Using this example, can we use AMD's case as an argument that large IPC gains are a thing of the past?If we look on other x86 makers. Specially AMD due to size. The IPC gains there since K8 have been very small. And that includes time where they had money.
It seems to revert to the term that people have problems accepting. The performance/watt.
Accountability of what? We're trying to have a discussion here. The only thing you've done is pulling a straw man and then when that failed you resorted to insults and personal attacks. If you've got something to add to the subject then do that instead of just derailing the thread as usual.Whatever helps you refrain from taking personal accountability.
Why is it that Intel is given a free pass?
May be the wrong person to ask, but can you say for certain that large IPC gains are no more, or are just inferring this claim based on Intel recent history of small IPC gains per generation?
Power consumption cant be driven like previous. Where CPUs from uarch to uarch could go from 20-30W to 40-50W, then 65-75W, then 95W and finally 125-140W over the years. If we extrapolate even the FX9590 would be in the low end.
The thing is that previously you paid a much less TDP penalty per frequency increase than today. E.g. in ~2 years time you could often double the frequency at only 30% or so higher TDP (given the benefit of a later node too).
Do you think Intel could produce a 4790K replacement ~2 years after it was introduced that was running at 8/8.8 GHz instead of 4/4.4 GHz? At only 30% higher TDP, so 88*1.3=114 W? I don't think so. No matter if there was much higher consumer demand for faster desktop CPUs and it was the primary focus for Intel. Not even close.
The TCO cost is also why people can find very cheap older generation Xeons as upgrades for their desktop. Compared to relatively expensive equal desktop parts.
Certainly not only Intel, but why don't add SUN and IBM to the mix? Are they improving IPC of their processors at extremely high rates or are they betting on efficiency and adding more core/threads and better interconnects for their new processors?
Power8 has significantly higher single-threaded IPC than Power7 did. I've seen tens of percent improvement myself at equivalent clock on non-synthetic loads, which is generally at least close to IBM's claims.
Can these workloads make good use of the beefier L3 and L4 caches?
Core-local cache isn't beefier in P8 - it dropped to 8MB/core from 10MB/core in P7+.
i'm not sure what effect the Centaur L4 has, but i suspect the answer is "not much." Memory latency is still pretty high.
Ignorance is a bliss? You do know if people and companies dont upgrade, Intel goes bankrupt very fast?
I don't think it's greedy at all, considering how much they've exploited populations.
It seems that some are only thinking in opposites and not being able to see a range of possibilities.
Its either Intel is purposely slowing down development or IPC gains are almost impossible to extract.
What about benign neglect due to it not being a very high priority? Just enough of a gain between generations to keep sales up but not enough to wow the customer.
If the 6700K is too underwhelming you can always pay $6000 for a 15-core Xeon. What? And I thought you called yourself an enthusiast.
Pfftt....$4859.95 buys you an 18 core beastie!
http://www.newegg.com/Product/Produ...cm_re=xeon_e5_2699-_-9SIA75M3GF8887-_-Product
http://download.sap.com/download.ep...218166335A6011727316427E851ED72C285D42D4F5BFE
Lenovo System x3950 X6, 8 processors / 144 cores / 288 threads,
Intel Xeon Processor E7-8890 v3, 2.50 GHz, 64 KB L1 cache and 256 KB L2 cache per core, 45 MB L3 cache per processor,
2048 GB main memory
Yeah, but the 15-core chip has better single-threaded performance which you need for playing Minesweeper.
On an unrelated note, I wonder why I hear of people in the forums bragging about their Titan SLI setup but I've never once heard of anyone with 12+ cores on their desktop PC.
Doesn't anyone have anything else to say about the IME?
I don't know. Perhaps you or someone else would elucidate. And how much of a performance hit do we see in AMD and Intel's ME?How does it differ from AMD's version?
