The Eternal Question...
Originally posted by: 5LiterMustang
Originally posted by: Griffinhart
Originally posted by: Wynder
I guess my hesitation with the AMD's still lies with the frequency difference and how it compares to the intels.
That seems to be a hard mindset for many to break out of. But, I went from a 2.4Ghz Intel to a 2.2 Ghz AMD (3500+) last year. And I can tell you. Mhz means nothing when talking performance. 🙂
Yeah thats pretty cool isn't it? I have tried to explain that to people, but they dont really get it.
I think it killed AMD the first time they did it (back in the late 90's) because it's all people every understood. I dream of unified rating where you can look at processor A and process B and dinifitely see what's better for rendering, crunching and business.
(wakes up)
Originally posted by: Diasper
Please read through this before you make any final decision.
Also go for 2 x 1GB RAM 🙂
Great article...
As said earlier just because something has 2mb of cache doesn't mean its a faster machine. In fact the gains seen from going over 1mb of cache are almost non existent and the gains from 512 to 1mb are only marginal. The big jump was from 256k to 512k.
It's like taking a Corvette(amd) and a mustang GT(intel) so the Ford guy puts bigger tires on his car...well once you're talking about rather large 275 width tires going to 295 doesn't make much difference and the vette is still going to be faster.
The X2 prices can only go down from here. So, down the line they will be more affordable. Plus, what will make the X2 a cheaper upgrade from the 3700+ is that it will be a chip swap and nothing else as they use the same socket. I fully expect the 4400+ X2's(basically two 3700+'s) will be in the $300 range by the end of next year.
After reading and reading (and yet more reading), I'm slowly starting to lean towards the Prescott EM64T 3.2ghz. It uses the LGA 775 socket (as do the Dual Core Intels for future upgrades), and that 2MB L2 cache keeps slapping me in the face. Since another limitation of a CPU is usually memory bandwidth, the DDR2 compatibility for the Intel boards gets me... if AMD was using DDR2, I think I'd be in a rougher situation decision-wise.
Well, it's not that the Intel set up is bad or anything. But, reviews seem to lean me towards AMD. Frankly, I think the only CPU on your list that you would be dissapointed in is the Intel Multi Core. I simply don't see you being unhappy with any of the other choices.
As far as RAM memory goes, remember AMD does not=Intel when dealing with RAM. There are a lot of mitigating factors. AMD's RAM comtroller is on the CPU Dye itself so, it gives a benefit. DDR2 is faster, but tends to have bigger latencies. Here is a review of the 3500+ http://www.techreport.com/reviews/2004q3/athlon64-3500/index.x?pg=3 That's the memory section. Keep in mind the 3500+ has half the cache of the 3700+, but, it gives a good idea of how AMD is on this front.
AMD will never offer DDR2. Instead, it looks like they are going to go straight to DDR3 with the next Socket time next year.
As for Dual Cores, in all honesty, AMD's X2's are simply in a different league over the Intel Dual Cores. I don't see this changing until Yonas and that not even too clear yet.
It's all a tough choice though. I just, strongly, suggest keeping away from the intel entry level dual core due to it's single core performance. It's likely to be little better than what you currently have for the MMOG's you currently play.
$1200 total ? Well, you could get an X2 3800+ and mobo for $461 and 2 gig of memory for $194. Thats only $1074 if I add right. You could probably squeeze in a 4200+ for that money !
Where do ya find RAM that cheap? ;p On Crucial (I don't buy generic RAM anymore...), the cheapest 2X1GB for DDR400 PC3200 is in the $280 range.
Also keep in mind that $300 of that $1200 is for the video card. 😉
Basically AMD does much more work per clock of frequency - this is sometimes called the IPC rating.
AMD's IPC rating x frequency is basically higher than Intel's lower IPC x higher frequency.
The 1Mb on the 3700 San Diego has typically shown neglible performance extra over a 512kb Venice except in the occasional thing where for example I remember reading getting as much as 18% extra in some bit of Half Life 2.
3700+ San Diego's overclock very well actually - typically 2.7ghz isn't a problem although please check at forums (here and elsewhere) eg one thread here comparing Venice to San Diego.
If you're looking to overclock very stably with low heat look to overclocking towards 2.6ghz as typically beyond that the amount of heat produced for increased frequency increases very much more rapidly - exponentially. However, even at 2.7-2.8ghz you'r probably still going to use less power/heat than Intel. Intel's Netburst chips produce so much heat they have had to introduce thermal throttling ie when it gets too hot it reduces its frequency - that's really testament to how near-sightedly designed a chip it was.
Please, if nothing else, make your decision based on what you need and what can do it best at your pricepoint, not on the amount of cache or the clockspeed or the RAM/FSB. Both of those are just attempts to cover up a much larger problem with the NetBurst architechture. If you can at all spare it, I would recommend finding a 3800+ X2, but if not, the Intel dual cores will serve you well if you are using a multi-processor capable program. The big tradeoff with Intel dual core right now is that you get a second core, but by doing so you sacrifice a lot of single threaded power. If you are dealing mostly in single thread and can't afford the X2, then get the 3700+ A64.
Edit: Mark was talking about this, which is some OCZ 2x1GB. I would hardly consider OCZ a "generic brand," but either way you lose money by buying your RAM direct from Crucial like that; very rarely does the manufacturer offer the lowest price.
Here's another thread but in it people discuss Intel vs AMD like what you want.
Now on overclocking - it's down to luck of the draw but 3700+ has been proven a great overclocking chip. Intel you may want to consider if you would want to overclock it given all the heat it produces.
