The End of Oil?
imported_Reck
1,695
Aren't vegetable based fuels actually called ethanol or something? I think it's made from corn. That's obviously not a feasible alternative either. Skoorb so what can be used to produce ethanol and hydrogen fuels? Nuclear power? We have a big enough problem with nuclear waste as it is.
Steeplerot
13,051
A bit about hemp some may not know, its better then corn with a multitude of other uses industrial ag medical etc.
http://www.masscann.org/hemp/
Fuel:
* Farming 6% of the continental U.S. acreage with biomass crops would provide all of America's energy needs. 1
* Hemp is Earth's number-one biomass resource; it is capable of producing 10 tons per acre in four months. 1
* Biomass can be converted to methane, methanol, or gasoline at a cost comparable to petroleum, and hemp is much better for the environment. Pyrolysis (charcoalizing), or biochemical composting are two methods of turning hemp into fuel.2
* Hemp can produce 10 times more methanol than corn.
* Hemp fuel burns clean. Petroleum causes acid rain due to sulfur pollution.
* The use of hemp fuel does not contribute to global warming.
Food:
* Hemp seed can be pressed into a nutritious oil, which contains the highest amount of fatty acids in the plant kingdom. Essential oils are responsible for our immune system responses, and clear the arteries of cholesterol and plaque.
* The byproduct of pressing the oil from hemp seed is high quality protein seed cake. It can be sprouted (malted) or ground and baked into cakes, breads, and casseroles. Hemp seed protein is one of mankind's finest, most complete and available-to-the-body vegetable proteins.
* Hemp seed was the world's number one wild and domestic bird seed until the 1937 Marijuana prohibition law. Four million pounds of hemp seed for songbirds were sold at retail in the U.S. in 1937. Birds will pick hemp seeds out and eat them first from a pile of mixed seed. Birds in the wild live longer and breed more with hemp seed in their diet, using the oil for the feathers and their overall health.
Fiber:
* Hemp is the oldest cultivated fiber plant in the world.
* Low-THC fiber hemp varieties developed by the French and others have been available for over 20 years. It is impossible to get high from fiber hemp. Over 600,000 acres of hemp is grown worldwide with no drug misuse problem.
* One acre of hemp can produce as much usable fiber as 4 acres of trees or two acres of cotton.
* Trees cut down to make paper take 50 to 500 years to grow, while hemp can be cultivated in as little as 100 days and can yield 4 times more paper over a 20 year period.
* Until 1883, from 75-90% of all paper in the world was made with cannabis hemp fiber including that for books, Bibles, maps, paper money, stocks and bonds, newspapers, etc. 2
* Hemp paper is longer lasting than wood pulp, stronger, acid-free, and chlorine free. (Chlorine is estimated to cause up to 10% of all Cancers.)
* Hemp paper can be recycled 7 times, wood pulp 4 times.
* If the hemp pulp paper process reported by the USDA in 1916, were legal today it would soon replace 70% of all wood paper products.
* Rag paper containing hemp fiber is the highest quality and longest lasting paper ever made. It can be torn when wet, but returns to its full strength when dry. Barring extreme conditions, rag paper remains stable for centuries.
* Hemp particle board may be up to 2 times stronger than wood particleboard and holds nails better.
* Hemp is softer, warmer, more water absorbent, has three times the tensile strength, and is many times more durable than cotton. Hemp production uses less chemicals than cotton. 2
* From 70-90% of all rope, twine, and cordage was made from hemp until 1937. 2
* A strong lustrous fiber; hemp withstands heat, mildew, insects, and is not damaged by light. Oil paintings on hemp and/or flax canvas have stayed in fine condition for centuries.
Medicine:
* Deaths from marijuana use: 0
* From 1842 through the 1880s, extremely strong marijuana (then known as cannabis extractums), hashish extracts, tinctures, and elixirs were routinely the second and third most-used medicines in America for humans (from birth through old age). These extracts were also used in veterinary medicine until the 1920s and longer. 2
* For at least 3,000 years prior to 1842 widely varying marijuana extracts (bud, leaves, roots, etc.) were the most commonly used real medicines in the world for the majority of mankind's illnesses.
* The U.S. Pharmacopoeia indicated cannabis should be used for treating such ailments as fatigue, fits of coughing, rheumatism, asthma, delirium tremens, migraine headaches, and the cramps and depressions associated with menstruation. 3
* In this century, cannabis research has demonstrated therapeutic value and complete safety in the treatment of many health problems including asthma, glaucoma, nausea, tumors, epilepsy, infection, stress, migraines, anorexia, depression, rheumatism, arthritis, and possibly herpes. 3
* Deaths from aspirin (U.S. per year): 180 - 1,000 +
* Deaths from legal drugs (U.S. per year) at doses used for prevention, diagnosis, or therapy: 106,000
Industry:
* Almost any product that can be made from wood, cotton, or petroleum (including plastics) can be made from hemp. There are more than 25,000 known uses for hemp.
