Intel won't be as scared of i3 overclocking as they will that 3.4 GHz LGA1151 Xeon for ~$260.
edit: what boards support that chip? It's the Xeon E3-1230 V5:
http://pcpartpicker.com/part/intel-cpu-bx80662e31230v5
pcpartspicker is listing zero LGA1151-compatible boards . . . oh wait, you need something like the c230 chipset to use it. Blah. That's a non-starter.
btw, ASRock has a Z170 board for ~$80 on NewEgg:
http://pcpartpicker.com/part/asrock-motherboard-z170pro4s
If they enabled bclk overclock on that thing, whew!
I don't think you need any special board to run that Xeon. The previous Xeon E3-1230 all worked on regular motherboards. It may just be that these chips were recently released to market? It seems like none of them have any reviews on Newegg. If the 1230 is compatible with a Z170 and can overclock, that was be awesome.
The OCing is being done entirely on the BLCK, it's not going to reach K chip OC's. You'll see mild OCing with this. Well...I would not have expect it to reach K series OC's on the BLCK alone.
Definately that is bad news for Intel.... Kabylake will get ruined hard.Well there's the knock on effect. If the next gen is offering ~10% performance gain against locked chips the OC'd SKL gen are likely going to be faster.
I don't know if these "look at me OC non-K SkyLake" article writers are fully stability testing their OCs but there might be quite a lot of potential with BCLK considering the other buses like PCIe are locked to their appropriate clocks with SkyLake processors.
This person was at least able to run Cinebench R15 with an impressively overclocked i5-6400 at 4726MHz:
http://overclocking.guide/overclocking-non-k-intel-skylake-cpus-performance-tests/
Will be interesting to see when and how Intel tries to put the genie back in the bottle.
Oh boy.... that would be epic to watch.... Core i5 U outperforming Core i7 ones.... Or an HQ Core i5 sodomizing a Core i7 U ones...So it should be possible to overclock laptop processors then. Does anyone know if this can be done in software ala throttlestop or rmclock, or does it require bios functionality?
Given that skylake U undervolts pretty well, and overclock should be ok.
They did block OC on non-Z with new firmware, it's the main reason why I won't update my motherboard past what it's at now. With G3258 Intel and MS also unleashed a microcode update with Windows 10 that prevented booting (or something like that) unless you went back to stock clocks or ran with one core enabled. For whatever reason Intel hasn't done the same thing with their K chips which allows me to still use Windows 10 with my i5 OC.
If this ends being a thing, I might as well go for i5 6500 and clock it upwards of 4GHz on an H97 for a fraction of the cost. Just like old times 🙂.
From what i understand, ASUS BIOS release will only be for the High-End ROG series motherboards and that means expensive Z170 boards.
So is a new socket maybe? Remember Nehalem and Sandy Bridge....Francois Piednoel indicated on Twitter that Intel isn't going to nerf this:
https://twitter.com/FPiednoel/status/675808618315251712
What are you talking about? Intel's released a new socket with every tock, regardless of whether the previous socket was overclockable. Intel isn't going to change sockets before Kabylake.
