Originally posted by: roks
Hi, All,
I just wanted to know if you guys we're able to enable/disable the wireless card from the BIOS after using the cmos hack?
I dont remember if I was able to but I just upgraded the bios from 3.08a to 3.12 and I can enable/disable the wireless card, and the Centrino logo comes up, at boot time, when the its enabled.
I can't check right now, and I also don't remember, since I never tried to switch from BIOS, I always did it from XP with Fn+F5.
But: I have seen that IBM has chosen to support a few more WLAN adapters. There are now three types of 802.11a/b/g adapters available, product #31P9701 (old Atheros chipset), and the new cheaper ones #73P4301 and #73P4302, which seem to be new Atheros chipsets (one is for U.S.A. and one for Europe with a different channel layout). They are not included in the german dealers inventories, so I have not been able to order them yet. However, there just
had to be a new BIOS enabling at least those new cards. Maybe they "lifted the ban" as well, but I doubt that.
Still no LED....I wonder if I undo the cmos hack will it work now?
I can't tell, you'd have to check (with the risk of needing to remove the card once to re-apply the fix). But you might as well get the BIOS diskette version and look for occurrences of the appropriate PCI ID strings on Matthew's page. This is not easy for those IBM-provided versions, though, since they are compressed somehow... normally, you can only investigate this after you save the BIOS in uncompressed form with the right tools.
I suppose IBM will release another version of IBM Access Connections as well to make Fn+F5 work for the new cards. If they do this, the additional PCI IDs have to be in the two files mentioned earlier in this thread as well, so you could check if also the Intel IDs are in there now.
But, again: What gives? The LED won't come on and I surely wouldn't bother trying disabling the fix with the risk of another hour of decomposing my Thinkpad. Any volunteers?
