Siso we should see a huge increase in patriots fumbles this year?
Long term competitive advantage?
http://www.sharpfootballanalysis.co...iots-mysteriously-became-fumble-proof-in-2007
hey let's make up a number, with the help of a tiny sample set, that reinforces the outcome we already want
As a NH native and proud wearer of both "Squish the fish" and "Bury the Bears" T shirts, I am probably just a little biased toward NE, but it looks like they cheated yet again.
The sample size was over years, and fivethirtyeight researched it themselves and found the fumble rate suspicious.
http://fivethirtyeight.com/datalab/fivethirtyeight-dissects-the-deflategate-report/
That's the rebuttal I mentioned, and no, it doesn't address everything. You read past the title, right? Bickering about axis not starting at 0, questioning why you would have someone verify your work if you're an expert, and making even WORSE data manipulation errors (see below).
I actually went back and researched 5 year periods for the entire NFL over the last 25 years. The Patriots ratio of 187 plays to 1 fumble is the BEST of ANY team in the NFL for ANY 5 year span of time over the last 25 years. Not was it just the best, it wasn't close:
1. 2010-2014 Patriots: 187 plays/fumble
2. 2009-2013 Patriots: 156 plays/fumble
3. 2006-2010 Colts: 156 plays/fumble
Here, the author curiously ranks the Patriots #2 and the Colts #3, despite the fact that the teams appear to have the same number of plays per fumble (156).
OK, so he's comparing various 5 year periods. WTF is your point here again? 156 plays/fumble is simply not 187. That's a 20% difference, go ahead and plot the data points he lists, 187 is a major outlier, and he's cherry picking the best teams in 5 different 5 year periods.
As the age gap expands so does the validation. You don't compare a team in the 70s to a team in the 10s because the game changes. As you approach a single year difference it's closer, but even then it's different.
The author's conclusion why the Colts and Pats have similar numbers equally silly.
Why does this matter?
Because, Manning and Brady are generally among the quickest in football at getting rid of the ball when dropping back to throw. In fact, according to Pro Football Focus (PFF), Manning led the league in time-to-throw in 2014, at a lightning-quick 2.24 seconds. Brady finished 3rd in 2014, and also ranked 3rd, 1st, and 4th between 2011 and 2013 (PFF stats only go as far back as 2011). Even better, Brady also posted the league's lowest sack-per-dropback rate in 2014.
You heard that right. Lightning fast time to throw = less fumbles.
Wait. WHAT? Sure it helps, but ... Rushing QBs will get around 4-5 fumbles in a year, more passing oriented QBs will get about 2-4 and really good passing QBs will get around 1-2. That's a difference of about 1-2 fumbles per year for the team.
OK, so he massages the numbers a bit and comes up with this chart
AH-HA! Wait... No, NE is still an outlier, and you didn't address the main point in the original article. How did they go from such a high rate to a low one?
If we're using these text messages as evidence, then can we ask why the refs put the balls at 16 PSI, completely out of spec? The fact is no one (including the refs and by proxy the NFL) gave two shits about the PSI rule until the colts or whoever decided to whine about it. This remains a non-story. How can you all care so much about the PSI in a football, when in reality it makes little to no difference and in reality the refs didn't give a damn either.
Quoted for hilarity when punishment is handed down and flat ignorance. I don't expect heavy punishment, but it'll be there and we'll see how much of a non-story it is.
Ball pressure doesn't matter. 🙄
Remember when the NHL tested a new puck with a sensor in it that allowed the camera to "show" the puck when it was behind the wall? It weighted the same, had the same balance for all practical purposes it should have been the same. It wasn't. Players noticed the difference and because they didn't have access to the expensive pucks for practice it was killed (one of the reasons).
Everything about the ball matters. It's why most of the process is rigorously controlled from manufacturing to storage. They need to change the rules and have the refs/league handle the balls.
Then why no investigation or punishment for Indy for having 3 out of 4 balls under inflated? Why only a warning to the Vikings and Panters for heating up balls on the sidelines during a game?
http://espn.go.com/blog/minnesota-v...of-game-ball-incident-during-panthers-vikings
In addition, Brady stated that he suggested that the Patriots give the game officials a copy of Rule 2 when they delivered game balls prior to each game, so that the officials would know that it was not necessary to inflate them further.
he will appeal. how does the process work? arbitrator? no way there's enough evidence to say tom explicitly told them to under inflate. I'd guess it was more like Brady told them that he likes the balls as low as possible, maybe with a wink wink sort of agreement. eh, fuck the nfl
Pats should lose draft picks and be ineligible for the playoffs too