* For thousands of years virtually all good paints and varnishes were made with hemp seed oil and/or linseed oil.
* Hemp stems are 80% hurds (pulp by-product after the hemp fiber is removed from the plant). Hemp hurds are 77% cellulose - a primary chemical feed stock (industrial raw material) used in the production of chemicals, plastics, and fibers. Depending on which U.S. agricultural report is correct, an acre of full grown hemp plants can sustainably provide from four to 50 or even 100 times the cellulose found in cornstalks, kenaf, or sugar cane (the planet's next highest annual cellulose plants).
* One acre of hemp produces as much cellulose fiber pulp as 4.1 acres of trees, making hemp a perfect material to replace trees for pressed board, particle board, and concrete construction molds.
* Heating and compressing plant fibers can create practical, inexpensive, fire-resistant construction materials with excellent thermal and sound-insulating qualities. These strong plant fiber construction materials could replace dry wall and wood paneling. William B. Conde of Conde's Redwood Lumber, Inc. near Eugene, Oregon, in conjunction with Washington State University (1991-1993), has demonstrated the superior strength, flexibility, and economy of hemp composite building materials compared to wood fiber, even as beams.
* Isochanvre, a rediscovered French building material made from hemp hurds mixed with lime petrifies into a mineral state and lasts for many centuries. Archeologists have found a bridge in the south of France from the Merovingian period (500-751 A.D.), built with this process.
* Hemp has been used throughout history for carpet backing. Hemp fiber has potential in the manufacture of strong, rot resistant carpeting - eliminating the poisonous fumes of burning synthetic materials in a house or commercial fire, along with allergic reactions associated with new synthetic carpeting.
* Plastic plumbing pipe (PVC pipes) can be manufactured using renewable hemp cellulose as the chemical feed stocks, replacing non-renewable coal or petroleum based chemical feed stocks.
* In 1941 Henry Ford built a plastic car made of fiber from hemp and wheat straw. Hemp plastic is biodegradable, synthetic plastic is not.
StageLeft
70,150
Yes, nuclear power, and nuclear power is going to be an increasingly used source of our energy. Dealing with comparitively small amounts of nuclear waste is much easier than dealing with gobs and gobs of oil, which is expensive, needs to be imported, and invariably affects the environment.
rahvin
8,475
Originally posted by: tss4
Does anybody know how much the price of gas has to increase in order for coal liquification to be profitable? It would give us an idea of the upper end of gas price increases (even under the worst case scenario- all oil runs out). In some ways, running out of oil may be a good thing for us. We will still have coal and can export it.
Gas and oil prices are only marginally connected right now because gas is supply constrained due to refiner limitations. Although the price of oil does determine the base starting point the biggest factor in gas prices right now is the limited production capacity of refined gasoline.
And as others mentioned, how the hell does this relate to MIT and even if it did MIT is an institution, the individual professors are what matters and everyone mentioned in that article isn't from MIT. The reality is that oil supplies wouldn't be pumping at the maximum right now if India and china weren't fully into the process of industrialization. Proclamations of the vision of some long dead scientist are meaningless given his complete lack of understanding of the global economy and the relative low numbers his predictions made in the 60's.
There is something you all need to keep in mind, had the dollar not corrected, oil prices would have likely remained unchanged. There has been an approximate drop in value in the dollar of around 30% and that is only a few percent off the increase in price of oil. Oil as a commodity remained priced essentially the same, the US just pays more for it because the dollar dropped. Because the Euro offered greater currency stability the europeans have not experienced any significant increases in oil prices.
Acanthus
19,915
ostif.org
At $2.50 a gallon youd have to drive over 175k miles to break even on a hybrid accord over a base accord...
Not to mention those batteries need replaced at some point and will cost a ton im sure.
glorifiedg790
Banned
Mar 29, 2005
301
I am 17, there will be enough oil/coal left until I am about 60. My guess is that hydrogen will power the cars of the future, emitting only water, only problem is separating hydrgen from H2O requires electricity which requires coal, so an efficent way for separating hydrogen and oxygen is needed. Hydrogen engines are already developed. Toyota made a prototype already.
biostud
19,951
7,049
Originally posted by: dmcowen674
Originally posted by: biostud
Most of the cars in brazil runs on alcohol or gasoline/alchol combo cars.
The Gas stations were converted in some way???
