Originally posted by: Fineghal
I would just like to point out that if we had zero inflation, the unemployment rate would probably be in excess of 10%.
It's called a phillips curve. Tis an economic expression of the phrase "No free lunch."
And as to deteriorating wages... Yeah right. You want to know WHY the purchasing power of the minimum wage has decreased? Ta da! Inflation! So you're correct. If you want to kvetch about it, take that up with congress. That ball is in THEIR court.
Further, your 1913 theory is absolutely made of tin foil. The reason the U.S. doesn't have a recorded inflation rate pre 1913? Because no one has calculated it!
Inflation is a measure of how much it costs you to get a certain number of goods at a certain price. This is your base year. The Fed's current base year is 1988 or so. What you then do to determine inflation rate is compare this previously determined basket to to another year.
Example: In the base year, 1988, I bought 20 tires at $3500, 100 apples at $22 etc. I then compare how much it would cost me to get the same number of items in a different year. In 1950 it might cost $2300 and $21.
Do you understand how this makes any type of calculated inflation from beyond a certain time period pointless? Do you really want to compare the price of apples and tires in 1913 when the car had only been invented 10 years earlier?
Further the standard CPI (Consumer Price Index), which I generally outlined above tends to OVER-state inflation. For two reasons. The first is that quality of goods tends to go up. The second is that it doesn't take into account substitute goods. If the price of apples goes up, you buy oranges no?
And as a final point: Inflation is not BAD. It only becomes an issue when it gets too high.
Oh and if you REALLY want to complain about something, complain next time you get a raise that only matches inflation. Why? Because while your raise matched inflation, it didn't account for growth in the GDP. So while your pay (adjusted) remains the same, the actual percentage of the pie (GDP) you get actually shrank.
