Suggestions on Building a PC
If you do ever decide you want more RAM, it wouldn't be a bad thing. 8GB of RAM is more than I've ever had in any of my systems though. It's not like you NEED more ram for editing, it's something you may want. If you know what I mean.
Yes.
I think i have everything together now.
Cpu/Ssd Combo
Mobo/OS combo
Ram
PSU/HDD combo
dvd/cd Burner (2x)
Video Card
Case
A list of the components are:
Case-AZZA Solano 1000R Black / Red Japanese SECC Steel/Metal mesh in front ATX Full Tower Computer Case
Video card-ASUS ENGTS450 DirectCU TOP/DI/1GD5 GeForce GTS 450 (Fermi) 1GB 128-bit DDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
CPU-AMD Phenom II X6 1055T Thuban 2.8GHz 6 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Six-Core Desktop Processor HDT55TFBGRBOX
SSD- OCZ Agility 2 OCZSSD2-2AGTE60G 2.5" 60GB SATA II MLC Internal Solid State Drive (SSD)
Mobo- GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
OS- Microsoft Windows 7 Professional 32-bit 1-Pack for System Builders - OEM
RAM- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL
HDD- SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
PSU- CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ...
Optical Drive- ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
How does this Look? 😕😱😕
Looks pretty good to me. The 430CX would be a better-matched PSU, but with that combo and the MIR, the 650TX should come out to be about the same price.
I agree. I'm not sure about the case (never heard of AZZA) but I think everything should be dandy. You found a ton of great combos too!
EDIT: Honestly I would probably stick with the Antec 300 case. It's known to be a sturdy, well cooled case and it's less expensive WITHOUT worrying about getting your MIR.
If you want a good windowed case, get the Antec 600
http://www.newegg.com/Product/Produ...129079&cm_re=antec_600-_-11-129-079-_-Product
I know... I dont even think i can comprehend what that can be used for 😵😕😵😱D:
What would it be used for by the way 😵
Scientific applications spring to mind. We have a machine at work that has 512GB of RAM and a certain professor keeps asking for more.
I'm pretty sure you need to have a custom setup with multiple mobos. So it would be like 10 computers running 1 os. So You would probably get multiple dual Xeon boards and it would probably cost well over 500k.