I heard it should be really confusing to use them (The report was from a science program on national radio over here) You can get gasoline, gasoline spiced with alcohol, pure alcohol, diesel, bio diesel or something like that. There was another South american country who did this as well. They got the alcohol from sugarcanes, so they kinda didn't care about the high oil prices.
dannybin1742
2,335
Because 15 years ago we failed to begin developing the new energy sources and technologies we need now, Deffeyes argues, in the immediate future we?ll have to rely on what we?ve got. In Beyond Oil, he examines how we might optimize the use of our geologically derived energy sources.
Good. The faster it runs out, the faster the world will work to discover alternatives. Oil is going to run out....probably SOONER than later. Just imagine what $200,000,000,000 could have done to help alternative research.
yes but with no government funding to do this we are kinda stuck, there are plenty of bright minds in the US, but this administration is unwilling to give a generous enough budget to do alternative fuel research because of the money that flows into the government from the energy industry, and both parties are on the take........
let us also not forget that petroleum is not just used for gas, but for any type of plastic too, so those prices will invariably rise
phantom309
2,065
Fuel:
Food:
Fiber:
Medicine:
Industry:
It doesn't matter how many ways you silly hippies try to rationalize it. They'll never legalize pot in the U.S.
alent1234
3,915
just imagine if everyone burned hemp for heat in their fireplaces intstead of oil. you would have half the country getting high at the same time
Tab
12,145
Fuel:
Food:
Fiber:
Medicine:
Industry:
So true, and they already do have legal hemp farms.
Steeplerot
13,051
thats funny I can count 5 stores to buy pot (and smoke it) within a few blocks of my house and they advertise eighths of weed on the covers of the little newspapers like thrifty nickel.
Last I heard SF alone has 33 cannabis clubs and counting.
sorry you live in such a backward place, welcome to the 21st century.
BTW sad such a hateful person uses such a great man's song title for a username too.
Johnny Cash would be rolling in his grave if you mattered or had a clue about what you were talking about.
cquark
1,741
Originally posted by: StormRider
Is there any way to use vegetable oil as fuel? We have tons of corn that can produce vegetable oil....
You can, but we also use a lot of petroleum to produce the corn, as synthetic fertilizers are based on petroleum.
charrison
17,033
Originally posted by: cquark
Originally posted by: OS
Originally posted by: SuperTool
I am guessing we'll still be using oil for plastics and things like that even if we find some other source of fuel.
We also need petroleum products to produce synthetic fertilizers to grow food. Even without reductions in petroleum use, world food production has declined in recent years, due to suburban sprawl in the West, urbanization in China, and so forth.
Oil can still be synthesized even if it's not drilled from the ground. The article alludes to this, but basically the germans made oil from coal during WW2.
Pulling numbers from my ass, I figure at $6 or $7 a gallon, synthetic gasoline is commercially viable.
I've seen large scale coal liquefaction estimates for the cost of producing a barrel of oil lower than $50/barrel and production of oil from CO2 + H20 using nuclear power below $100/barrel, so it should be economic well below $6 a gallon, though it will take some time to build enough production plants to do so.
I posted an article in the other oil thread about shale to oil process to generate oil at $10/barrel.
FlyLice
Banned
Jan 19, 2005
1,680
and if we can't invent an alternative we're fct?
dmcowen674
54,889
47
www.alienbabeltech.com
China Vs U.S. over Oil will end Civilization
End of Oil Could Fuel 'End of Civilization as We Know It'
The most dire and perhaps speculative forecast calls for global oil production to peak next year -- specifically on Thanksgiving.
The consequences will be grave: huge inflation, global resource wars -- China vs. the United States was emphasized as a possibility -- and the end of civilization as we know it.
U.S. peaked already
The argument stretches back to a 1956 prediction by M. King Hubbert that oil production in the lower 48 U.S. states would peak in the early 1970s.
He was right.
The United States now imports nearly 60 percent of the oil it uses.
Meanwhile, other countries are beginning to clamor for oil at unprecedented rates, and therein lies the recipe for potential disaster.
China uses a comparatively modest 1.5 billion barrels a year (perhaps 2.4 billion this year) according to some estimates. India consumes less. Both countries' economies are becoming increasingly dependent on oil
Yet China's own production has been flat since the 1980s and it now imports 40 percent of what it needs.
'When do we panic?'
"What matters in the short term is, when do we panic?" Nur said. "In my opinion, the point of panic has already taken place."
It's a behind-the-scenes sort of panic. The two largest economies on Earth -- China and the United States -- have already incorporated the finite nature of oil into their national security policies
The war in Iraq, a country second only to politically unstable Saudi Arabia in oil reserves, is another clue, he said.
"Civilization as we know it will come to an end sometime this century, when the fuel runs out," Goodstein said, adding that "I certainly hope my prediction is wrong."
