You know what's amusing? After writing that post, I convinced myself to buy the TPCast simply because my love for technology couldn't hold out anymore.I do know about OpenTPCast, and due to that, I also purchased an SDHC card to install the OpenTPCast software. (I'll just leave the original card in the box in case I need it.) I also went through and bought a different router from the tested router replacement list. I might also test out a spare router that I have to see if it works, which means I can return the new one. OpenTPCast does support the mic, so we're good there. Unfortunately, it doesn't support the webcam just yet.
I actually forgot about the noisy transmitter, which might have changed my mind. I do really, really hate noisy things. If that's the case, do you usually turn off the unit when you're not using it, or does it not make noise unless it's transmitting?
The included router seems to work fine. I wouldn't bother with a different one unless you actually experience tracking issues.
The transmitter only makes noise when it's transmitting video
