
There are hundreds of distros that will do what you asked. Some will run right out of the CD with most things that a user asked for, and at the extreme end you have to roll your own & compile everything for your box.Originally posted by: Trucker61
OK, now I am intrigued. I use my computer to web cruise, play FPS games and occasionally use MS office. which OS should I use and where can I get it?
Ok, I googled to find a site to download, it seems to be clogged up?
OK, thanks, I was able to get a download of Knoppix started with the second link. Do I open the ISO image with winrar and then burn those files to a disc and boot from my cdrom to install? the download size is 716mgs, this won't fit on a disk........
An 800 mg disk? Geez, I guess I have been playin games a bit too long, I didn't know they had em!
