GodlessAstronomer
- Oct 27, 2007
- 17,009
- 5
- 0
Nah those people are retards that think the CDs confused speed cameras. LOLzI guess that's why some ppl have CDs in the back.
As mentioned already, flip the rear-view mirror into night mode next time.
/thread
The side mirrors are still beaming directly into your eyes (unless your mirrors are set wrong and are not actually pointing anywhere near the back of your car)
They can be factory installed and even a standard option. I find it difficult to believe they are illegal.
Probably some law issue about them installed aftermarket with improper equipment.
As Nik stated, there is more to them than just the bulb.
Even if they do buy the full assembly, the light can be functionally installed correctly, and improperly installed, which seriously impacts other drivers.
If they are installed correctly, they don't really do anything for other drivers, besides being far more visible.
I really like when they are on other cars, installed properly. You can see them clearly, but they don't appear any more bright than other lights. It's a very odd effect to describe.
And from the car the lights provide far more illumination of the ground and surrounding environment ahead. They just need to be aimed down correctly.
Lol wat? You think they emit poison photons or something? Do you get a headache when you walk around in full sunlight? Sounds like it's all in your head.
Factory built ones are properly done, and they aren't as blue.
Its the aftermarket ones you'd find at autozone or some place like that, which are really blinding. Most people don't even know how to professionally install HIDs.
Factory built ones aren't so blinding and they also adjust depending on speed.
ditto for Jersey.They're not legal. Cops just don't really enforce it (around here).
I stopped by my parents house and as I was leaving some guy was behind me with these lights for a small portion of my drive back home. During the whole drive I could barely see anything because it felt as if I stared right into the sun for half an hour without stopping.
My eyes STILL hurt and it's been about half an hour. When I close them I can still see the car. Seriously, why are these even street legal? There's no reason to have headlights that bright unless it's on a search helicopter.
/thread
You probably needed to have sped up. Sounds like you were driving too slow.
That's BS. You can't see the rest of the traffic as well, all because some fvckwad puts this shit in their car.
There should be penalties for anyone that installs this crap.
BTW, for reference, this is how an aftermarket HID retrofit SHOULD be like:
Notice the lack of extreme blue color (which is worthless for visibility anyway) and the lack of glare. Now if I stand RIGHT in front of it, then yes, I get some glare, but not bad at all. Actually less than the stock halogens.
Of course, if I crouched down into the beam then yes I'd be blinded, but I hope no car is that low
Now this is why I like the HIDs. Lights up the road very well, but in a controlled manner.
You can't see the rest of the traffic? Never used them have you? Head lights are dimmed but I can sure see the traffic behind me. Never had someone behind you with their high beams on?
That's actually not bad TBH. Guess most of the ones I see are not properly installed and aimed too high.
I'll bet they were all just sticking HID bulbs in standard reflectors.
Here is a pic of another car of the same model as mine, but running HIDs in the stock reflector housings and are 10k in color. This is probably what you've been seeing that is so annoying.
And, btw, this is the person I mentioned that insists this is "just fine"
Can't read? I said "as well."
It's not possible to see the traffic as well with the mirror flipped because you're not seeing the direct image, you're seeing a reflection of the image in the mirror. Yes, that dims headlights so that ones that are blinding are less bright, but everything in the mirror is less bright as well.
