Red Hawk
- Jan 1, 2011
- 3,266
- 169
- 106
Query: Is the MSI Twin Frozr 7850 with a factory overclock to 900 MHz a good purcahse at $209.99 MIR?
I'm new to overclocking and dont really know what I'm doing, what should I watch out for? do the clock speeds need to be specific numbers or just anything that is stable?
I used the asus gpu tweak tool and set the GPU to 1050mhz and memory to 5000 mhz with default voltage of 1.138v and after playing BF3 for 5 minutes the graphics driver stopped responding. is that because of temperature or low voltage?? how do people get such high clocks and low temperature.
the temperature gets really high when I'm playing, like over 80 degrees, even when the clock is merely 920+ mhz, is that normal? my room is not really cool though cuz its summer. also should i be using auto fan speed or user defined?
We need to know more. Make/model of card, make/model of PSU, case, and ambient temps? Also, what does your card run temp wise when stock?
you need to set your fan profile .
so it start running like 60 -70 % at 60c and 80% or 90% at 70 c
put you memory back to stock and only oc the gpu 25mhz mhz at a time . each time test it. then oc 25mhz more,.. lather rince repeat.
untill you find max for stock volt.
. i recommend tho just finding max oc on stock volts and getting a fan profile set up. untill you learn more about ocing.
[ i test with heaven benchmark and l4d2]
silly question but does the clock need to be in increments of multiples of 5 or any number
Check GPU Tweak's monitor while the GPU is under load and look at the voltage. I find that to be the most accurate. It is safe to run the core and memory overclocked that much at up to 1.225v. The clock speeds don't matter, the card will just crash if it's too high and after a reboot, it'll be back to stock speeds. Voltage and temperature is what kills GPU's. Just make sure you don't go over 1.225v. I've heard 1.3v being the maximum. As far as I know, no HD 7850 PCB's have temperature probes on the VRM's. Overclocking the core clock is much more significant than the memory clock. Eventually, it will get to a point where the memory and even core clock offers little to no improvement as you increase them within a stable environment.Hello guys, I have a question. I have a PowerColor PCS+7850 overclocked to 1250/5600 (didnt try more, though sure its possible), but I'm not sure what voltage it has. ASUS GPU Tweak says its 1.219, but TPU GPU-Z says its 1.098 under load in Unigine DX11 test. (ASIC is 92.5% if it has to do anything..)Which reading is true? MAX temp is 66 C. Also is it safe to run the core overclocked that much and is it safe toverclock memory since it's not cooled like the core, and I'm not really sure what temps memory has? Also seems like my FPS in the benchmark doesnt go up after 1350 (5400) memclock.
Thanks for info! Also, while "playing" with AMD control center I found a Power Control Setting slider in GPU Overdrive, after making it +10% I've got +1.5 fps in the benchmark. I've read it has smth to do with how much power card can draw before failing in extreme situation? Or maybe I didn't understand it right.. Anyway, is it safe to touch that slider or is it better left alone?![]()
