Supreme commander Quad core ready ? CPU whore
40sTheme
1,607
Originally posted by: tuteja1986
if it was poorly coded than you would see no performance difference between AMD FX60 to Quad core QX6700. They don't take advantage of more than one processing thread. Also if you know that sumpreme commander is one the hard core Enthuasictic RTS. Its not your average quick kill type rts like Dawn of War , Warcraft 3 , Company of heroes and others like that. It actually requires alot of tactical strategical thinking.
You think CoH is a quick kill game? It takes TONS of strategic thinking. It is a micromanagers heaven. I've had CoH battles last 4 hours.
Anyways, it is Quad CPU ready and utilizes them rather well, but I don't see what other people are saying about it being poorly coded for other systems.. demo runs fine on my Pentium D lol. But too bad it is a boring game where you can only zoom in during battles or you won't be able to manage your stuff.
aka1nas
4,335
Originally posted by: ArchAngel777
Those gamespot benchmarks seem suspect... The FX-60 barely scores better than the FX57. I have a hard time believing that the E6300 is THAT much better than an FX-60. Unless the game was purposely gimped for AMD systems. From what I have seen in multi-threaded performance is that the FX-60 is always faster than a stock E6300.
It's hard to say. The game might be more reliant on Integer ops than Floating point, where AMD usually has a relative advantage.
Oct 4, 2004
10,515
Yup, it is Quad-Core ready. In a nutshell:
XP SP2
Vista
(8800GTX SLI, QX6700 with 1/2/4 cores enabled, 1600x1200 No AA/16X AF, Highest In-Game-Settings)
For the full article, click here
The Vista numbers are much lower - probably because of SLI issues. It's a pity they didn't just do a single-GPU configuration.
stockjock
4,205
The other night I was playing a 3v3 and about 15 mins the game basically stopped and we were all trying to figure out who it was, then some clueless idiot says that he was watching a movie while the units were building to 'pass the time', but he wasn't lagging because he's on cable..........
OMG...I think we were in the same game. I don't think he was watching a movie...I think he was dl'ing the movie because as soon as he stopped the dl the game picked up.
Mandin62
157
As you can see in my sig my system is not great but definently not bad. and i was lagging out playing with 2 other guys on lan. one of the systems is an e6600 at 2.6Ghz and an 8800 GTS 640 the other was a a pretty old rig with Atholon 64 3600+ and a 7800 GT, I think that was the specs for the older system not sure i didnt build that one. It was liking watching a slide show at some points. could it have been the older system that was dragging things down?
yacoub
1,991
14
SupCom does see a boost with quad-core, especially since the other programs and OS processes can be offloaded to core 3 or 4 instead of taking up process time on the first two cores that SupCom inarguably uses.
Also, my 7900GT KO runs the game fine visually at all Medium settings and 4xS AA. It is only when unit count goes up that my single-core Venice 3200+ @ 2.4GHz starts to struggle and eventually turns into a slideshow. (I run 1680x1050.)
Without question the best performance upgrade one can do for SupCom is get a dual-core CPU. Then also 2GB of RAM but that should be a given today. The next best would be getting an 8800GTS. That followed then by a quad-core CPU. After that upgrade path, the game will be very much playable. Anything else would be icing on the cake.
Hit the "/" key on your numpad to see in-game FPS, btw.
CU
2,419
53
Here is the review I was talking about earlier.
Intel
AMD
This makes it look like if you have a low end video card like mine then your cpu is not the problem. Although with higher end cards and with more AI's your cpu is the problem.
apoppin
34,890
alienbabeltech.com
Let's see if anybody else can replicate this result with Supreme Commander or any other game.
Cue H-Enthusiast:
Looking back it is very clear that scaling the cores of our Intel Core 2 Duo in Supreme Commander provides positive results. Under Windows Vista we found that Supreme Commander was not playable with a single-core CPU. We ranSupCom at the lowest possible settings, 1024x768 NoAA/NoAF with all options turned off, and the average framerate was only 10 FPS. When we enabled a second core we received a large performance improvement which provided a better gameplay experience. With dual-core we found 1280x1024 NoAA/16X AF playable with ?medium? fidelity settings. The gameplay experience was even more improved by enabling the remaining two cores giving us a quad-core processor. We were able to run the game at 1600x1200 with NoAA/16X AF and maximum in-game settings. Intel?s quad-core by far allowed the best experience in Supreme Commander with all graphical effects possible enabled and at their highest detail levels.
Looks like it's time to buy a QuadCore.:Q
I think this thread is about to become very active.
Edit--Hey Mod, how about moving this thread over to "CPU/Processors" where it belongs?
http://forums.anandtech.com/messageview...atid=28&threadid=2027487&enterthread=y
in CPU/OCing now
thanks to the OP!
Genx87
41,091
513
Is the retail game more detailed than the demo? In the demo with my rig I had no issues with slowness at 1600X1200.
stevty2889
7,036
8
Originally posted by: 40sTheme
[ But too bad it is a boring game where you can only zoom in during battles or you won't be able to manage your stuff.
..so use the split screen mode, you can have the full zoomed out map on one side of the screen(or even second monitor) while zooming in on the battles you want to watch..
hans007
20,212
18
this was the exact same problem with TA and TA kingdoms when they came out.
all these 8 billion unit type games, bring every computer to a crawl. When TA Kingdoms came out I actually had a fairly high end system ( i think i had a voodoo 2 12mb and a K6-2 @ 500mhz ) and it played like ass. and that was high end back then.
AkumaX
12,648
4
those specs bring a tear to my eye :D
CaiNaM
3,718
Originally posted by: ayabe
The developers have stated that it's a dual threaded app, so those results don't really jive.
it will use 100% of one core, and 20-30% of the second core. doesn't seem very well done...
Nightmare225
1,661
I feel so old... :(
yacoub
1,991
14
...if you don't understand the concept of threading and the reality that not every thread is going to fill up a CPU... and that you can't use all cores to 100% when there are background and OS processes that demand time.
LittleNemoNES
4,142
Originally posted by: Nightmare225
I really need a quad-core for this game. :(
Hopefully the Penryns will be cheap and work in a P5W...
dude just OC that e6600 to 3 ghz without changing the voltage.
Also, do you have at least 2GB of ram?
I play @ 1680x1050 with excellent performance @ max settings.
Chaotic42
35,333
2,473
Yeah, it's eating my E6600 alive. I bought it in August and didn't even get one game that it could dominate.
