Suspicion about Shari Redstone of CBS
Muse
41,113
10,331
The New Yorker ran an interview of Leslie Stahl (senior 60 Minutes stalwart) May 31st in which this appears:
I have to say, Lesley—and with no relish at all—it looks pretty obvious at this point that they’re going to settle that lawsuit just as ABC did, so that they can be sold to Skydance.
Yes.
Read that interview.
Megyn Kelly of Fox News is a coward and a creep. I loath Donald Trump and I loath Fox News. Add Megyn Kelly to the list. There was a moment a few months ago when I wondered about Leslie Stahl, but since then I've decided she's pretty OK.
fskimospy
55,704
Yes.
So we agree that no settlement has happened then.
Josh128
1,505
2,256
Assuming you live within range of those signals ... not always the case. And it doesn't account for producers using exclusivity of certain distribution methods either.
Calling it "completely" due to that is probably not really that accurate.
I live in one of the most poor and rural locations in the US, south central Louisiana, and I get around 25 channels, reliably.
Muse
41,113
10,331
Which is completely due to the ignorance of the masses who dont realize that you can get 20+ channels of HD content, PBS, local news, and the big 4 broadcast networks for free with a simple outside antenna connected to your TV. Add a no-subscription-required OTA DVR device like Tablo and you can pause, record, and stream to every smart device in your house. Spend about $200-$300 for an initial setup like this and TV is free for the rest of your life.
But no, due to technical ignorance of todays "tech savvy" people, you dont have TV unless you have NFlix, Prime, AppleTV, etc. etc. Pay, pay, pay, every month, for the rest of your life. And, pretty soon, like you said, they will start to shut down terrestrial broadcast towers and that will be the only choice, as if we arent nickel and dime'd enough for everything already as it is.
Yes, yes and yes. I do OTA. Almost never subscribe to anything. Did MAX no-ads for a couple months for some specific stuff and cancelled effective 5 days ago.
I have 43" 4k Roku TVs (cost me less than $250 each and have rooftop antennas) so can FF/Pause/Rewind for the last 90 minutes of programming (which gets zapped if I change channel :( ). I need to do the OTA DVR thing, haven't gotten around to it. Thanks for the tip there, @Josh128. I had something "in mind" but haven't checked it out.
Reactions: Josh128
outriding
4,586
4,036
OK, but like seen, it's assumed it will, so BFD. See ya on the other side.
Trump refused their $15M offer, demanding $25M.
And an apology …
I would pay CBS to write their apology… and it would be the best apology with the best words in the world
Josh128
1,505
2,256
Not to go too much off topic, but the no-subscription OTA DVR is a miracle worker, I HIGHLY recommend one. We use ours to record the local and national news on our preferred channels every day, and they also allow you to record series, even if they play at completely random days and times, like PBS Nature & NOVA. I have two ChannelMaster DVR+ units (that are no longer manufactured, unfortunately), 1 in living room and 1 in bedroom and we use them EVERY SINGLE DAY. We have a 1TB external drive connected to each one. They dont even have wifi, the program guide via the data stream from the off air channels themselves is sufficient. They are fantastic, but ChannelMaster replaced them with an inferior model that was completely different, cheaper and much less robust, despite "wifi". I tried one of those (which have also since been discontinued) and found it to be junk compared to the DVR+.
Ive not tried the Tablo, as the DVR+ units do everything I need, but if I had to try something new, I would go that route. If you can find a good deal on a used DVR+ on Ebay and dont need Wifi connectivity, they are fantastic for what they do, IMO.
Pens1566
13,928
11,620
Proximity/distance to N.O. or Baton Rouge?
I live in a ~100k city that has ZERO broadcast stations, the closest is ~60 miles away, is only for CBS, and isn't reliably available due to weather/geography.
I haven't seen the most recent coverage #s, but it's simply not an option for everyone.
fskimospy
55,704
I mean we will see. I doubt she has much actual knowledge as to what’s being talked about though.
They could absolutely end up caving to Trump’s bribery request but as of now they haven’t. If they do it will be entirely due to their desire to pay off public officials for favorable regulatory treatment though, nothing to do with the merits of the case, as it has none.
Reactions: Muse
Paratus
17,722
16,012
We’ve got an OTA TIVO that we paid for the lifetime channel guide and schedule subscription it’s been great for watching the news and a couple of shows we care about
Reactions: Josh128
Josh128
1,505
2,256
As the crow flies, Im 75 miles from Baton Rouge, 150 miles from New Orleans. I dont channels from either of them. I get stations out of Lafayette, Alexandria, & Lake Charles.
hal2kilo
26,371
12,515
I live probably about 20 miles as a crow flies from Seattle proper (damn my r key is starting to die), and I can't get a good signal for any HD network or PBS channels probably due to the Puget sound and 2 ridges between. Anyway, there's a small mountain over my shoulder and on it is a big TV transmitter that has Fox, and about 5 religious channels that I can get just fine. So much for over the air broadcast since they decided to abandon VHF when switching over the HD which has much superior reach (but not as much bandwidth).
