Question Thought the 3060 TI was "it" but then ...
Hope so since I'm on a 12GB gpu
Same. Since I was the one who specced out these computers, it would be funny (not really) if my older brother's 3080 Ti with 12 GB has less staying power than my little brother's RX6800, even though there's about a 25-30% performance advantage for the 3080 Ti at 4K. The only saving grace for the 3080 Ti at this point is if every game my older brother plays is either 1) not a modern AAA title that gobbles VRAM, or 2) has DLSS so that it's effectively only 1440p internally.
As I mentioned in the post above, XGB with high speed asset streaming is superior to a flat XGB. The better assumption is that you will need more VRam on a graphics card in a PC, for an equal experience.
That technology is being added to DirectX so it won't matter that much in terms of console vs. PC. More specifically, it was only going to see extensive use in first or second party Sony exclusives. It's a great idea though which is why Microsoft adding it to DirectX is a big deal, but it shouldn't be anything to consider for most games.
Do games have to be designed for it or can it be added retroactively?
You could add support retroactively but unless a game is built to need it there won't be much effect. Previously you'd design around the kind of scenarios where this was necessary so you didn't get a stuttering mess.
The point of the technology was that you could design games that didn't need a big tunnel (or something like that) connecting the areas that would give the engine time to load in the new assets. If the game already has the tunnel then it doesn't really add much.
The consoles have at least 12 GB plus high speed streaming. This is superior to a flat 12 GB on the PC as you appear to be equating.
Also PCs have access to Ultra quality while consoles typically use a mix of medium/high settings. Ultra = more VRAM.
Now that the 4070 is out, it seems that one makes a ton more sense than the 3060ti I thought I wanted when I opened this thread. However, many good arugments were made here (and many, many more by the review stampede on YouTube) for the 6800XT and the 6950XT as no-brainer alternatives. Here is my question: for NON-GAMING use, what if any issues will I have with one of those two AMD cards if I go that route? I'm not into anything that taxing so I doubt I would run into any limits but I'd like to know what ones are lurking out there that I can't see due to my lack of experience.
ANY of these cards are overkill for me (currently) but I do want a capable desktop and I probably will get back into more serious gaming with a computer that can handle it (my current machine has a first gen i7 Intel CPU and a 660ti GPU). If I start working with large RAW files from a DSLR or do some drone video editing am I going to run into any debilitaing issues with an AMD card mentioned above?
Oh wow, nice job sticking on that 1st gen i7. The performance boost from moving to the latest CPUs is gonna be ridiculous.
I doubt you will notice any differences with either brand for what you are doing. I’d go with AMD to save some money if buying new.
One thing I wanna point out is both RTX 3000 and RX 6000 love undervolting. Both of them will be clocked high and their voltage will be high. Power limiting them is a nice easy way to keep them from guzzling power for no reason.
I think it depends on what you are using for video editing. My understanding is that GPU encoding is faster, but CPU encoding is higher quality. Many just use the CPU for video editing, however it can be done with GPU rendering support, depending on the application and what is supported. I am not so knowledgeable about video editing though, so maybe someone else could give a recommendation for video editing software.
you've got it right. dedicated card encoders like the new amd one with xilinx tech is the same as a video card but uses other accelerators to produce a video as close to software encoding but faster. It's the logical next step in hardware based encoding that slowly trickles down to consumer priced hardware. The new car is around 1500 bucks and it may take another 2-4 generations before we see similar tech in intel and amd cpus.
the logical reasoning of using dedicated hardware accelerators an ai algorithms is that you cut down your data rate per frame big time while maintaining a much higher quality than you'd normally get depending on the original stack and use far less power.
ai has become a buzz word but there is a market for ai. the kuwaiiti's have presented an ai model reading the news in arabic but it's not good. The voice doesn't match the person. If there is one company that can pull it off it's nvidia.
coolest stuff I've seen since then have been meta's live translation ai that reformulates the speaker's voice into the language of preference. very cool stuff. remember in the 80s how you'd go places if you knew enough japanese? this is like then now but only for the company that can develop the best hot product. ya gotta love capitalism and smart people baby!
Depends where you are. Here in Canada, the 6800XT is not such a competitive alternative, since it's almost $100 more than the 4070 for the same Raster performance (with significantly worse RT), and 6950x is a heck of lot more expensive.
But you are also comparing new gen versus previous. At similar pricing I'd be choosing for the newer generation with features like the very decent AV1 video encoder in the 4070 that is missing on older RDNA 2 cards. Also AI is becoming bigger every day so I wouldn't mind having the dedicated AI unit is the NVidia card, and finally there is DLSS 3 frame generation. I have railed against NVidia marketing of this feature because they treat it like a real native frame rate, which it isn't. But there is nothing wrong with having the feature itself. In the right circumstances most reviewers indicated it's useful feature, so it can't hurt to have it as an option.
I would consider the 6800XT, but only if it were significantly less expensive to compensate for the previous generation and all the features missing.
The big AI splash lately is obviously ChatGPT, which seems able to do anything you ask of it in the text medium. Write you an essay, or short story, check or even, write source code in the computer language of your choice. Write a script for TV show. Write your resume, etc...
But things like ChatGPT is a large model that is trained on a massive data set, you probably won't run it on your local machine, though I could see targetted versions running locally, like a programmers assistant that checks your source code, and writes common routines to lift productivity.
A lot of the generative art AT like Stable Diffusion let you run your own local version.
I would really like the extra AI HW in my next GPU.
I know what one of those services are and from my own experience trying it on a coworkers phone it's terrible.
?? ChatGPT is widely regarded as kind of amazing. Even if their are rough edges it's easy to see how this is revolutionary technology.
