Shamrock
http://techreport.com/news/24009/am...mpaign=Feed:+techreport/all+(The+Tech+Report)
This is in response to the rumor of Intel going socketless.
If only they'd make a CPU we'd care about putting into their sockets.
Clearly I buy my motherboards based on whether it comes with a Socket or not. The way that the CPUs line up to the markers, pushing down the lever to lock it down. That's the only reason why I'd spend so much money on a desktop. 😛
The road-map is all over the place but Steamroller and Excavator will happen.So Steamroller may make it to the FX line after all? All this information is confusing.
AM3+ will get killed off since there will only be tri-channel/quad-channel parts after Orochi dies.Although i hope they abandon AM3+ its about time it died off, need some modern LGA goodness.
The road-map is all over the place but Steamroller and Excavator will happen.AM3+ will get killed off since there will only be tri-channel/quad-channel parts after Orochi dies.
The important question really is, are Steamroller and Excavator happening in a timeframe that is relevant?
If Steamroller is 2013 and Excavator is 2014, then there is a chance the answer is yes.
If Steamroller is 2014 and Excavator is ... whenever ..., the answer is very likely no, unless Steamroller is a Conroe-sized improvement compared to Piledriver.
According to previous roadmaps, Vishera was the last performance desktop CPU; it was APU's only after that. So based on his statement that would mean:That will continue through 2013 and 2014 with the "Kaveri" APU and FX CPU lines.
I can see some justification in waiting until 2014 if they move to DDR4. The APUs really need some more memory bandwidth to shine.
That may be true, however, the longer it is delayed, the more it will have to compete with more power efficient and higher performance (hopefully) low/mid range discrete gpus. Since APUs tend to be a budget solution, you also have to be concerned about the cost of DDR4.
Personally on the desktop, I dont ever see APUs as more than a "jack of all trades, master of none" solution. In laptops and tablets, APUs are much more relevant, since power savings is critical and you can not easily add a discrete card.
Steamroller is a Tejas improvement on Bulldozer rather than a Conroe improvement on Bulldozer.the answer is very likely no, unless Steamroller is a Conroe-sized improvement compared to Piledriver.