Reactions: DaaQ and Pens1566
Josh128
1,505
2,256
I have an omnidirectional internally amplified antenna on a 25' mast above my house, going to a 4 port distribution amplfier at the base, with cables from there to my living room, utility room, and 3 bedrooms. I catch KPLC (Lake Charles) which is around 60 miles, just fine. Height is everything with terrestrial reception, especially if you live in hill country. I live in flat prairieland.
UNCjigga
25,648
10,353
Aereo/Locast would’ve been even better solutions for low cost TV (cloud-based OTA and unlimited DVR) but they were sued out of existence thanks to end-stage capitalism and our corrupted court system.
Pens1566
13,928
11,620
This just isn't practical for me. The lengths that I would need to go to would far outweigh the benefits. And, as much as I'd love to donkey punch my HOA board over fighting that aspect of it, it's just not worth it.
Reactions: hal2kilo
Muse
41,113
10,331
Thanks for the info! I do a LOT of ebay buying of used stuff with great success. Got a couple packages in the last week, A+ transactions. Will look into the DVR+ and Tablo. I've been meaning to go DVR on my OTA stuff for years now. I did with my projector setup which is based on old PC DVI cards (MyHD120) that are good res but have some nasty bug issues. That has software that's DVR and I can watch recordings at any time, still can, but I like my 4k TVs' image a lot more and have just put up with the vast restriction of having to be within 90 minutes of live broadcast of anything I watch. Even so, I NEVER watch live, hate commercials!
I may get 2 DVR systems, the 4k TV in my bedroom gets the lion's share of my TV viewing but I have another in the kitchen, so... ;)
Sorry to be OT, folks, but hey, maybe others can benefit from the info here as Josh128 obviously knows.
I live in metro Bay Area. TV is pretty much everything, certainly the major networks, which is pretty much all I tune into anyway and from one direction. I would like some low power FM from other directions, my car gets them. I bought FM specific antennas for that.
Reactions: Josh128
Muse
41,113
10,331
I got wind of a price drop on Tablo 4th gen 2 tuner 128GB internal storage DVR (pre Prime Day, but I don't have Prime anyway) a few days ago and ordered one for $59.95 off Amazon, free shipping. I have it next to me, shrinkwrap still on it. Buncha projects next couple days, will see about getting things going over the weekend. I have external USB HDs lying around, 2-3TB.
Moonbeam
74,875
6,784
No one wants to buy when the FTC is potentially going to launch bs investigations over station licensing that will slow or halt a sale.
The lawsuit is a naked shakedown of corruption by the president.
On an unrelated note, it's funny how you uncritically always bend towards the conservative position. No critical thinking.
Your statement and Greenman's, it seems to me, do not really conflict. I think Trump is a blackmailer and I think lawsuits would be an impediment to sales. Aren't you really just mad that some chose pragmatism over principle and that we have a President who will bend people over and shove it in?
fskimospy
55,704
Seems like the experience of Columbia would be a gigantic sign that capitulation is not pragmatic, no?
Reactions: Brainonska511
Moonbeam
74,875
6,784
I don't watch TV but have spent fortune on Channels, Apple TV, Plex, Homerun, 40 TB and 8 TB NAS for DVR plus full Sling and cloud DVR plus PBS, KQED for Masterpiece Theater, none of which I personally use. I would actually be better off with Xfinity cable I think. The issue with over the air in our local environment, yours is the same as mine, is that you can't get MSNBC without some sort of subscription. One watcher in my house has to have that and I hate cable but can't escape TV. I bought a thousand dollar 65 inch Qled for the TV watcher here but it was pronounced too big so I gave it to my Nephew. I have a Sony 5 piece stereo from the 80s in my front room and unopened Klipsch speaker system and record player in my garage somewhere but I just listen to music on occasion via headphones and YouTube.
When I become convinced the MSNBC banner would cause burn in any time soon in future OLED TVs I will maybe buy an LG OLED 55in. I skipped OLED for a monitor purchase I recently made for the same reason. Game banners are always lit in fixed positions.
Reactions: Muse
hal2kilo
26,371
12,515
Well that's new information. Yep, googled OLED TV burn in, it's a fact I was not aware of.
