FUD R US up in this thread with you two nvidia fanboys.
Toms is accurate here, anandtech isn't. Pretty. simple.
but I wrote nothing but facts;
none of it is even opened up for a debate
why FUD :ninja:
why FUD :ninja:
Technically it's all FUD if you're afraid of it.
I had no intention of making you fearful.
But I guess you are right: Facts or not, if your are afraid of it, then I AM spreading F(ear)UD.
This also means that R9 M295X have the memory bus chopped in half and have 12CUs disabled.
Source:http://www.computerbase.de/2014-06/amd-firepro-w8100-hawaii-nicht-tonga-gpu/
AMD apparently instead of using an actual Tonga GPU in W8100. Used the Hawaii GL40 ASIC which is the equivalent of the R9 290 graphics with full DP capabilities.Sorry, I don't speak German and Google translate butchers German so as not to be reliable. What makes you think that Tonga has a memory bus that's chopped in half and 12CU's disabled?
Haha I knew it. Tonga is NOT based on Tahiti.
Tonga is based on Hawaii!
Thanks to Computerbase we know a lot more of the specifications of FirePro W8100.
Shader count: Still unknown but atleast 2048 shaders (32CUs) based on R9 M295X leak
Shader clock: 917 Mhz (Not known if it have additional turbo boost)
Bus Width: 512bit
Memory clock: 1250MHz
Memory Bandwidth: 320GB/s
Average what over what? How are they measuring this average? Likely they take measurements at different points in time and they average them, but how many?
Instantaneously is the only way power can accurately be measured anyway. It appears you don't understand much about how measurement power works.
It's the highest average value over a 5 second window (this way we're measuring full power consumption, but not transient peaks). That said our Crysis 3 test is rather consistent, so it will hold for well over 5 seconds.
-Ryan Smith
Auf Nachfrage bestätigte AMD uns gegenüber, dass bei der FirePro W8100 die Hawaii- und nicht Tonga-GPU zum Einsatz kommen wird.
On demand AMD has confirmed to us that a Hawaii and not Tonga GPU will be used at the FirePro W8100.
I fail to see the point in bringing new cards to the table if they are only to just out due the card that they are replacing for around the same price,
to me all they are doing is milking the general public of the money,
at the end of the day people want an improvement to the point of 30% to 40% on every new version of card not 5% or 10% thats crap.
For me, doing more with less is better, that's why i prefer new architectures showing up now at 28nm.
Would be so cool seeing "Maxwell effect" in a 280x chip consuming 270x power with no node shrink.
Not much difference in consumption between a 280x and 270x.
Both AMD and nVidia have nothing good to release.
50W is a pretty big difference in my book. You're forgetting that that graph is total power consumption, not just the GPU. If isolating the GPU power useage were possible, the difference percentage-wise would be pretty high. (~25%) If that's not impressive to you, what would be? 50%?
