That's not an engine
Eli
Super Moderator | Elite Member
8
Pretty awesome eh?
I've often wondered how they machine parts so large? Are there warehouse sized lathes and mills or something? :Q
randay
11,018
216
Originally posted by: Eli
Pretty awesome eh?
die-cast.
sao123
12,656
207
Originally posted by: Rubycon
:laugh: at some of the replies here!
These engines are prime movers for ships. Modern ships use as many as six to generate electrical power. This power is used for everything onboard including propulsion and steering via bow tunnel thrusters and azipod propulsion systems. Large azipods can be over 30MW EACH.
Nuclear power requires a crew of nuclear certified engineers as well as a staggering budget secured by taxpayer funding. The obvious advantage is no bunkering (re-fueling) required for as long as TWO YEARS.
6 of these engines... holy hell?
what is this an aircraft carrier?
arcenite
10,660
7
Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
Well at least now we know where all the oil is going...
Gibsons
12,530
35
Originally posted by: Riverhound777
I wonder how that would compare to a Nuclear powered ship.
Reactors on nuclear subs are around 50K hp, IIRC, a little under 10X one of these.
Demon-Xanth
20,551
The key thing is that some of those ships can haul 15,000 containers. Each of which will be hauled by a truck. (9000 is a common number though)
Gibsons
12,530
35
The USN's conventional power carriers are rated at a total of 280,000 shaft horsepower Text, roughly the equivalent of 40 of those. I don't think that includes the electrical power, either.
Edit: whoops, I was reading horsepower per cylinder, not for the whole engine. d'oh! So it's more like 2-4 of those, not 40. :eek:
rgwalt
7,393
And those containers end up delivering more shit that you don't need to your local Wal-Mart.
Eli
8
Pretty awesome eh?
die-cast.
Uh, yeah. You still have to machine the parts to spec. They don't magically come out of the molds machined.
Sep 12, 2004
16,852
59
86
Pretty awesome eh?
die-cast.
It's highly unlikely to be die cast anyway. Building a die casting mold for something that large would be cost prohibitive. More likely it was sand cast. That crankcase was likely sand cast in sections and then bolted/welded together. I can't imagine they would be able to control tolerances, cooling, and prevent air pockets if they cast it as a monolithic piece. A bad pour and you're remelting tons of metal, not to mention the cost of a new mold.
moparacer
1,336
Imagine building that thing, installing it in a boat and upon initial start up you realize someone forgot to torque the bearings and it kicks a rod out the side of the block.....
:Q
