Originally posted by: bctbct
Bummer, there goes all the savings from gas milage.
Originally posted by: chuckywang
Some cars have a non-interference head such that if the timing belt does break, then the rest of the motor doesn't get damaged. Not sure about the Accord.
Originally posted by: Captante
Wow $600 is a lot of money for a timing belt ... I've never had that job done on a Honda, but my Volvo 850 cost about $375, the Camry I had before that cost about $300 for the belt & my wifes Subaru Outback was about $400.
The Accord probabyl has Vtec ro some derivitatino of VTEC and all variable timing engines are interference.
as for the replacement, you probably should do it but you'll probably be safe for a while. Aslo make sure to do the water pump with the belt, otherwise if the water pump breaks, its an even bigger pita to replace and your car is undrivable too during the time the water pump breaks to the time the water pump is repaired. Not sure but I think the accord may have plastic water pump impellers whaich make them more prone t breakage.
Originally posted by: raildogg
The guy did say that I will end up needing a new engine if it fails. I think I will go ahead and get this done in 2 weeks.
Do you think it will hold up that long?(a bit nervous)
I was looking at this ad for a 97 LHS for $650 that needed a new timing belt (non-interference head), and I asked the Dodge dealership for a quote. $800 dollars for timing belt+water pump!!!! WTF!!
Which is why they recommend replacing them when you do the timing belt. It's just good preventative maint. and since you basically have to remove the timing cover and belt to do the water pump you might as well spend the extra money and replace the water pump at the same time.
Originally posted by: n19htmare
Atleast I don't have to worry about TIming belt.... Got a timing chain in the RSX-s...... don't really need to mess with much till about 100K which i'm approaching.
It almost certainly will.
But don't go presenting ME with the bill if it doesn't.
FYI, timing belts and waterpumps and clutches aren't the easiest jobs to do yourself, but they do save you a CRAPLOAD of money, and so IMHO it's worth it. The expense isn't the parts, it's the labor to take the engine apart and put it back together.
But that really depends on how much your time is worth. I'm a cheap bastard, so...
On a DODGE? Dude, you could do it yourself for peanuts. That's the great thing about an American car...if you do your own work, the most expensive part of any job is the beer![]()
How would a FWD American car be any easier to work on than a FWD Japanese car? Or are you saying your friends would only work on American cars for beer?
Originally posted by: iamaelephant
Should be okay, manufacturers build a huge safety margin into their timing belt schedules. I've seen cars do 100,000km+ on the original, although I do not recommend that.
That's in line with other Hondas I've seen. The price to replace the timing belt on the '88 Accord I used to have was just about $600.Originally posted by: Captante
(And if you want a bad price for that, buy a 951. T-belt and water pump were $1,430.34 in parts and labor, not counting the additional $261.25 in labor required to drill out the old water pump studs which had rusted due to neglect from the previous owner.)
ZV
I didn't say anything about how easy it is to work on them...I just said that on American cars, the parts you need to get it running cost less than the beer you need to install said parts.
