Dark Shroud
- Mar 26, 2010
- 1,576
- 1
- 0
Can anyone recommend a good site to buy those after market GPU coolers from?
Is this card really doing this?
Visiontek Radeon HD 7850 (stock 860/1200) runs at 1050/1375 with a 10% voltage decrease. I believe it will run at 15% or 20% decrease, but I didn't attempt to try because I didn't have time to stability test it. OCCT wasn't picking up any errors - was it mistaken?
I didn't feel like flashing the BIOS to push it further, either.
Uh...probably. I don't know why you are expecting one board manufacturer's BIOS to work with a board from a different manufacturer.
It depends on the voltage control chip. Some aren't voltage adjustable. The one review I found of your card was a crap review that didn't show the components. They also didn't try overvolting the review sample. Without knowing the voltage control chip we can't tell you if it can have the voltage increased.
You'd have to find a review that showed it in a hires pic.
To be honest, I'd be surprised if your card didn't use the "NCP5395T" in the first pic that doesn't offer voltage control. The CHiL chip is more costly and generally used in the more premium models and true reference designs.
because you're buying epson cartridges from a retail store. Buy hte generics mail order and you save 90%
I bought myself a XFX DD (non-black editition) HD7850. Since GPU Tweak wouldn't let me change the voltage, I flashed it with the ASUS BIOS. Now, there is a voltage slider in GPU Tweak. The problem is this: no matter how I move the slider or set the voltage numerically i GPU Tweak, the voltage readings in GPU-Z do not change. Neither does my OC potential increase. Can anyone help me out here? Is my board simply restricted to stock voltage?
Cheers!
I guess you could play with the voltage to see if the temperature changes. If no temperature change, then perhaps there is no voltage change despite what anything says.
Just picked up a MSI Power Edition 7850.
Hope its as good as the Asus I had on launch!
