Originally posted by: Duvie
Not a big deal if you have seen the support plates that are mounted on for 775 mobos and the plates that are standard on the 939 mobos...Those plates are there for that purpose of the torque......XP90c is a heavy biatch and this is not much greater so it should be fine..
uh no, the big typhoon would act like two/three times heavier than the XP90C because all of the weight is on the top of the heatsink, not near the base like the XP90C. Basic physics. The weight is not balanced. For example, which one would be better, a 5 pound weight on the palm of your hand, or a 3 pound weight on your fingers. Now pretend the socket is the palm of the hand...
Originally posted by: Avalon
Well, you figure if the Zalman 9500 can keep up with entry watercooling, this Big Typhoon should keep up with mid-level watercooling. Definitely not bad for air at all! It's huge, but if you can get it to fit in your system and it isn't $85 like the Zalman, this thing would rock. It seems like you could get even further benefit by adding a more powerful 120mm Panaflo to the HSF and taking off the TT fan. A little more noise for a 2500RPM Panaflo would cool a lot better.
*drool*
Hmm, I wonder how much this unit weighs? I like to keep my HSFs at 500 grams or under. It seems this wouldn't be too heavy, since the base is just pipes, and the main piece is aluminum. I wonder what makes it cool so much better than the Zalman under load? Any thoughts?
*EDIT*
$40 at Ewiz :Q
Text
Originally posted by: Elfear
Not trying to offend Duvie, don't get all worked up. I'm sure you're right that your mobo should be just fine. I was just agreeing with Unkno that weight isn't everything and that the extra height of the Big Typhoon (103mm vs. 75mm) will cause more force on the mobo than the XP-90C.
I actually had the Silent Tower pictured in my mind instead of the Big Typhoon when I mentioned the length of the moment arm. The Big Typhoon's moment arm is probably only 40-50% longer instead of the 100% like I was saying. I guess I should have looked at the pic a little closer huh.
I am not worked up I just know it wasn't twice as long, and I still dont think the top of it is as heavy as the xp-90c....I think most sckt 939 mobos have the backplate and therefore I only see issues with P4 users....
If the arm is 33% longer but the top weighs a 1/4 plus left it should be very similar. Any idea what the XP-120 is in relation to this typhoon???
Height wise it's 63mm vs. 103mm, and weight wise it's 370g vs. 813g. I'd like to see some more tests comparing the two since the XP-120 has been one of the best coolers out there for awhile. Never had much respect for Thermaltake but it looks like they have a nice cooler with the Big Typhoon.
Originally posted by: chinkgai
this hsf has been in use at xtreme systems for months and months now...most people there agree it will outdo the thermalrights, unless the thermalrights were paired with very high cfm fans, then it may even out a bit...but at the expense of noise...
if i wasnt on water, i'd definitely try this out...since i was NOT impressed with my xp120 at all
