Trinity review
Page 21 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
LOL_Wut_Axel
4,310
8
That's the same thing the AMD-nuts have been saying about all of the reviews pitting the A10 against the 45W i7 IB and even the 55W i7 IB. It just goes to show you how shitty and half-assed the reviews have been, Anandtech included.
The i3 35W SB doesn't stomp on the A10 either and the "win" isn't as clear (flat-out faster) as you made it seem. It can get pretty close and you can see that.
That I agree with 100%, but atm we're discussing hypotheticals. When comparing laptop builds there's a lot that goes into it and not just cinebench scores. When you buy a laptop you're buying the entire package and not just the CPU so it's hard to compare competing processors fairly. I think it's much easier to do that when you've got the laptops in hand and you can consider things like price, battery life, discrete GPU vs APU, etc., otherwise we're discussing hypotheticals. We don't know what OEMs will do to Trinity yet. HP has a "sleekbook" for ~$600 with the A10 which is pretty good but we don't know the exact specs/options. The i3 IB's don't even have a release date other than a rough estimation so we don't know how they'll be featured by OEMs and what the prices/options will be.
I think the only certainty is that SB/Llanos will be the best bang-for-your-buck. Some SB i5's with discrete GPUs can be had for ~$600 and Llano crossfired with dGPUs can be had for ~$500. If those get even lower they'll be an absolute steal.
Except no one here has compared anything CPU-related when it comes to the 45W i7 and 35W A10. The only thing that's been compared here is their IGPs, which is fair because the i3 and i5 will have slightly lower clocked HD 4000 graphics (which will mean 5-10% slower than i7 HD 4000). The lower-end A8 and A6 have cut-down/harvested dies and are also lower-clocked.
Abwx
11,885
4,873
Ok, so power consumption doesn't matter on desktop, but does in mobile. Gotcha.
Got anything to back up your other statements? If it was as easy as that, why would AMD leave so much performance laying on the floor?
They can easily increase perfs using higher frequencies
and no doubt that there will be 45W parts but for now
it is obvious that they are targeting thin and ultrathin
segments as per Rory Read s claims.
Wrong or right , he thinks that mobile small form factors
are the main growing market and i can only agree with him
as i had a few laptops using 35W parts and it s quite too much,
really too hot , 17 or 25W would be better , but still too
expensive generaly.
pelov
3,510
So the IB HD4000 will have a smaller performance hit than HD3000 did despite being much bigger transistor-wise and far more dependent on the L3 cache and turbo speeds?
I'm almost certain it's going to be worse than 5-10% slower than the 45W HD4000 i7's. It's 10% slower if you consider the TDP alone, never mind the hit the performance will take after having it's cache halved. I hope it's only 5-10% because then the i5's (not so much the i3's as I'd kick myself for not having CPU turbo) will be a great buy provided they stay cheap.
LOL_Wut_Axel
4,310
8
The performance hit was 5-10% with the HD 3000, too. This was already established a page ago. The penalty will be the same now because the clock speed differences are exactly the same as they were with HD 3000 and they both use the exact same architecture.
It's also already been established that having more L3 cache won't make a difference as the 3-4MB of L3 shared with the CPU is plenty given the cache is fast and more efficient than AMD's.
Using TDP as your argument is inherently wrong because of the fact that the extra 10W TDP in the i7 goes directly to power the extra transistors for the bigger quad-core die. That 10W TDP difference is because of the extra cores, not because of the slightly higher IGP Turbo speed.
pelov
3,510
It allows for more headroom in turbo (everywhere, really) so it does apply and doesn't necessarily only show itself at 4 cores 8 threads but rather whenever there's an application that can benefit from turbo. Thus a 10W difference is huge, especially for architectures that have turbo clocks on both the GPU and CPU on the same die, which is now both Trinity/IB. That 10W that the other chip doesn't have is 10W in either CPU or GPU performance or even both. That means a single thread can be tasked while the rest of that TDP goes to the GPU clocks and the 45W TDP has more headroom at any given workload. It matters.
