Originally posted by: Chryso
Looks like the refill is about $5.
I would bet you could just mix water with a little bleach to refill it though.
Originally posted by: Shame
What a great anniversary gift! 😛
Hmm...if they're that cheap and actually work decently that's pretty much a no-brainer for a lazy bastard? like me.Originally posted by: spidey07
I think I've seen them on special for 20-25 bucks.
Originally posted by: Howard
Is it battery powered?
Probably, it'd be better if it used water-power from the shower head...
If it were powered by the pressure of the water line it would require new plumbing. How would you route the water from the shower head to the device?Originally posted by: Shame
Wouldn't that require the shower being on?
And that's a problem how? I mean, sure it takes away <---> much of the "set it and forget it" factor, but like I said it'd work a LOT better. Pressure-batteries for the win.Wouldn't that require the shower being on?
K.I.S.S.
edit:And that's a problem how? I mean, sure it takes away <---> much of the "set it and forget it" factor, but like I said it'd work a LOT better. Pressure-batteries for the win.Wouldn't that require the shower being on?
It could also have a valve that turns itself off, though I'm sure it'd work better w/o it, but would require you to turn on and off the shower head.
You didn't click the link, did you?
There is no plumbing/drywall/tile work necessary. Also, it would only require turning on the water, pressing a button, turning off the water X minutes later.
