KillerBee
That worked perfect ! Thanks Ken
Well it almost worked perfect except for leaving youtube videos reversed
Youtube links are Iframes, so...
Code:.messageText iframe{ filter: invert(100%); }
One more thing Ken
Is there any easy way to drop the "Members Online Now" and "Staff Online Now" side bars
but leave the "New Posts" side bar?
Is there a way to extend the New Posts sidebar so it shows more than 5 ?
That piece of content is just 5 items. There are not more hidden off screen.
CSS alters the display of a website, it does not add content to it.
It'd be possible for Grease Monkey to make that change, by also loading content from another page and then throwing it in.
body, img, .img.m, .img.s, .messageText iframe, #userBar .navTabs {filter: invert(100%); }
Update on the avatar backgrounds....
This one line might have all the inverse code needed.
Code:body, img, .img.m, .img.s, .messageText iframe, #userBar .navTabs {filter: invert(100%); }
I'm almost ready to release the first Reverse theme. Just need to tweak the search bar colors so you can see it.
Known issues:
- Images while editing a post are inverse colors! Opps. Will try to find the appropriate selector to fix this asap.
Update: Editbox is inside an Iframe. I can inverse the entire frame, but elements within it are causing trouble. Not sure I can select / edit them at this time... Is this a fatal flaw of the inverse method?
How did you reverse the entire Editbox Iframe?
.redactor_box iframe {filter: invert(100%); }
With the following:
Code:.redactor_box iframe {filter: invert(100%); }
I still feel like it's way too wide.
html.is-fullWidth .pageWidth {
max-width: 1000px;
Classy graphite/copper theme there. Very fetching. Funny that it actually reversed the video. The power of css these days .....Well it almost worked perfect except for leaving youtube videos reversed
I might have to install Stylish ... sometime. Not sure.
Even awesomer now Ken g6 🙂I updated the vBulletin style with lots of changes to thread listings, and I made quotes look very much like vBulletin.
This makes me feel all warm and fuzzy inside.I updated the vBulletin style with lots of changes to thread listings, and I made quotes look very much like vBulletin.