The speed of the cache isn't the issue as that only refers to saturation. Intel can do more with less cache than AMD. That's absolutely true but that's not the point here. The point is Intel can also do more with more cache and that's what I'm getting at, especially when you've got far more graphics transistors to play with. The clock speeds have remained the same (roughly. We don't know about the i3's yet and there's bound to be more i5's) but the performance has increased drastically because it's essentially a bigger and more efficient version of the same thing. So I'm not expecting a meager 5-10% decrease in performance but a larger one than that.
- HD3000 has 114mill transistors on an SB die at 995mill for the entire chip. IB has nearly 20% more transistors and nearly all of them going to the HD4000.
Abwx
11,885
4,873
Let s look at the real numbers , not your propaganda...
45W IB 3720QM CPU 2.6G/3.6G IGP 650mhz/1250mhz.
35W IB 3612QM CPU 2.1G/3.1G IGP 650mhz/1100mhz
Unlikely that the performance penalty would be only
5/10% when going to the lower TDP part..
http://en.wikipedia.org/wiki/Ivy_Bridge_(microarchitecture)
LOL_Wut_Axel
4,310
8
Ivy Bridge isn't CPU limited, so your comments about it making a bigger difference going from the i3 to i5 to i7 with the same IGP are unfounded.
There will be a difference, but a very small one like with HD 3000.
Madpacket
2,068
326
look man, it doesn't matter anymore about needing faster CPU performance for SB or IVB. Trinity is fast enough and its GPU and battery life is what what matters for portable devices which is where AMD leads. Give it up. Intel will have to wait until haswell in order to compete with AMD.
It's funny that even with 22nm and superior fab that Intel still falls behind. AMD is now leading in the most important areas which goes to show that unlimited funds (Intel) can't help always help you win the race.
Congrats Rory, you get it.
AtenRa
14,003
3,362
Core™ i5-2520M(3MB L3) vs Core™ i7-2820QM (8MB L3)
http://www.anandtech.com/bench/Product/348?vs=327
I believe the difference in gaming is more than 5-10% ;)
Specs
http://ark.intel.com/products/52229/Intel-Core-i5-2520M-Processor-(3M-Cache-2_50-GHz)
http://ark.intel.com/products/52227/Intel-Core-i7-2820QM-Processor-(8M-Cache-2_30-GHz)
IntelUser2000
8,686
3,787
There's very little effect(if at all) on cache size for graphics performance. Whatever difference was there is reduced further with Ivy Bridge, which adds an dedicated L3 cache.
I also believe the way cache is used is fixed allocation rather than dynamic, meaning the total graphics L3 for 8MB L3 parts and 3MB parts are identical.
AtenRa
14,003
3,362
Until we see real Core i3 benchmarks we cannot know if the small dedicated L3$ helps in games.
Aug 11, 2008
10,451
642
Are you really so deluded or is this post just sarcastic? I am sure intel is really worried about how "superior" AMD is, since they (intel) only have 80+ percent of the market. I get so sick of hearing the "good enough" excuse for AMD's inferior CPU performance. You could say that HD4000 is "good enough" for graphics too, and if you want to game, add a discrete card. Even trinity is only slightly ahead in graphics and is not "good enough" to play games at decent settings.
ninaholic37
1,883
31
I agree. Why pay more for Intel when you don't have to? :D i5 and i7 laptops always seem to be $100-$200 more here, and I've always found AMD laptops ran smoother anyway (not in benchmarks but in actual real-world performance). Save your money and stop the "Intel Inside/5 stars" marketing by buying what you really need instead! Most laptop resolutions are still 1366x768 anyway.
RampantAndroid
6,591
Yeah, never understood the "I want to game with HD3000/4000/AMD APU" stuff. If I want to game, you can be darn sure I'll have a discrete card in there.
