cusideabelincoln
Wrong.
You do know those results are with broken Crossfire drivers for the 5870? HardOCP posted a follow-up article... go find it. And the 6900 cards have even better scaling than the 5870.
Wrong.
Wrong.
Doesn't 2 6950's run just as well as 2 580's at the high resolutions? I'd go with a pair of 6950's for under $600.
would have to apply to any 1gb card, including single 1gb gpu AMD eyefinity.560s would be fine for single monitor resolutions, but they are hopeless for surround.
You do know, the main point of my post was to refute, 560s would be fine for single monitor resolutions, but they are hopeless for surround..
You didn't have a problem with Skurges blanket statement, that is absolutely incorrect ?
Those are current dx11 games that were playable in surround on the gtx 460, never mind countless less demanding games that would play 'at fast fps' in surround.
Such as the COD's, Mafia II without AA, NFS Shift, WoW,
probably anything with adjustments except Crysis, Metro 2033.
Skurges post would have to apply to any 1gb card, including single 1gb gpu AMD eyefinity.
edit: Sorry to have taken the OP off topic :
I would go with 2 more powerful cards VS 3 less powerful.
Less problems in many areas, going that route.
2-gtx 570- 580's
To be fair it was hard to see what the point of your post was, as it consisted of a single word followed by benchmarks of unrelated hardware several months old.You do know, the main point of my post was to refute, 560s would be fine for single monitor resolutions, but they are hopeless for surround..
I don't think the 560s would be anything close to hopeless from a performance perspective, I assumed that comment stemmed from the fact that you do hit 1GB VRAM limitations with surround setups.Those are current dx11 games that were playable in surround on the gtx 460, never mind countless less demanding games that would play 'at fast fps' in surround.
At high resolutions 6970s trade blows (but ultimately end up slower) than 580s. The small performance delta is not worth the staggering price difference, especially since (at the time of this post as far as I know) 6950s can also be unlocked and run at those levels.Doesn't 2 6950's run just as well as 2 580's at the high resolutions? I'd go with a pair of 6950's for under $600.
My single word, initial response, was preceded by his single sentence in QUOTES that saidTo be fair it was hard to see what the point of your post was, as it consisted of a single word followed by benchmarks of unrelated hardware several months old.
No , your post I responded to did not. Go back and look.My quote had links with the 560s against 6870s and they were losing in every benchmark.
Crushing AMD is a tough task especially with the numbers Crossfired 6950/6970s put up, in the past this would be easy to do but these new chips are top notch when paired. If they choose GTX 580s and underclock them, I think it would not be enough to "crush" a 6990. At best it would end up with the GTX 595 being 5-10% faster but when all is said and done, it would probably be a wash.
Has anyone done any comparisons between 3x6950 vs. 2x6950? Going for 3 cards might be a waste of money unless you're getting a large performance increase over 2 cards.
I hear there are going to be 560 TI 2GB cards out too. You may also consider running three of them in SLI for around $810.
they're going to need to be 2x3gb memory, too, b/c at the ultra high settings those cards are designed for the 6990 at 2x2 would be a big advantage over 2x1.5. of course, amd might just go for a 2x4 and, um, lay the wood on NV... 😉
@OP: I'd go with the 2x580 just b/c of uncertainty about 3+ card drivers.
The hardware is related. The only way to run Nvidia surround is in sli, gtx 460's are sister cards to gtx 560's.
Both being 1gb, sorry I need to make that clear to you.No , your post I responded to did not. Go back and look.
Well, Im not sure how 3 x 6950's perform as apposed to the 580's, however perhaps 2 x 570 would be a better choice....Cheaper and quiet capable of clocking to 580 performance.I can't honestly decide. I'm going with a 3 monitor setup and the 2GB from the 6950's is an advantage but i'm scared of Amd's drivers with 3 cards. What does everyone think?
Lets see if we can gather some benches from around the web for tri SLI 570/580 and trifired 6950/6970.
Here is one on the 570s but with older drivers. From December.
http://benchmarkextreme.com/Articles/GTX 570/P1.html
Here is a Unigine 2.1 570 triSLI score. Not sure what CPU or driver version though.
I'll look for any others as well as trifire.
Something from Xtremesystems forum with Tri 6970s.
http://67.90.82.13/forums/showthread.php?t=263672
From Skurge:
http://www.xtremesystems.org/forums/...d.php?t=265548 6950 trifire
Not many games and no straight comparison between tri-fire vs SLI GTX580, but considering that the tri-fire isn't far from tri-sli, it might be useful:
http://www.hardwareheaven.com/revie...-review-3-way-crossfire-eyefinity-vs-sli.html
If you can manage the heat and noise I would go with 3x 6950.
I think we know that was when crossfire wasnt working.
http://www.hardwareheaven.com/revie...d-sli-performance-bad-company-2-surround.html
http://www.hardwareheaven.com/revie...-sli-performance-crysis-warhead-surround.html
http://www.hardwareheaven.com/revie...iew-and-sli-performance-f1-2010-surround.html
More demanding games. Show up the 560s weakness. I would rather pay the premium and get 570s, even if they have less ram.
OP, I'm in a similar situation in terms of getting new GPUs and I've decided to wait for BOTH the AMD 6990 and GTX-590/595 to be released. Once there is some solid information on those cards, I will decide on Quad SLI vs QuadFire.
The thing is, jumping in now is a bad proposition all around IMO. The GTX-580, especially in SLI, Tri-SLI, and Quad-SLI, trounce any setup out there. The AMD 6970 CrossFire, for very high resolutions (2560x1600 and above), edges out the GTX-580 SLI. However, if I were to get something TODAY, I would get GTX-580 SLI and OC them. There is no doubt about that.
Having said that, I would really wait (which I am doing LOL) for the 6990 and the 590/595 to be released before making a final decision.
