Originally posted by: SlickSnake
Here Is A Good Link To Science News About Space Discoveries
And as far as a PMed request for proof Mars is not red, just look at the color enhanced doctored rover pictures from Mars that show they are altering the colors of the rover itself when they show pictures of the rover from mars. The pictures taken of the rover colors on earth do not match the picture colors of the rovers what so ever taken from Mars. And the ESA pictures of Mars from orbit do not resemble the reddish hued pictures NASA keeps showing of Mars from orbit, and on the ground.
Many More Mars Links To Doctored Pics
Mars Link
Mars Rover Altered Color
Mars Link
Wow...I'm not sure I'm going to reply to you anymore because you're really out there. Mark is RED colored because it's soil contains a high amount of iron oxide (rust). Just like water won't appear blue up close but a large amount is blue from a distance, the iron oxide shows up as red on Mars at a distance. I've seen Mars through a one-meter telescope...it is orange red in color, trust me. Color enhancement on space pics is done to enhance otherwise hard to see details.
Mars Link
Enjoy. Don't make me open the can of Whoop-ass again.
Don't astronomers usually go to great pains to reconstruct accurate color images from the various telescopes they use when they can? And when they reconstruct those false color images, they also tell you how they are reconstructing it. Is Nasa doing this? The answer is NO, they usually aren't. So why is Nasa failing in this regard literally on nearly every image they release? Don't that seem the least little bit odd to you? These hundreds of thousands of false color images might actually be useful to a geologist. But the geologist also has to be aware exactly what filter is being used to achieve this result. Otherwise, all the false color crap is just useless. So why does Nasa not reveal what filters are being used on what images to make the images actually usable to a geologist to study? What are they hiding? And why?
One of the filters is clear - so it would return black and white images. The CCD on the rover is only 12 bit black and white. That's all it can do. L1 is the clear filter. If it's used, all you get is a plain black and white image. When imaged through the other filters, that's when you can get color images. Take three black and white images, one each through red, green, and blue filters, calibrate them properly, combine them, and you'll get an approximate true-color image.Originally posted by: SlickSnake
Your post was highly informative to those who don't understand photography or the filtering systems used on the various Mars probes. However, I already have a background in photography and photographic methodology. The point being made by me is not the quality or techniques used on the light filtration process. The point is the pictures are not being released with the proper color filter being used. Since one of the cameras filters is obviously clear on the rovers, why would Nasa choose to only release a false color image of Mars for public consumption? Especially since this lends credence to the fact they are altering the pictures of Mars? Which they obviously are as you are clearly pointing out.
They DO reveal what filters are being used. It's right in the filenames.Don't astronomers usually go to great pains to reconstruct accurate color images from the various telescopes they use when they can? And when they reconstruct those false color images, they also tell you how they are reconstructing it. Is Nasa doing this? The answer is NO, they usually aren't. So why is Nasa failing in this regard literally on nearly every image they release? Don't that seem the least little bit odd to you? These hundreds of thousands of false color images might actually be useful to a geologist. But the geologist also has to be aware exactly what filter is being used to achieve this result. Otherwise, all the false color crap is just useless. So why does Nasa not reveal what filters are being used on what images to make the images actually usable to a geologist to study? What are they hiding? And why?
Simply put, there is no liquid water on the surface. The pressure there is 1/1000th* that of Earth's. Water would boil away instantly. Ice would sublimate directly to gas.It obviously makes it easier to hide and obscure odd and unusual features in an image if you use some sort of uniformly dark colorization process on most the pictures to blur important features in an image, depending on whatever it is you may want to hide, such as blue water, or green plants. Make it all look a bit out of focus, dark and red, and the plants then all look like some kind of strange dark mineral deposits. They might as well just stop the false pretense of "color" images altogether, and simply release all the "color" images in high contrast black and white, but they don't because the higher contrast of B&W images would also defeat the purpose of artificially darkening and falsely colorizing an image red, which appears to be the sole purpose of this "red planet conspiracy" if you will.
