Assimilator1
- Nov 4, 1999
- 24,182
- 528
- 126
Originally posted by: Amaroque
I brought the system in my sig here, but it seems the CPU is dead. I put it in my sisters rig (swapped the 3500) for a while, and then it sat in the plastic package it came in (with the anti-static mat) in a box for a while.
Long story short, I put the system back together... Nothing.![]()
It's a shame, as I bought the CPU rite when it came out for ~$1000. :|
Supreme Commander (PC-Game), encoding (in both WMP, and DVD shrink
Originally posted by: Captain Howdy
Wow, I am very unhappy with the way this DC client can monopolize CPU cycles, never had this problem with RC5. Sometimes I have to close this to use CPU-intensive tasks, like Supreme Commander (PC-Game), encoding (in both WMP, and DVD shrink)
(Yes, the client is set to be a background task, but it still seems to take 'control' of the CPU.)
Interesting, do you have it set as background in the 'config.txt'? Also, are you running 'muon1_background.exe'?
Aside from that, I couldn't think of any problems. I personally haven't had any problems with DPAD. The one thing you may be running into, is that DPAD uses ALOT of RAM.
I use all those while crunching too lol I love Supreme Commander have you tried command and conquer 3 yet? Out of curiosity,
how much ram are you running in that rig?
Are you running an antivirus scan in the background at all?
I've run DPAD on everything (concerning AMD) From simple Tbred's, to X2's. As far as Intel, a couple P4's, and one C2D (I didn't bother with the P3's).
This shouldn't be happening.![]()