Many tech leaders are appealing for a pause on potentially disruptive technology:
I used it during the 2nd round. I see it's on round 4 now. I'll have to try it out one day but I'm not expecting anything remarkable. I know from reading some like it because it's more direct than googleing a question but I think most people are too daft to know how to google not people here on this forum but most people out there the average person who thinks magic goes on inside their computer. little elves and a litany of other dark forces.
It's a lot more than a google search replacement. You can literally have it write software for you, or an essay on a topic of your choosing, or fiction of under your guidance.
I play an ancient game Neverwinter Nights and someone said it could be prompted into turning out valid scripts for module creation for that.
If you feel the need to ask this question, and I say this with no malice or ill intent, don't bother exploring the AMD side and go with an Nvidia card, as you are looking for the familiar experience and safety of the brand you know. If the 4070 suits your budget, go with this SKU. It's a decent card, and even if it may run out of steam in a couple of years (in terms of VRAM), it will happen gradually and you'll probably lose RT and cruise along for a while longer, which on the AMD side would be lost even sooner.
Anything you buy that has been discussed on this thread would be able to handle your content creation needs. You can check some benchmarks here, with the caveat that your needs are more likely at the bottom of the charts than at the top (in the sense that you don't need a semi-professional setup just as you don't need a high-end gaming rig).
The CPU you are buying, whether it is the 13700K or 13600K, will have plenty of processing power for your needs. Get 32GB of RAM, maybe even 48 or 64GB if you find a great deal (but always stick with 2 DIMMs, not 4). Get a 12GB 4070. Then spend a few days combing through monitor reviews.
In the meantime we'll happily continue to argue over 4070 vs. 6800XT/6950XT, it's not like you need this thread anymore, right? So where were we... the hot topic of Large Language Models and how they eat VRAM for breakfast:
https://www.tomshardware.com/news/running-your-own-chatbot-on-a-single-gpu
Using the base models with 16-bit data, for example, the best you can do with cards that all have 24GB of VRAM — is to run the model with seven billion parameters (LLaMa-7b). That's a start, but very few home users are likely to have such a graphics card, and it runs quite poorly. Thankfully, there are other options.
Loading the model with 8-bit precision cuts the RAM requirements in half, meaning you could run LLaMa-7b with many of the best graphics cards — anything with at least 10GB VRAM could potentially suffice. Even better, loading the model with 4-bit precision halves the VRAM requirements yet again, allowing for LLaMa-13b to work on 10GB VRAM. (You'll also need a decent amount of system memory, 32GB or more most likely — that's what we used, at least.)
Getting the models isn't too difficult at least, but they can be very large. LLaMa-13b for example consists of 36.3 GiB download for the main data (opens in new tab), and then another 6.5 GiB for the pre-quantized 4-bit model (opens in new tab). Do you have a graphics card with 24GB of VRAM and 64GB of system memory? Then the 30 billion parameter model (opens in new tab) is only a 75.7 GiB download, and another 15.7 GiB for the 4-bit stuff. There's even a 65 billion parameter model, in case you have an Nvidia A100 40GB PCIe (opens in new tab) card handy, along with 128GB of system memory (well, 128GB of memory plus swap space). Hopefully the people downloading these models don't have a data cap on their internet connection.
Where is the evidence that 12GB card won't handle the bad console ports? Consoles can access more than 8GB of VRAM but they can't access more than 12GB.
Here is the Memory allocation for an XBSX:
That is 10GB of GPU optimal (IOW VRAM) and 3.5GB of regular RAM for the rest of the game.
So sure bad port with easy access to 10GB VRAM for consoles can lead to problems on 8GB cards, but not 12GB cards.
I'd bet on the 4070 easily beating the 6800 XT on top of having the normal NVidia ecosystem advantages.
Definitely worth waiting 3 days for some reviews...
I have heard there is a configuration setting for the X series X which games can use that increases the allocation for the vram pool from 10 to 13GB. I don't know any details about how it works, just heard about it from someone who used it. You'd probably never know which games are using it or not.
Only 10GB is is even of the fastest variety, and then you know the rest of the game actually needs some memory as well, so that sounds a bit sketchy.
Why? It only matters if he uses software that has specific nvidia optimizations.
The 4070 is a viable option if you're willing to spend $600, but if you can get a reduced 6950XT, 6800XT or 6800 so are they. Any of these cards are significantly faster than the 3060ti, and you can't really do a "wrong" with any of these cards if you can find them at the right price.
Because the bias is already there. If somebody comes to you for advice and then continues asking for reassurance, then they're not only asking for advice. At the end of the day the OP must be comfortable with their purchase, and sometimes the arguably better choice is the one that makes the user happier, not necessarily the objectively superior one.
As a side-note, I took a quick look at prices in my local Eastern Europe market: the 4070 is mostly matching the 6800XT in price here. AMD has very low availability for all N21 based cards. There's only one exception with a store selling a Sapphire 6950XT Nitro+ for around $60 premium over the 6800XT/4070 level. That's probably the best deal I've seen locally since Black Friday when I bought my 6800XT.
Some people don't even know if the video card play a role. I do some video and photo editing, but neither software is accelerated by nvidia, so it doesn't matter which video card is in the system. If we were to give the best advice we would need to know which software he uses, and if he uses it often.
I just checked, the 4070 and the 6950XT both can be found for around 5000DKK, which is a little less than I paid for my 6800XT in January.
Currently, the 4070 looks like the better deal long term due to fake frames giving the impression of higher fps, with the caveat that settings will have to be lowered in graphically intensive and texture heavy games. But once AMD launches FSR3 for RDNA2, the 4070 value proposition will weaken and 6800XT/6900XT/6950XT users will happily feel vindicated in their buying choice. 4070 will have higher RT performance and lower power going for it then, which may still be enough for a lot of people to sacrifice 4GB of VRAM.
