destrekor
- Nov 18, 2005
- 28,799
- 359
- 126
If that is a problem, i'll recommend saving some dough to buy newer cards to be launched in q2... and upgrade chassis CPU cooling at the same time. Unless, you're itching to play a new game, which you must. In that case, a single 290 should be more than enough for most games.
Upgrading the case and CPU cooling is out of the question. I'm not doing that this late into this build's lifespan. It's an i7 2600k and Asus P8Z68 Deluxe build. Outside of the GPU (this is the first upgrade since I put this together), I'm not spending more money on other aspects of the build unless I'm starting over entirely.
I might not care about the streaming in the end, it'd be a bonus - and AMD's hardware encoding could be improved with drivers, though it might be tough to match Nvidia's dedicated encoder in terms of not rendering a performance hit... I'm trying to figure out if replacing the intake right next to the GPUs on the side, and making that the exhaust from the radiator. Then I would put in top fans as intake to compensate.
