sdifox
- Sep 30, 2005
- 100,325
- 17,913
- 126
Yeah, I got it backward. It doesn't let you turn off traction control.On my Honda (current wheels lack sensors), it actually prevents you from disabling traction control? Help me understand!
You do not need a $200+ tool to program them. The tool for Fords of that era was around $15, IIRC.You need a special tool for that. Something like this.
And of course the programable sensors.
This set has 8 sensors
Sensors are fragile so having a shop do it is a safer bet.
Don't know how you are going to balance your wheel.
Granted it only does Fords (maybe Mazda too? IDK). You might find more info about the specific tool type in a Ford centric forum.
Briefly searching, that tool may not even be needed for a 5th gen explorer, only earlier generations. It looks like a '12 will relearn itself without the tool.
TPMS programming 2011 - 2015
Good evening all. I have a 15 sport and purchased blizzaks for my factory rims for winter and have ordered new rims for summer now that spring is here. Plan to buy new TPMS sensors and the programming tool to reprogram them when I flip them around 2xs a year. Can anyone tell me how to...www.explorerforum.com
You might also want to check the above linked forum for lots of other issues related to your '12 Explorer, probably one of the most informative on the 'net... if a youtube video doesn't cover what you're looking for.
Every now and then I read of someone getting one with a bad battery... just something to keep in mind.Ordered it.
Hopefully it works.
I could ask you to further explain your judgment of a Toyota SUV being too expensive to maintain. My brother and his wife dumped a perfectly good Toyota Camry because they didn't want to spend the money to fix a rear door window.I had a 2001 Toyota Highlander that I drove for about 10,000 miles over 15 years but it was becoming too expensive to maintain. Much cheaper with Ford or even older cars if you can still find the parts.
BTW as someone who has driven a 1983 Toyota Cresside, 1991 Corolla, 2001 Highlander.. the only feature that I would miss in those cars vs modern is the Back Up Camera. I don't know if it's possible to install it in older vehicles but if it is, that's worth it!