Infraction Jack
239
As a casual gamer on a budget a fast IGP is a perfect solution. The majority of people are not enthusiasts. I am currently considering an A8 based laptop for light gaming. A good $500- $600 laptop that can play all of the F2P games at a decent frame rate is good enough for most people.
hans007
20,212
18
Exactly. Especially with a budget laptop. Cant add a discrete card. And if a Trinity laptop is good enough for low end gaming for a few years while being cheap enough to replace with the Trinity successor in a few years that's generally what I'd want. You can always repurposr old laptops while buying one much more expensive machine costs much more and you only have one machine in two years
sm625
8,172
137
Not only is a 45W intel TDP chip being compared with a 35W amd TDP chip, but I have also posted data showing that intel chip uses 12 more watts (about 25% more power) when both are rated at the same TDP. So really, the 45W intel i7 notebook chip is using somewhere in the neighborhood of 50% more power than the 35W AMD A10 while gaming.
Check the data. This data has been known for quite some time, but no one really seems to grasp its significance. Not sure why. Seems pretty damn significant to me. Yet I can find no one single article that covers this in the detail it should. We have articles with benchmarks that show the increased power, but no real discussion on it.
Chiropteran
9,811
110
Hey now, power is only relevant when it's an AMD FX CPU in a desktop using more power in a very unrealistic load situation.
When it comes to laptops, power usage is unimportant.
happysmiles
340
Spot on, I think its an achievement that has been overlooked, while we might not game on battery now, if they continue improving it's going to mean a lot for multimedia down the track,
especially with more programs using GPU for processing.
Definitely time to get excited about computers again.
LOL_Wut_Axel
4,310
8
Not sure if serious.
You do realize Llano sold a small speck of what Sandy Bridge did even though it had a huge IGP advantage, right? Intel has nearly closed the IGP gap with Ivy Bridge while AMD still has a huge CPU deficiency. If the IGP mattered as much as the pro-AMD people here said then SB wouldn't have smashed Llano when it came to sales.
LOL_Wut_Axel
4,310
8
If you still don't get the memo even though it's been mentioned here many times before, the Trinity A8 will use a cut-down HD 7640G and eliminate pretty much all of AMD's IGP advantage against Intel's HD 4000 while still having a CPU that is far, far slower in comparison.
Can anyone here tell me how HD 4000 is not "good enough" when people here were parroting a year ago that Llano/HD 6620G were "perfect" for budget gaming? HD 4000=HD 6620G in performance. So is Llano now all of a sudden not "good enough" or do you just hate Intel?
pelov
3,510
The 6620G compared to a really [lousy] HD3000. The only games I can play on the HD3000 are DX9 (DX11 didnt even work) and the frames and image quality were sub par. Basically, this laptop is only good for watching videos and web browsing/reading, which is what I mainly use it for anyway but for those same tasks the Llano with on-die 6620G (would have been cheaper than my i3 too) could have done all of that + gaming and at a lower power figures and far better FPS with K10stat. I screwed the pooch buying this i3 SB.
You're right in that the 7640G won't be an upgrade over the 6620G and if I were to buy Trinity I'd make sure to buy an A10 to leverage the graphical performance over the HD4000 and Llano. The comparisons are only fair if you take into account price and release date. You can't compare an HD4000 to Llano as that was last gen hardware just as you can't compare Trinity to HD3000 because that too was last gen.
The power figures are a little wonky on the Intel chips, for sure. The SB i5 also has a very high load power consumption that bests the 35W TDP limitations and surpasses both Llano and Trinity in certain tasks, but comparing power consumption figures also requires accounting for perf-per-watt and Intel still bests AMD's Llano/Trinity in heavy compute scenarios despite the added wattage.
LOL_Wut_Axel
4,310
8
That doesn't answer my question: how is HD 4000 not good enough when it's the same speed as HD 6620G/HD 7640G, a solution which was praised a year ago for its budget gaming potential?
After all, it's people here saying that it only needs to be "good enough" because most people interested in the IGP only want to play casual and some heavy games at Medium settings and mainstream resolution (1280x720/1366x768), which both the HD 6620 and HD 4000 can handle. How is it suddenly not good enough if it's the same speed as what the pro-AMD were saying was "good enough"?
I just want to understand the reasoning behind this, even if the budget/casual gaming PC market segment is very small in relation to the overall market and therefore most people didn't care about the HD 3000 only playing games at low settings.