CPU: $405 X2 3800+
M/B: $125 ($100AR)MSI K8N Neo4 Platinum (If you want SLI for future upgradability, you will have to save for a little)
RAM: $200 2x 1gig OCZ Value
Sound: You can use onboard due to the use of Soundblaster. However you can also look at an Audigy 2 for ~100.
HDD: $100 200Gig SATA II NCQ Spinpoint
(Also, you can look at the Seagate Barracuda's which are very nice, but slightly more expensive, and older)
Video: $345 ($330 After IR) EVGA 6800GT (You can now use EVGA's step up program and upgrade to a better card within 90days)
You now have $40 to play with. You can either save another $30 for a Soundcard, or you can invest in an SLI motherboard.
-Kevin
PC3200 newegg, 1 gig dimms OCZ value. I bet you could even beat that price if you looked a little (I'm lazy). You really need an X2 of you are running multi-threaded apps, or multitasking a lot.
Originally posted by: Gamingphreek
CPU: $405 X2 3800+
-Kevin
A very good suggestion there 🙂
The 7.1 Chaintech card I reckon could be a possibility - a slight step up in audio quality I think as it has nice clean analalogue sound although lacking some features while CPU utilisation could be lower. If you were going for an aftermarket sound card the Epox board might be a good one to go and save you a bit of money - its an excellent overclocker and a solid stable board.
Alternative is buy the new ATI chipset - look to Sapphire or DFI's efforts - DFI is already on sale here in the UK as they includes some rather good on-board audio.
Ooh related info. I read that NVidia is lowering the prices on their 6800 line very soon. 🙂
CPU: $405 X2 3800+
-Kevin
The 7.1 Chaintech card I reckon could be a possibility - a slight step up in audio quality I think as it has nice clean analalogue sound although lacking some features while CPU utilisation could be lower. If you were going for an aftermarket sound card the Epox board might be a good one to go with being an excellent overclocker and a solid stable board.
The Chaintech card is based on the Via Envy APU. While this is EXCELLENT, it is horrible for gaming. The only realy gaming cards are onboard Soundstorm (Old but very nice) and the Audigy series.
As for the ATI boards. They have always looked promising. Everytime they release a new one the same thing happens, everyone says the Nforce is going to be flattened. Nothing has happened yet. Additionally, i will never buy ULI again.
-Kevin
If going dual-core however, the extra CPU utilisation on the Chaintech should not a problem if it's willing to offload it onto the second CPU... I'm not sure if XP does that however.
So, I know this is the CPU forum, but I figure, since we've gone this far, I'll try to stretch a bit...
If I went the route of the 3700+, what's a decent motherboard to pair it up with... I'll need SATA RAID, PCI-E 16x and 4 DIMM Slots... I'm seing some SOLTEK boards, but I've never heard of them.
If the X2 and the 3700+ were both running on XP Pro with an application that didn't utilize dual core, how would they perform against each other?
If an application does not utilize more than 1 thread you will not see the slightest bit of performance increase with dual core. Ex: A venice 3500+ (2.2 ghz, 512k) will be exactly the same as the X2 4200+ (2.2 ghz, 512k).
You said you are into mmorpg development. Better check if the software you are using is multithreaded. If you arent going to overclock, soltek will be fine. If you are, get the MSI Neo 4 platinum as it has sb live, and since it has an integrated sound card, and not just intergrated sound, your performance will be alot better in games (15% more fps) due to the sound card taking the stress off the cpu.
Is that entirely true? I thought with windows XP Pro so long as he was running dual core that windows could divide the load...for example his AV and AS stuff would run on one core while his application in question ran on the other, allowing another 10 to 15% of the cpu resources to be free on that core...is that incorrect?
it wont be exactly the same, as the windows scheduler will assign other services and processes to one core whilst the other core can be dedicated to just that app (if not SMT enabled), where as a plain single core (Venice etc) will have to run every process running .. although there will still be a minor difference depends on what the individual user is running in the background
I'll check out that MB, thanks! What's the deal with SLI? Is it still just dealing with running two video cards?
Anywhere from 13-20 threads according to task manager, so I'm assuming that the X2 would afford me a bit more performance?
But I guess would it be more than I would see if I were running a single core 3700+ San Diego?
(Also on that note, any reccomendations on an X2 MB ~$120?)
X2 mb=any socket 939 mb BTW
http://www.newegg.com/Product/ProductLi...ice=120&SubCategory=22&Submit=Property
Id say either the asus a8n-e or the abit an8-ultra due to its included sound card.
The X2 is better than the PD if you are running a couple apps of cpu intensive apps, where as the PD is better when you run a ton of apps, but they aren't cpu intensive. In your case I would go with the X2 3800+ if you can afford it, as it will be great in games, and since you only plan on running a couple cpu intensive applications, not tons of little apps.
So, here are the two AMD builds that I've come up with, I'd *really* like to hear some feedback:
Base Components:
($55) Aspire X-Infinity Case/420W power supply
($299) SAPPHIRE X850PRO 256MB GDDR3 PCI Express
($128) 2x 80GB SATA Seagate Barracuda for RAID 0
($196) 2x1GB OCZ Memory
$678
Build 1:
($405) X2 3800+ Manchester
($119) ABIT AN8-ULTRA Socket 939 NVIDIA nForce4 Ultra
+ Base
$1202
Build 2:
($279) AMD Athlon 64 3700+ San Diego 1GHz FSB Socket 939 Processor
($95) REFURBISHED: MSI K8N Neo4 Platinum SLI Socket 939 NVIDIA nForce4 SLI ATX
+ Base
$1052
Keeping in mind my budget is $1200 (wife will have to suffer with me shelling out extra for shipping), which here is the better option?
PD? 🙂
