Originally posted by: Macro2
PW finds plenty of 1600+ for 66, 1700+ for 72 and 1800+ for 83. Either AMD and/or OEMs are dumping or they are making way for T-breds...
Which one is the best deal for non overclockers...?
mac
If you are not an overclocker, then it probably won't matter if you score 9400 3dmarks or 10,000 3dmarks.
The little things like raw numbers won't matter.
Along the same lines, you probably would not be able to tell the speed difference between a stock XP1600+ and a stock XP1900+.
So the best choice for non-overclockers is the cheapest CPU, (XP1600+), not the fastest stock rated. (Even though when overclocked it is the fastest).
The nice thing about that is "if" you need a little extra speed (which you probably won't notice), you can always spend 10 minutes and overclock it later.
BTW, as has been pointed out, Newegg's high volume sales means they always have the latest steppings, and this again has proven to be true with these CPU's.
AGOIA and AROIA are what you will get, (99% probability) unless a newer stepping comes out.
That's what I get. That's what all others are getting in overclockers forums.
Be very cautious with other venders.
Many of them will hand pick out the cherry's like AGOIA/AROIA, and will only sell the poor steppings cheap, while charging a premium for the good steppings.
Also, have seen some of the low Pricewatch CPU venders offering ZERO warranty on OEM CPU's, unless you also buy a HSF from them at same time!!!!! Read the fine print!!!!
