Originally posted by: clarkkent333
I understand the value on this from a price standpoint but wouldn't it be better to spend around $100-200 extra for a lappy with a bigger hard drive, wireless, and a better overall configuration? You'd have to spend that much on upgrades anyways wouldn't you?
This Q&A probably survived unchanged from the days when USB2.0 was relatively uncommon compared with USB1.1 and Toshiba had a policy of always denoting USB2.0.Originally posted by: ActuaryTm
From the Toshiba site:Originally posted by: allisolm
Does anyone know if the USB ports are 2 or 1? I looked and can't find anything. Thanks.
"Does my Toshiba PC have USB 2.0? How to tell.
Check the Detailed specs for your Toshiba PC:
If the published specs indicate USB 2.0, then your Toshiba PC is equipped with USB 2.0 capability. If the specs don't indicate USB 2.0 (or if they don't specify), then your Toshiba PC is equipped with USB 1.1 capability."
The specifications list "3 Universial Serial Bus Ports (USB)". Unfortunately, most likely not USB 2.0 compliant.
Originally posted by: CarrotStick
The USB ports are USB 2.0. Come on now what kind of question is that? USB 1.1 has long been replaced years ago. Just look on the toshiba website. Its USB 2.0. Simple fact.
Well, not so fast. How are you so sure what "chipset" this model has?Originally posted by: CarrotStick
People People People....The laptop HAS USB 2.0.... Why? Because like all laptops the USB ports are integrated into the chipset. The chipset in this laptop has USB 2.0 ports. Very simple. There is no question. This laptop HAS USB 2.0. Simple fact.
Originally posted by: fooshkee
i work at best buy and this deal is gonna be big... so if you want one, go tomorrow... $599 for a basic laptop is great... they're also offering a 2 year psp (extended warrentry) this week for $99 which is a pretty good deal as well... the only other time i've seen a laptop under $600 was black friday...
Originally posted by: kerokeroppi82
just got mines, have to admit its pretty nice for a cheap laptop
