Fanatical Meat
Hey guys My toilet is wobbling and leaking a small amount. I re-mounted the toilet around 7 years ago. I remember the flange (the part that bolts into the toilet) being very corroded and I think it was below the tile that was added before we purchased the home. I know that isn’t right.
I am sort of scared to do this job but I understand how it mounts much better now.
I tried to tighten the toilet but the bolt just spun around which make me think something broke and now it needs a proper fix.
Assumptions:
House was built in 1960
Last time I had the toilet off it looked like cast iron
No PVC can be seen anywhere, waste pipe is cast iron.
I saw this which is a pvc Mount that has a rubber gasket to tighten on the pipe.
I assume this is the solution I want
**above implies it is for PVC piping but it is not the label plainly says "for use with cast iron pipe"
Questions:
How difficult is it to remove a corroded flange. YouTube videos make it seem like a chisel will break it up with ease. What about the waste pipe? I fear the waste pipe could break too.
YouTube videos tend to make home repairs look far easier than they are.
I am assuming it has lead bonding the flange to the pipe does this change removal?
Bonus points what type drill bit should be used for drilling a pilot hole into tile?
@Greenman you are good with this stuff, should I call in a professional or deal with it myself?
Assumptions:
Oatey 4 in. PVC Twist-N-Set Open Toilet Flange 436512 - The Home Depot
Oatey Twist-N-Set Replacement Closet Flanges are designed to replace broken cast iron closet flanges with a gasket that expands to fit inside of service weight, heavy weight and no hub pipe. The replacement
www.homedepot.com
Questions:
