KK
Originally posted by: n7
As others here have tried to tell you, you really need to run @ 401 or higher.
AFAIK, all the P5Bs utilize the 1066 chipset strap till 400, & at 401, they switch to the 1600 strap, which is a lot easier on the motherboard.
I don't understand why you are having so many issues, but i too suspect RAM is the culprit.
However, make sure you have bumped up vFSB at least a notch or two (FSB Termination Voltage).
I'd set it to at least 1.3V or 1.4V for now; it can possibly be lowered later
I just helped a good friend of mine OC his P5B-E + E6300, & it was too easy really, so i am a little puzzled by the issues you're having.
I'm hoping that by sticking the memory as you have said 1-2- instead the way I have them(12--), in the same channel, that this should help it out greatly. I've fiddled with every imaginable setting and 370 is all I can do stable. I've tried that 401 setting with different voltages, no help. So once again I hope, that changing the memory around will help.
