zerocool84
The left is the aftermarket one I'm going to install, the right is the factory one.
Oh wow that stock one is tiny then. That aftermarket one is much better.
Had a brain fart.Yeah, but you saying there would not be need for a wastegate made no sense to me. How would an overall decrease in efficiency created by an intercooler cause it to not need to remove excess air?
Yikes.
Man I thought the stock WRX TMIC was small, that thing is tinyyyy......
Glad they took care of you though, since there was a tsb guess they couldn't try to screw you.
At speed mine can get within 5-10 degrees on a nice day, but as I slow back down from speed the efficiency obviously goes way down. If it's hot outside it can't get close though. I'm piecing together a meth kit to go on when I get back as well. Will run a 50/50 meth water mix activated at 10psi and at full pressure by 18psi.
