The Notebook Undervolting Guide
I used HwMonitor which has almost the same temps as RMClock.
What temperatures should my L7400 be running at (without undervolting)?
Well, my T8300 is running at 35-40C idle and 52C load. You can google for exact temps for your L7500, but I don't think it should be much higher than mn T8300.
Can't find any real temp data for the L7400 using google.
Have asked people in a lenovo forum to post their temps.
any idea what could be causing the video stuttering with RMClock?
When you set it to performance on demand, did you check ALL of the multiplier boxes? If you didn't, you are basically limiting the multi to only the ones you have chosen.
Also, have you benchmarked it in Orthos overnight to make sure it's stable at the lower voltages?
#1 Yes. all multipliers are enabled. The lowest already was set to the lowest Voltage.
#2 Ran Orthos for 2 hours. You are not supposed to run it longer on laptops (see the guide on NBR forums). It was rock stable. I do NOT get stuttering when I view the videos without RMClock but with the CPU limited through power management to the lowest multiplier. I DO get the stuttering when I have RMClock running and it is limited to the lowest multiplier (where I can not change the voltage).
Hmm that is a strange issue...I've personally never experienced that, so you should post on NBR forum or send a PM to the author of the guide flipfire about your situation.
centrino hardware control works very well also, if it works on your notebook. I have been underclocking my laptop for years, getting 4 to 5 hours of life out if it. it will also set spin down and acoustic management settings for hard drives. a very useful tool.
I got decent results from RMClock on my C2D L7500. I set everything to be 0.9v, which unfortunately is the lowest it would let me go. It was stable for 12hrs under prime95. I'm doing this under Vista. Max temp used to be 87c, now it's 72c.
Unfortunately since the processor supports low freq multiplier for super low speeds and the lowest voltage I can set in RMClock is 0.9v, it doesn't really save power when it's in superlfm mode since 0.9v is probably higher than the system uses. My power usage is slightly higher when idling now.
Hi this thread is awesome,
I have a gateway M-153Xl with a t8300 penryn
The latest version of Rm Clock does not identify my cpu, it says unknown for CPU core and Revision Name, what is wrong?
Cpu type is checked as mobile.
Thx
EDIT - Latest HMonitor gives incorrect temps, something like 5C idle for both core..
Same thing and temps for Core Temp version 0.99.5
Quote:
Originally Posted by MrM1 View Post
One other Question for all you T8300 users.
Does RightMark indicate your correct info? On the CPU info page I have
Model:
Genuine Intel(R) Core(TM) 2 Duo
CPU core ............... Unknown Core
Revision .................. Unknown
I have seen pics of RightMark testing a T9300 and it pics up the processor as Penryn no problem.
Wondering if anyone else is seeing this?
I found another person having the same prob!
Originally posted by: EarthwormJim
I wish rmclock worked with Atom processors.
i've posted two tools that are similar to rmclock but for netbooks in my sticky. eeectl tool and a1ctl. if you have an eee or acer then maybe give one of those a try
I'll try eeectl again, I didn't know it controls voltage too.
i originally thought about posting the entire description but then figured it would probably be too long to list all the things it did. i'll try to think of a way to compact the info but have more of it at the same time
I'm looking through the settings.ini (eeectl) and I only see a low or normal setting for voltage. Do the motherboards that netbooks use not have highly adjustable voltage settings?
well i've no firsthand exp using the tool, i just post info about stuff heh. sorry i cant help more than that. i do know that the chipset uses more power than the processor itself. i think the atom is 4-8w max while the chipset is 20-ish
Ah ok, I do appreciate your sticky though 🙂