Originally posted by: Dean
Originally posted by: Zugzwang152
Fortunately we can just send a space ship to fire a gigantic nuclear bomb into the sun. When it explodes, the sun will restart, giving us billions of years before we have to worry again.
I have been testing that theory. I lit a medicine ball on fire and just as it was going out, I fired some paint balls filled with gasoline at it. So far I have experienced a 100% success rate in keeping the ball on fire.
Mars Link
Mars Link
LOL! You've lost all credibility by using Enterprisemission.com as a source. You might as well put a link to a story from the National Enquirer![]()
No, it does NOT support the theories. It presents false color images while claiming that they're true color. That is called "lying," not "supporting."Originally posted by: SlickSnake
You think posting on here in Off Topic next to posts about non perforated toilet paper rolls gives anyone credibility to start with? Consider the original topic here "Sun burns out in 200 years". I was trying to point out similar conspiracy theories to consider. The Mars pics one fit, and came to mind.
BTW, that site has some interesting articles. It was posted primarily as a link for pics. Not as a valid reference source. But it does support the various Mars conspiracy theories.
And stop PMing me for my old National Enquirers. I reread them often while I'm on the toilet. If I ever decide to sell them, I will let you know first, ok?
The images at the Cornell University site say right there on the page, "All Images were made using filters L2, 3, 4, 5, 6, and 7." Pretty obvious to me.
This panorama says right in the description, "This is an approximately true-color, red-green-blue composite panorama generated from images taken through the Pancam's 600-nanometer, 530-nanometer and 480-nanometer filters." Based on the publicly-available information on the Pancam, those are filters L4, L5, and L6 - BGR colors, in that order.
(Note too, the filter designations beginning with "L" are for the left camera. The right camera's filters are in the far infrared.)
This image - the filename is Sol1167B_P2419_L257atc_br2.jpg. The bolded part indicates that filters L2, 5, and 7 were used.
Yes, the scientists involved went to great lengths to ensure color reproduction as accurate as a $15 million budget could allow. If you're seeing blue rocks, or a blue sky, that's because they're not using RGB filters. They'll call it a "false color" image for a reason, because other filters were used. Another example
L2, 5, and 7 were used for false color. L2 is infrared, 750 nanometers. L7 is beyond indigo, but not quite violet, 430 nanometers, as stated quite clearly in the description.
The true color was again L4, 5, and 6, RGB color, again, as stated in the description.
Simply put, there is no liquid water on the surface. The pressure there is 1/1000th that of Earth's. Water would boil away instantly. Ice would sublimate directly to gas.It obviously makes it easier to hide and obscure odd and unusual features in an image if you use some sort of uniformly dark colorization process on most the pictures to blur important features in an image, depending on whatever it is you may want to hide, such as blue water, or green plants. Make it all look a bit out of focus, dark and red, and the plants then all look like some kind of strange dark mineral deposits. They might as well just stop the false pretense of "color" images altogether, and simply release all the "color" images in high contrast black and white, but they don't because the higher contrast of B&W images would also defeat the purpose of artificially darkening and falsely colorizing an image red, which appears to be the sole purpose of this "red planet conspiracy" if you will.
Any "structures" would be easily revealed now anyway, by Mars Reconnaissance Orbiter. That thing's got 25cm/pixel resolution. If any discovery by either the MER or MRO team was life, word would get out, fast. Discovering direct evidence of life on another planet would be the biggest scientific even since the COBE mission analyzed the cosmic background radiation.
Its actually only 1/7th the earths in the lowest areas.
I haven't heard anything like this.Originally posted by: getbush
Well the common theory people keep mentioning, that the sun is half way done and has maybe 5-6 billion more years also has another point. Under this idea, it's not the end of the sun, it's implosion that will be disastrous for earth. That would actually happen a short 400-500 million years from now as all the water is boiled off the surface of the earth due to the sun constantly getting hotter. So somewhere before that point is the end of life as we know it. Earth will already be a dry rock before the suns implodes.
