Originally posted by: PurdueRy
gas pedal FTW
:thumbsup:
gas pedal FTW
Originally posted by: maximus maximus
Originally posted by: jst0ney
Originally posted by: senseamp
Handbrake. Give it a little gas, slowly release clutch when you feel it start to catch, release the handbrake.
only way to do it on a steep hill
Wrong !!! I have driven a stick shift for more than 6 years now. I use gas + clutch and no brakes. Yes, you heard me right. No brakes.
Just give it a little as and release the clutch just a little. The accelaration pushes the car forward and the incline pushes it back negating the forces.
Once the light goes green, I just increase the gas and release the clutch a little more.
Practice this and it will be a peice of cake to stop on inclined surfaces.
Originally posted by: homestarmy
Originally posted by: dmcowen674
Good topic
I can't count how many times clutch drivers have rolled into me on an incline.
Sometimes I've just had to keep the nose up on their rear to stop them from rolling.
Wow. I have never seen anyone roll into someone in this manner.
You know what that means? You're an asshat and don't give the poor guys enough room. They shouldn't need any room, correct. But as with every portion of driving, you need to give a little extra just incase.
You heard it here first folks, he's an asshat.
Originally posted by: KK
No, we didn't hear it here first.
Originally posted by: Lucky
It's illegal in most states NOT to keep the car in gear while at a stop.
Hi, can you please post the revelant law for most states that say this please? if not STFU.
only way to do it on a steep hill when you're a newbie
Originally posted by: 5150Joker
My clutch hasn't been replaced in 6 years since it still works great so your warnings are falling on deaf ears.
Originally posted by: DonVito
The "quick feet" technique also seems unnecessarily risky to me, since you're trusting that a) the person behind you isn't too close, and b) your foot won't slip off or miss the clutch or gas pedals at the critical moment (this last issue may sound fanciful, but if you live where there's significant rain and snow, it isn't). Also, having lived in San Francisco, there is no way the "quick foot" technique wouldn't also lead to decreased clutch life on a truly steep hill, since you're creating a lot of completely unnecessary spinning against the clutch disc under high tension. "Quick feet" just seems dopey to me, even if it works the majority of the time, since there's a superior method readily available.
Originally posted by: quasarsky
its easy. just buy an automatic and tap the breaks 🙂
You may want to edit your post. I am no fan of Dave's, but he enjoys special favor from the mods.
Originally posted by: Witchfire
Sorry... No, it doesn't add safety. It adds unnecessary steps to a simple process. Using the handbrake is actually one of the more serious errors that can be done. It has the potential for locking up the brakes, due to the mechanical locking mechanism built into them.
The handbrake is to ONLY be used for parking. Other uses are a common misconception. The correct terminology for the 'handbrake', as you put it is Parking Brake, not 'handbrake', or 'Emergency Brake'.
This information is actually part of the Commercial Drivers License test.
Originally posted by: DivideBYZero
Originally posted by: alimoalem
well for one, you need more gas (as has been stated by others). i haven't read through the thread so excuse my post if it's been answered. i would recommend using the parking brake until you're more used to stick shift.
pull up your parking brake, get the gas up to around 3k rpm and let go about half of the clutch. start letting the parking brake down slowly and if you start moving backwards, apply more gas. if you're already a 3-4k rpm though, let go of some of the clutch. then just do the normal clutch release/gas application you would do on level ground. it's hard describing but yea.
the other option is push hard on the gas, let go of half the clutch, once you hear the rpm drop a little apply some more gas, and then eventually let go of the clutch completely. hope this helps.
3-4k?! LMAO!
Sucks to be your clutch.
Originally posted by: kmrivers
i put my foot on the brake.
3-4k?! LMAO!
i never said i take up to that. i'm recommending it to the OP because he's new to the method. whe he gets comfortable with it, he can do it at lower RPMs. the idea is not to stall
Wow, you wouldn't last five minutes with a UK driving instructor.
[Edit] Oh, and I'm fairly sure that the manual for my Focus refers to it as a handbrake.
Originally posted by: BD2003
I personally concentrate more about communicating to drivers behind me to give me a reasonable amount of room. Unless the hill is a massive incline, you dont even need quick feet, you just need normal feet, as long as you have a foot or so of space behind you.
I was in this situation yesterday...came up to a massive hill, and there was a dumb broad in a mecedes SUV just riding my ass as we got to the stop sign. I made sure there was at least a car length in front of me before I stopped. She gave me maybe 2 inches behind me. I revved and creeped forward a bit - obvious I was driving a manual. She creeped onto my bumper again. Then I put it in reverse, kept the clutch down, and revved the hell out of it. Apparently that scared her. She gave me all the space I needed after that, and I leisurely took off with the not-so quick feet. Its rare enough that a car is on your ass so bad that you need to worry about bumping into them behind you - most of the time drivers understand to keep a little distance, especially from cars that look like theyd be stick. Some dont - and they get bumped with no remorse given they had a warning. Using the handbrake is probably the "right" way to do it, but so is going 55 on the highway, and who the hell does that anymore really.
Originally posted by: AntaresVI
Wow, I had never even heard of the handbrake method. When I was learning stick, my dad just took me out to a steep hill on a road that no one ever used and wouldn't let me leave until I could get up it from a stop a bunch of times in a row. It really isn't that hard to do the brake-gas jump without rolling back if you've practiced it enough.
This sounds like a lot of hassle to me (not to mention that you're presuming the driver behind you isn't so oblivious that he or she will eventually get the message), when there's a perfectly easy way to get up that hill without rolling back even an inch.
In San Francisco, where I used to live, there are lots and lots of ultra-steep hills with stop signs at the top (obligating you to stop, over and over, on a steep-ass hill with cars in front of and behind you). These are some of the steepest paved hills on Earth, with stairs on the sidewalks. I guess I am still at a loss to see how the "quick feet" technique wouldn't lead to added clutch wear in that situation (since the car is fighting rolling backwards as you're engaging the clutch), not to mention opportunities for failure. Even if you use "quick feet," the parking brake just seems like an added measure of safety and protection to the clutch. I'll agree that in most situations "quick feet" probably works just fine, but having driven in extremely hilly conditions, I think the handbrake is just a superior technique.
basically a summary: handbrake technique is the "safest" and the recommended way..."quick feet" or even "normal feet" is basically when you're lazy and do have enough control over your car not to turn it off or roll back too much.
OP, have you attempted using any of these techniques? any success stories? any failure stories?