Diasper
709
I've read up a little about this a while back. The energy problem can be overcome by completely refocusing the production and use of energy. Oil a comibantion of renewaable and non-renewable will be able bridge the growing deficit. At the same time energy savings everywhere, from industry to homes to cars. Given oil's so many diverse and critical uses in many all forms of production and subtances (plastics anyone?), it always seemed a shame to be burning it in a primative combustion engine.
Think about it: if you saved energy by a more economical car, you could undoubtedly over time the amount saved could be sold for a huge sum - that's if inflation hasn't nagated the use of money. Nevertheless, inflation due to shortage of a resource means the price inflation of the resource will be greater than the general inflation. Of course ultimately, it'll be the speculators and oil cartels making the real money this way.
Interesting stuff I've read is China's development of small-scale nuclear powerplants using helium as opposed to water, which if they can solve the containment of it such that the small particles of helium do not escape, would be much safer (nnowhere near as hot) and more environmentally friendly (no pumping into the rivers) than using water.
Question: is there any historical precident for a major resource running out? ie resource wars of a significant nature in the past? I just hope our economy is globalised enough at this point to ensure world peace. Problem is some countries like China are less integrated and have their own strong and independent ideology.
kage69
31,438
47,802
The stone age did not end because we ran out of stones....
Your analogies really need work. Stone isn't, and never was, a valuable commodity like oil.
Ozoned
5,578
What country has the largest shale oil reserves?
Canada? China? Soviet union?
Nope.
United States Of America
It is estimated that nearly 62% of the world?s potentially recoverable oil shale resources are concentrated in the USA. The largest of the deposits is found in the 42 700 km2 Eocene Green River formation in north-western Colorado, north-eastern Utah and south-western Wyoming. The richest and most easily recoverable deposits are located in the Piceance Creek Basin in western Colorado and the Uinta Basin in eastern Utah. The shale oil can be extracted by surface and in-situ methods of retorting: depending upon the methods of mining and processing used, as much as one-third or more of this resource might be recoverable. There are also the Devonian-Mississippian black shales in the eastern United States.
Data reported for the present Survey indicate the vastness of US oil shale resources: the proved amount of shale in place is put at 3 340 billion tonnes, with a shale oil content of 242 billion tonnes, of which about 89% is located in the Green River deposits and 11% in the Devonian black shales. Recoverable reserves of shale oil are estimated to be within the range of 60-80 billion tonnes, with additional resources put at 62 billion tonnes.
Oil distilled from shale was burnt and used horticulturally in the second half of the 19th century in Utah and Colorado but very little development occurred at that time. It was not until the early 1900?s that the deposits were first studied in detail by USGS and the government established the Naval Petroleum and Oil Shale Reserves, that for much of the 20th century served as a contingency source of fuel for the nation?s military. These properties were originally envisioned as a way to provide a reserve supply of oil to fuel US naval vessels.
Oil shale development had always been on a small scale but the project that was to represent the greatest development of the shale deposits was begun immediately after World War II in 1946 - the US Bureau of Mines established the Anvils Point oil shale demonstration project in Colorado. However, processing plants had been small and the cost of production high. It was not until the USA had become a net oil importer, together with the oil crises of 1973 and 1979, that interest in oil shale was reawakened.
In the latter part of the 20th century military fuel needs changed and the strategic value of the shale reserves began to diminish. In the 1970?s ways to maximise domestic oil supplies were devised and the oil shale fields were opened up for commercial production. Oil companies led the investigations: leases were obtained and consolidated but one-by-one these organisations gave up their oil shale interests. Unocal was the last to do so in 1991.
Recoverable resources of shale oil from the marine black shales in the eastern United States were estimated in 1980 to exceed 400 billion barrels. These deposits differ significantly in chemical and mineralogical composition from Green River oil shale. Owing to its lower H:C ratio, the organic matter in eastern oil shale yields only about one-third as much oil as Green River oil shale, as determined by conventional Fischer assay analyses. However, when retorted in a hydrogen atmosphere, the oil yield of eastern oil shale increases by as much as 2.0-2.5 times the Fischer assay yield.
Green River oil shale contains abundant carbonate minerals including dolomite, nahcolite, and dawsonite. The latter two minerals have potential by-product value for their soda ash and alumina content, respectively. The eastern oil shales are low in carbonate content but contain notable quantities of metals, including uranium, vanadium, molybdenum, and others which could add significant by-product value to these deposits.
All field operations have ceased and at the present time shale oil is not being produced in the USA. Large-scale commercial production of oil shale is not anticipated before the second or third decade of the 21st century.
Got oil? :laugh: :laugh: :laugh:
